What ARB locker to rear?
What ARB locker goes to rear axle to LJ70 -90 and newer?
I´ve been telled that theres 8.9" rear diff and RD33 would fit, but ain´t RD33 to 9.5" diffs? At front I´ve got RD23, works fine. But now I should to rear and I liked to be sure for what am I buying. |
wow you locked the front first amazing,i have a90 lj78 i believe that the rear is
an 8 inch . i think it is the same as the front maybe the RD23 will work, there very little info on the lj axles aaron |
retired maths geek huh
If memory serves me right you need a RD08, the LSD carrier on an LJ70 takes the same bearings as the "V6" or "turbo" trucks.
__________________ '71MS75 threw a rod '74MS75 seized engine '75BJ40 farm tractor type R '79FJ55 rostig schwein '80BJ40 never ending resto '88LN65 frame-off '90HDJ80 the bear '92LN85 turbo ute |
#4 | ||
Havent even cracked any joints , theres bigger joints than at older LJ, allmost big as HDJ joints. Here I wondered will it break but luckyly it didn´t ![]() They dont even knock at all. |
nope, just found the bill and it was an RD23
#7 | |
[quote=Axel Von Gardan;2040951]
http://www.arbusa.com/alac/alsp/0-00.pdf __________________ '71MS75 threw a rod '74MS75 seized engine '75BJ40 farm tractor type R '79FJ55 rostig schwein '80BJ40 never ending resto '88LN65 frame-off '90HDJ80 the bear '92LN85 turbo ute |
You need the rd23
LJ RJ 70 use RD 23
BJ HJ HZJ 70 RD 33 __________________ JTS Diff Parts & Accessories ih8mud sponsor 866-349-6801 info@justdifferentials.com www.justdifferentials.com 99 uzj100 35's, uniball a-arms, fox shocks, 4.88, lockers, bullbar, drawers & more. |
Just a Note .!
Both axles are 8" and 1.31" axle diam 30 splines .. In my case my 3rd member are 8 7/8 = 9.5" with the same axles and splines. |
#10 |
ARB Air Lockers
Please note the following information directly from ARB:
http://http://www.arbusa.com/USA-Veh...r-70-73-74.pdf . There youll find the complete application for 70 series Land Cruiser including OME and snorkels. __________________ HZJ71 from Costa Rica |
#12 |
I can send it to you, just let me know how.
#13 |
Today I got hangover, so I checked that what differential there is, and YES, there this 10 bolt 8" diff.
#14 |
yes rd23
yes rd23. How was it underneath there w/ that hangover?
#16 |
#17 |
#18 |
Hi,
Out of interest I have a KZJ70, probably the same axles as the LJ70, did yours have an LSD fitted in the rear? I am looking at putting a arb in the rear, suppose this is the RD132 as well? Any comments to help on my install would be much apreciated? Thanks Martin. |
#19 |
Martin,
I also ride a KZJ70 and will install RD132 in both front and rear. I have checked that RD132 is the thing we need for out trucks: 8" 10 bolt rear diff and high pinion 8" 10 bolt front diff. |
#20 |
Hi,
Thanks for the reply, only just seen it. I will go with RD132, getting some knoks and chings from the back end so may as well swap it out for a locker. |
#21 |
Same locker for low and hi pinion . ?
#22 |
Tapage:
yes, the diff size is the same - different are the ring+pinion wheels (high+reverse cut) |
#23 |
Interesting .. thanks !
#24 |
Yes they are the same for high and low pinion, but only in light duty (kzj, lj, rj, etc)
