Go Back   IH8MUD™ Forums > Toyota Tech Forums > 70-Series Tech
Old 09-06-07, 11:27 AM   #151
Tapage's Avatar
Originally Posted by Z()LTAN View Post
ive never used them like this..
but my mate has them on his lux, and it flexes up orsmly!
Lets see what happens in yours .. and sure poser flex pics are required
HJ-60 2H-T Intercooler Tencha
Originally Posted by pygpen
Tapage is online now   Reply With Quote
Old 09-14-07, 04:17 AM   #152
Z()LTAN's Avatar
hey guys,
im going to try and sort out the front diff tomorrow, get it under the springs at the right angle and all that.
I got the old engine and box back into the w/s so i can get all the angles right...
i towed it with the dunnydoor in the wet and subsequently rear ended someone (stoopid me) wasnt any damage but ill still be up for a bit of $$ ahh well ill update saturday night
laters
Lock, Stomp and Steer, No Fear
Z()LTAN is offline   Reply With Quote
Old 09-15-07, 02:01 AM   #153
Z()LTAN's Avatar
Old 09-15-07, 02:02 AM   #154
Z()LTAN's Avatar
Hi guys heres a little update, i didnt get much done as i was helping a mate sort his car out (he bent his front diff).
Anyway i managed to get the old block and gearbox/transfer siting in for the output flange angles.
I was running out of time so i did a quick bodjy job and put the front diff in SOA just so it can be wheeled around easier now that the engine is in.
Hehe a super quick 10 min front SOA comprising of only 2 holes hahaaha (remember its super temporary!)
Old 09-20-07, 08:18 AM   #155
Z()LTAN's Avatar
Got some new stuff comin my way now
Chyro Longfeild CVs
Chryo Hub gears
4.88 chryo ring and pinion (front and rear)
Front and rear full Detroit lockers with solid inners
Fully rebuilt into my old housings with new bearings and seals
High steer with chrome molly rock rods.
Thats another whack to the budget..
Old 09-20-07, 06:48 PM   #156
Diesel for blood
roscoFJ73's Avatar
Chyro Longfeild CVs
Chryo Hub gears
Some more movement. Your going to be stuck in there during summer if you dont go like crazy
Is that the old 1HZ that Kon was supposed to get?
What did Westralia springs charge for the leaf packs?
FJ73+1HZ Diesel NEW GEARBOX
33 in BFG A/T
Volvo 740 GL
roscoFJ73 is online now   Reply With Quote
Old 09-21-07, 03:36 AM   #157
Z()LTAN's Avatar
Ima goin CRAZY NOW!
Yeah but kon wants an 80 series now so its basically spare parts now
Westralia wacked me $1200 for 2x fronts 2x rears and all bushes
Old 09-22-07, 02:26 AM   #158
Z()LTAN's Avatar
Ive just completed the hardest part of a spring over for a 75 series.
That bloody square banjo housing... it almost broke me, but i won in the end
Getting everything absolutely perfect to the mm and deg so i dont crab down the road.
not easy...
Old 09-22-07, 02:27 AM   #159
Z()LTAN's Avatar
Old 09-22-07, 05:05 AM   #160
Diesel for blood
roscoFJ73's Avatar
Are you happy with that shackle angle? Looks like it should be more vertical to me and when you load some weight on it ,it will be worse.
With the hi steer,can you still use the old pitman arm?
33 in BFG A/T
Volvo 740 GL
Old 09-22-07, 06:32 AM   #161
Tapage's Avatar
Ditto ... I thought ou need to move it 2" backward..
Old 09-22-07, 07:54 PM   #162
Z()LTAN's Avatar
im changing all the shackle angles when i weight the chassis
Old 10-06-07, 08:04 AM   #163
Z()LTAN's Avatar
Not a big update but an update never the less...
I got the Front and Rear diffs in their perfect positions.
