Go Back   IH8MUD™ Forums > Toyota Tech Forums > 70-Series Tech
Old 10-28-07, 03:40 PM   #31
lshobie's Avatar
Well, it you don't use mandrel bends then you will be down to 2.5 inches which is still good - but not as good as 3 inch mandrel. Lots of welds aren't bad. There is a guy in town here with 3 inch stainless, and I can get the mandrel bent j pipes if you need them in stainless or regular steel.
Louis
Join the True North Toyota Land Cruiser Club in Ottawa http://toyotalandcruiser.blogspot.com/
Join the IVOAC here to keep JDM's coming - www.ivoac.ca
Dealers join the CAVI to protect your rights - and keep the JDM's coming- www.CAVI.ca
lshobie is online now   Reply With Quote
Old 10-28-07, 04:17 PM   #32
83bj60's Avatar
I'm still too busy and have tons of other things to do first but you sure make it very tempting for me to let everything go and just get to your place and get things done there...
91HDJ81VX (The Beast), 4B JDM, since Nov 06
83BJ60 (The Old Faithful), Still Running, Gone to a New Home
83BJ60 (Rusty but Trusty), Dec 90 - July 98, Parted Out
76FJ40 (Big Red), April 87 - July 93
83bj60 is offline   Reply With Quote
Old 10-28-07, 07:35 PM   #33
Originally Posted by 83bj60 View Post
wrong angle, you got to crawl further down and look at the cross member above the shocks...
Here it is...
Nope, the frame on the BJ-7x is different, there is no channel cross member for the pipe top go over.
Besides the problem with the pipe in the picture is not the diameter, it's the kink that nearly closes the pipe off. Nothing works right if it's not maintained.
Old 10-29-07, 12:16 AM   #34
83bj60's Avatar
That kink is common to all HDJ81s AFAIK. Martin White had the exact same problem, and was told by ATEB they were all like that. Nothing to do with lack of maintenance or some other sort of problem, it's apparently by design.
In any case redoing the exhaust solves the problem. Why am I not surprised...
Old 10-29-07, 03:39 PM   #35
That kink is common to all HDJ81s AFAIK. Martin White had the exact same problem, and was told by ATEB they were all like that. Nothing to do with lack of maintenance or some other sort of problem, it's apparently by design..
in the picture posted the exhaust pipe is clearly KINKED about half closed, and I doubt if it comes from Toyota like that. It comes with a smooth bend, but it's obvious in the pic that someone backed up against something and kinked the pipe, then part of the end rusted of. Clearly a maintenance issue. The design isn't all that great, I'll admit, and I'm glad they didn't do that design on the 7xs.
Old 10-29-07, 05:34 PM   #36
83bj60's Avatar
No kidding John, I just simply can't find the link to this. I'm am sure Martin White reported ATEB as saying it was a factory restriction.
I know it sounds weird, but I remember that very clearly. Something to do with limiting torque.
Old 10-29-07, 06:57 PM   #37
Whats the correct model number for these new cruisers? At a dealer I saw one with stickers on the windscreen calling it a 79 Series (however I had a 79 series for work and it was the old shape and 6cyl turbo)
This thread is titled 71 Series, but I have a brochure from Toyota naming it the 70 Series (however the swb isnt featured, only the tryaback, wagon and troopy)
Sean
BiG BoB is offline   Reply With Quote
Old 10-29-07, 08:51 PM   #38
Diesel for blood
roscoFJ73's Avatar
Sean
Only a handfull of markets still get a SWB 70 or 71 series. The one signifies a turbo version in some years and in others it means coil front and the new one has both,well so did the previous model.
The ones pictured above are ME models and not usually diesel,maybe they are dropping the old 1FZ FE.
Makes me wonder if the 7* series will ever see a V8 petrol
The V8 cab chassis is still a 79 series although the dealers are referring to all the new V8 models as the 70 or 79 series depending on who is talking.
(there is no longer a body plate with all the details on the firewall)
Much of the confusion is caused by the fact that since 1984 all the numbers from 70-79 have been used up.
They should have released the new models with a alphabetical suffix to signify it is from new generation of 7* series.
Make the most of them as I believe this will be the last model. With OHS laws becoming more stringent, it will probably be compulsory to have airbags and Toyota have already stated they cannot be fitted to a 7* series.
FJ73+1HZ Diesel NEW GEARBOX
33 in BFG A/T
Volvo 740 GL
Old 10-30-07, 11:04 PM   #39
Personally I cant see them dropping the line completley, there is just too much need for vehicles of this sort... Nissan have no problems fitting airbags to the Patrol, and Toyota fit them to the 100... Its just a case of a major redesign to incorporate airbags.
