70-Series Tech Tech assistance for the 70- thru 79-series Land Cruisers -- BJ74.com HZJ75.com
Old 07-25-07, 07:27 AM   #1 (permalink)
Rookie
Help with my LJ78 prado
Hi folks i,m new to this site and need some urgent help or advise.I recently bought my first landcruiser lj78 92 2.4 td efi lwb prado 100,00 miles which i bought as a non runner and was told it needed a new ecu so i bought a ecu fitted it and after a few turns it started with a bit of black smoke but it had been sitting for a year.Then it stopped again and i can,t get it started again.It has had the air filter fuel filter and 2 glow plugs replaced but still won,t start.Was told by the last owner it would shudder and produce black smoke whilst driving after a few pumps on the accelerator it would drive normally.Then it completely stopped tried to start it again for 10 mins and it started then ran fine for a couple of days then stopped again and hasn,t started since these are the symptoms i was told by last owner just hope someone reconises these symtoms.I know the cylinder head was replaced at 87000miles.The last owner said the fuel pump had been checked and was working fine but cant be sure about that.Any advise appreciated as i have limited mechanical skills as far as deisels go.
stevemilne750 is offline   Reply With Quote
Old 07-25-07, 08:58 AM   #2 (permalink)
crushers's Avatar
did you change the fuel filter?
does it run while you are rapidly hand pumping the pump?
did you crack the injector lines to see if there was fuel coming out?
we are all given sh*t in life, but some of us learn to turn it into fertilizer and grow from it, and some us try to fling it on others like monkeys.
the start to the above truck here: http://forum.ih8mud.com/70-series-te...uck-build.html
Wayne in Ontario
www.luxuryimports.ca
Old 07-25-07, 12:08 PM   #3 (permalink)
Rookie
Yeah the fuel filter has been replaced.Havent tried hand pumping the pump should i do this while someone else turns it over.Not to good with deisels so are the injector lines the lines that go into the glow plugs.If they are there is fuel going to them.
Sponsor 07-25-07, 06:05 PM
Sponsored Link
Advertisement
Old 07-25-07, 06:05 PM   #4 (permalink)
crushers's Avatar
the injector lines go to the injectors, a 17 mm wrench and crack the lines a 1/2 turn, crank over the engine and see if deisel spurts out...
Wayne in Ontario