Ive taken the centers out to be rebuilt with 4.88s and detroit lockers
Next i have to laminate and truss the housings, make new ubolt flip plates, try and sort out the front and rear shock positions, clean everything up for painting and then squirt some paint on her...
Im sure there is alot more i have forgotten to do but eh....
Old 10-12-07, 03:01 AM   #164
Z()LTAN's Avatar
my new $10 shock hoops
Old 10-13-07, 01:58 AM   #165
Z()LTAN's Avatar
Its Saturday so another update is due.
Ive made some new longer anti inversion shackles, they look very similar to a certain superior shackle
Welded the perches on
I trussed the front diff and cut the knuckles for the C&T later on
Extended the breather through the truss (ill cut it flush and tap a fitting into it later)
Tested my departure angle (with small tires mind you...)
Removed the tranni and transfer and sent out for exchange.
Old 10-13-07, 01:58 AM   #166
Z()LTAN's Avatar
Old 10-22-07, 05:46 AM   #167
Z()LTAN's Avatar
Alrighty then another update.
I don't have a Digital camera at the moment so i have no pix but this is what ive done.
I stripped the chassis bare
Spent hours prepping to paint
Painted 2 coats of 2 pack etching primer
Waited a day and painted 2 coats of High gloss 2 pack black
Painted all the odd bits like the shackles and fuel tank and brackets ive made.
Trussed the rear diff housing
Made u bolt flip plates
Started making sliders/sidesteps
Bought and picked up my new gearbox and transfer with chrome molly idler shafts
Somewhere in amongst all that i fitted a 2" body lift and 3" coil lift to my mates shorty patrol.
Hopefully get pix later this week
Cheers
Old 10-23-07, 05:02 AM   #168
Z()LTAN's Avatar
As Promised i have the pix...
They are super ghey res but you will get the drift
It only shows the undercoat, i have no pix of the top coat
Old 10-23-07, 05:03 AM   #169
Z()LTAN's Avatar
This is my rear diff truss and the start of my sliders
Old 10-23-07, 11:47 AM   #170
Tapage's Avatar
Hey dude .. thanks for re size the pics before posting here !
Old 10-24-07, 08:18 AM   #171
Z()LTAN's Avatar
too small are they ? :P
Old 11-01-07, 04:34 AM   #172
Z()LTAN's Avatar
I just spent another $3500
I have
Histeer
4140 cryo treated 30 spline lonfeilds
4140 cryo treated 30 spline hub gears
Solid Chrome molly drag link and tierod
Heavy duty RTC
I also gots PIX!
Let the pic bashing begin!
My new chassis
My new gearbox, transfer and bell housing
Old 11-01-07, 04:41 AM   #173
Z()LTAN's Avatar
Old 11-05-07, 01:45 AM   #174
Z()LTAN's Avatar
ahh the cvs are actually 300mm bell 4340 cvs :P
Even better
Old 11-12-07, 03:17 AM   #175
Z()LTAN's Avatar
small update..
I got a new gearstick and low range stick with linkages from a wrecker coz mine were all bent when the old box nose dived off the pallet it was on.
I stripped them all down, sand blasted it all, got it all painted 2pack gloss black
Got new bushes pins and cups from Toyota (grand total of $14 for the lot)
Now shes gonna feel totally new!
Old 11-30-07, 12:51 AM   #176
Z()LTAN's Avatar
Hey all its been a while and ive done very little...
But i have bought alot of stuff to start my new workshop up
I have finished my gearsticks though, they are lengthened and distorted to suit the 2" body lift.
Cheers fellas
Old 12-04-07, 08:19 PM   #177
Dog is my co-pilot.
Josie'sLandCruiser's Avatar
TLCA# 6446
Hi All:
"Zoltan," incredible thread! Thanks for sharing so much of your HZJ75 SOA build with us!
Good luck with the project!
Regards,
Alan
www.seattlecruiserheads.com
Josie'sLandCruiser is offline   Reply With Quote
Old 12-05-07, 02:45 AM   #178