I know where I work, there is no other option for what we do, other than a toyota troopy, without heavily customising another full chassis 4wd (deffender/patrol)
Sean
Old 10-31-07, 05:12 AM   #40
crushers's Avatar
Originally Posted by bigbrowndog View Post
how dare you taunt us like this...you are just a mean big brown dog...
LOL!!
contact me at wayne@crushersrule.com
Wayne
Owen Sound Ontario
http://www.ivoac.ca separating the rumours from the truth. join today
www.CAVI.ca Dealers join the CAVI to protect your rights
crushers is online now   Reply With Quote
Old 10-31-07, 05:13 AM   #41
crushers's Avatar
Originally Posted by Jim_Hbar View Post
By just removing the resonator on my HZJ73, and replacing with 2 1/2" straight pipe, I gained 3 seconds 0 to 100 km/h. Prior to that change, the engine did not want to pull above 3000 rpm..
good to know...
Wayne
Owen Sound Ontario
Old 10-31-07, 05:28 AM   #42
83bj60's Avatar
Would be nice to cut the resonator open to see what the restriction was!
Old 10-31-07, 05:55 AM   #43
Diesel for blood
roscoFJ73's Avatar
Sean
I dont think the end of the 7* series is imminent but it wont go on forever. By then there maybe something in Toyotas line up that can replace it.
33 in BFG A/T
Volvo 740 GL
Old 10-31-07, 06:06 AM   #44
v8 diesel shiver... you guys are excited about that?
1986 BJ70, 24v with a 3B
Eric Winkworth is offline   Reply With Quote
Old 10-31-07, 07:33 AM   #45
crushers's Avatar
you know what i like about that truck?
the side mount rear seats from the factory...cool!!
Wayne
Owen Sound Ontario
Old 11-01-07, 02:27 AM   #46
bigbrowndog's Avatar
LOL!!
LOL, Yep that's for sure. Another Hj47 ridden hard and put away wet.
Wonder if the mate will keep the new one as long as the HJ47.
bigbrowndog is offline   Reply With Quote
Old 11-01-07, 11:09 AM   #47
Tapage's Avatar
Just wondering if your mate don't want to adopt me .?
I could help driving the new cruiser .
HJ-60 2H-T Intercooler Tencha
Originally Posted by pygpen
Old 11-01-07, 11:25 AM   #48
crushers's Avatar
and here i was hoping you would adopt me to take pics of all those panama ladies...your picture finger must be getting tired by now...
Wayne
Owen Sound Ontario
Old 11-01-07, 12:04 PM   #49
I'm flagging this as porn!!!!!
Oh wait this aint CraigsList,
tntoyota is offline   Reply With Quote
Old 01-06-08, 03:04 AM   #50
where they sell this kind of 70series v8d with lhd
sager is offline   Reply With Quote
Old 01-06-08, 07:59 AM   #51
83bj60's Avatar
Probably everywhere EXCEPT North America
Old 01-10-08, 03:25 PM   #52
Tapage's Avatar
We haven't 'em " yet " .. actually only a set of 15 200 Series with the new V8 engine, maybe with luck next year catch some on those 70 series V8
Old 01-13-08, 03:36 AM   #53
i just want to know why we dont get the shorty in oz...
Thommo 73 is offline   Reply With Quote
Old 01-14-08, 01:40 PM   #54
Tapage's Avatar
Not .. ? how that impress me .. I hotught always OZ get all better stuff in Cruiser world ..
Old 01-16-08, 03:54 AM   #55
most of toyotas stuff yeah, but toyota oz carnt see the market for a shorty i can.......
we get every other 70 just no shortys or middys (the only ones i want!)
we didnt even get the coil sprung middys! in the 90's
Old 01-16-08, 11:29 PM   #56
Diesel for blood
roscoFJ73's Avatar
Because everyone looked at the SWB Patrols and the Pajeros and thought the Landcruiser SWB and MWB overpriced by $5-$10K.
The MWB in 1988 was $33K,about the same price as a 380 SEL Mercedes in oz and the dollar was worth something like 50c USD
When they are in the showroom all shiny and smelling so good ,no one looks underneath to see what they are made of,no one looks 10-20 years down the track.
33 in BFG A/T
Volvo 740 GL
Old 01-20-08, 03:20 AM   #57
id love to have a v8 shorty here in aus
75 Series Ute and 95 Series Prado
Prado:http://www.4wdmonthly.com.au/forum/s...ad.php?t=31767
75series:http://www.4wdmonthly.com.au/forum/f...83/#post498525
beast2h is offline   Reply With Quote
Old 01-23-08, 01:37 PM   #58
Hi Il live in the uae .
Do you sell these.
How much are they ?
Any other models coming in saaoudi ofthe 70 series in V8 diesel.
Regards,
Haya
