Go Back   IH8MUD™ Forums > Toyota Tech Forums > 70-Series Tech
Old 01-17-08, 11:23 AM   #1
76 series land cruiser locker
Hi guys, I was wondering what options are available for the following land cruiser in terms of auto lockers, like lockrite or detroit locker, I am in the U.S. but do not know much about 70 series cruisers.
Most sites I visited only specify the fj40-60-80 applications.
how do you relate 70 series to those? are the axles the same as 76 series?
Cruiser on hand:
model:KG-HZJ76K-RKMES
Engine :1HZ
Frame:HZJ76-0003298
trans/axle R151F K284
from looking at the following site it has a 9.5", 4:30 4 pinion differential.
Toyota Differential Identification - Toyota at Off-Road.com
also are the lockers the sam for front and rear axle?
Thanks in advance for any help.
Vadim
vadimb is offline   Reply With Quote
Old 01-17-08, 05:23 PM   #2
Diesel for blood
roscoFJ73's Avatar
What year is yours and what country was it intitially sold in?
The7* series have had a few changes to diffs since 1984.
FJ73+1HZ Diesel NEW GEARBOX
33 in BFG A/T
Volvo 740 GL
Old 01-20-08, 11:27 PM   #3
UpsideDown's Avatar
Most any Land Cruiser locker will fit, but you will have to provide some details. In any case, don't worry - you have lots of choices.
1978 FJ40 - parts vehicle - PM me
1987 HJ61 VX 5spd - loaded - daily driver
1981 BJ42 - ARBs, Warns, oba, ps, h55f, hws, soa
UpsideDown is offline   Reply With Quote
Old 01-22-08, 08:17 AM   #4
Tapage's Avatar
Interesting see that you have the R151 instead of the usually ( as far for us ) H150 that come with the 1HZ engine ..
Post a pic but I thought you have the front reverse cut 8" HP 3rd member and the rear 9.5" so lock right, EX locker, Detroit, No Slip, ARB for rear ..
For front I only recomend a selectable locker .. that in your case ould be ARB of the factory $$$$ one .. ( electric or cable with proper long splined axles to suit it )
HJ-60 2H-T Intercooler Tencha
Originally Posted by pygpen
Old 01-22-08, 03:43 PM   #5
Diesel for blood
roscoFJ73's Avatar
Oz had the R151 from 98 on behind the 1HZ. Lots of problems
33 in BFG A/T
Volvo 740 GL
Old 01-23-08, 10:50 AM   #6
Tapage's Avatar
Yeah . ? let me know the most common . ?
I thought the H tranny series are more tough ?
Old 01-23-08, 12:52 PM   #7
Diesel for blood
roscoFJ73's Avatar
I think the R151 main shaft is in 3 pieces that want to separate and the bearings dont last long.
A gearbox shop told me they just wear out everywhere,shift forks also
It was originally a Supra gearbox.
Most of my friends wih 105s or 79s rebuilt the gearbox before 150000klms.
If it is a one owner and driven very gently to church each week,then it maybe ok
The H55f,H150 and H151 are ok
They also had the 8" front diff which was based on a Hilux design and that was another problem.
33 in BFG A/T
Volvo 740 GL
Old 01-23-08, 01:47 PM   #8
Tapage's Avatar
Why didn't make a swap .. for a used H151 . ?
Static caravans for sale | Loans | Mortgage Calculator | Secured Loans | Mortgage Calculator
