#211 |
Now this proyect start moving faster .. !
#212 |
yeah i hope it will tap.
hey all, here is my 5th stud conversion... Pritty basic but should give me some more strength. If i break these ill buy a pair of 6shooters. __________________ Lock, Stomp and Steer, No Fear
#213 |
Hey all,
Im at Tafe for the next few weeks so i dont have access to the workshop to do anything. I do have a sort of garage come workshop set up at home to continue though. Heres my start to the front hub rebuild. Spindles are ok, only minor wear on the seal area so i cleaned them up for reuse. Hubs are painted and prepped. Highsteer is prepped for install (buffed off the stoopid red paint on the mating surface...) Hubs are almost together. Ive got to buy some new thrust bushes for the inside of the spindle and possibly some new lower kingpins as the last people to work on this truck were realy rough and gouged into everything (as you can see from the above swivel housing pix) Cheers fellas __________________ Lock, Stomp and Steer, No Fear
#214 |
Flame on suckers
![]() My Max Width __________________ Lock, Stomp and Steer, No Fear
#215 |
Nice!!!
__________________ LULO Adventure ![]() TLC LJ-70`88 (Soft Top) A Coruña - España (Spain) |
#216 |
![]() ![]() hehe cant wait __________________ Lock, Stomp and Steer, No Fear
#217 |
money money money, i have no money, i wish i were a rich man yeah...
haha im now poorer than a bum at Christmas... But i had to do it... ![]() __________________ Lock, Stomp and Steer, No Fear
#218 | |
Diesel for blood
![]() You really are a big spender
__________________ HZJ75 cab chassis 95 model ,stocker FJ73+1HZ Diesel NEW GEARBOX 1HZ =same power as 3F with 30% better fuel economy 2in Dobinsons lift.Powerdown adj shocks 33 in BFG A/T HJ61 with slidin windas regrettfully SOLD:(Volvo 740 GL |
#219 |
PFFFT
Super cheap my ass.... This is an industrial welder made by lincolin. It dont get a great deal better for the $$$ __________________ Lock, Stomp and Steer, No Fear
#220 |
Anyway....
GOT BLING? Turned out so awesome! __________________ Lock, Stomp and Steer, No Fear
#221 |
Update:
Had a prick of a day...Ive got a killer cold, im dodging rain all day and getting the wrong parts from Toyota... that i cant return as they have a non return policy... PRICKS... Anyhoo i managed to fit my knuckles back onto the housing with 5* of Castor, welded on my u bolt receivers (not yet finished) i put together the passenger side swivel housing and high steer, made a spacer ring out of the old backing plate so as to do away with the backing plates all together. I put the center in an did a few other things... I wet and cold... but happy as i have made some more progress... __________________ Lock, Stomp and Steer, No Fear
#222 |
Sneeky update:
Im supposed to be at Tafe but i have finished the block already... Tafe thinks im at work, work thinks im at tafe! Perfect! Got the other side finished, got the highsteer in. Got a load more stuff from toyota to finish it. Tomorrows agenda: Fit Longies and axles, fit hubs and put wheels on for a wank factor shot. Get some bundy tube (break line and fuel line) from ABS in ozzie park here, run the new break lines and fuel lines. Hehe wish me luck! Oh and some update pix __________________ Lock, Stomp and Steer, No Fear
#223 |
Diesel for blood
Its coming along
but those fishplates need to be bigger. I can see ongoing problems with ubolts coming loose.Another way would be to have some custom u bolts go around the axle and held there with some guides __________________ HZJ75 cab chassis 95 model ,stocker FJ73+1HZ Diesel NEW GEARBOX 1HZ =same power as 3F with 30% better fuel economy 2in Dobinsons lift.Powerdown adj shocks 33 in BFG A/T HJ61 with slidin windas regrettfully SOLD:(Volvo 740 GL |
#224 |
your right and ive been thinking the same.
If i had my time again i would have made the spring perch the lower ubolt holders.. anyhow i need custom ubolts neway as the thread dont go down far enough. __________________ Lock, Stomp and Steer, No Fear
#225 |
Well what do you know... She does hold her own weight!
For the first time in 2 years, she can hold herself up! Check out that Approach angle ![]() And the pix: Maby a sticker that says caution over width is needed? __________________ Lock, Stomp and Steer, No Fear
#226 |
WOW!!! excellent job mate!
...... i hope so in the future you have more free-time to do the same job with my front axle hahahahaaaa... ![]() mate!
#227 |
lol maby!
Thanx matey! __________________ Lock, Stomp and Steer, No Fear
#228 |
Pure bling bling with those crome knukles dude !
#229 |
Diesel for blood
Zoltan,you are going to clean the norwest dust off that engine,are'nt you??
#230 |
you betcha
As soon as its all plumbed up shes getting a birthday too
#231 |
Id just like to point out ,
198cm outside of tyre to outside of tyre ![]() thats about 6'5" LOL __________________ Lock, Stomp and Steer, No Fear
#232 |
very,very good job
#233 |
cheers buddy
#234 |
Hey all!
I got some good progress shots. Almost time to put the cab back on!!! Removed the rear backing plates and cleaned/painted the hub assembly. The 10mm x4 dowel conversion Completed Hubs Fun Time lol __________________ Lock, Stomp and Steer, No Fear
#235 |
Small update so you all dont think im doing nothing.
Took a couple o pix too Cheers fellas __________________ Lock, Stomp and Steer, No Fear
#236 |
looking real good, keep it up...
__________________ pulling this info out of my ass so take it with a pound of salt "People are poor because they don't spend money wisely, tough sh!t !!! " John Galt 09/22/08 Wayne Owen Sound Ontario http://www.ivoac.ca separating the rumours from the truth. join today |
#237 | |
retired maths geek huh
holy spacers and scrub radius ![]() there's no way I would run such a setup myself. I hope it works OK for you anyway
__________________ '71MS75 threw a rod '74MS75 seized engine '75BJ40 farm tractor type R '79FJ55 rostig schwein '80BJ40 never ending resto '88LN65 frame-off '90HDJ80 the bear '92LN85 turbo ute |
#238 |
hehe i like to do things a little differently
But yeah i would like to change to 80s diffs or dana 60s __________________ Lock, Stomp and Steer, No Fear
#239 |
Diesel for blood
