04-03-07, 07:09 AM
#31 (permalink)
yeah? whys that?
ive seen lifted springs flex super fine... and on a lux too
i understand if you get heavy spings they dont flex well, but they dont have to be heavy, i can afford some droop and go medium.
I have a set of stock parabolics, but they are super sagged... Could try to reset them and give them a go too
I believe that a lifted sping is just a longer spring thats been set at a higher arc and still gives same eye - eye distance...
so a lifted is the same as a stock but longer and higher?
ehh
Lock, Stomp and Steer, No Fear
04-03-07, 11:16 AM
#32 (permalink)
i want you to think this through, which will flex better?
a flat spring with no arch or a spring with arch fighting the upwards movement?i old go with the parabolics for perfleax...
cheers
04-03-07, 12:28 PM
#33 (permalink)
retired maths geek huh
Originally Posted by Z()LTAN
people its only gonna be SOA with lifted springs and drop shackles... i have no idea how tall its gonna be until i do it.
Don't be offended but I think you have it backwards, Myself I would decide how much lift I need/want and build accordingly ?
'71MS75 5cyl crown coupe '74MS75 6cyl crown coupe '74MS75 4cyl crown coupe '75BJ40 DD '79FJ55 rostig schwein '80BJ40 never ending resto '82BJ45 project troopie 50% '83LN46 no engine '84BJ45 project troopie 50% '88LN65 getting closer '90HDJ80 the bear '92LN85 turbo ute '96LN108 rustbucket
Originally Posted by LandCruiserPhil
there are a lot more single women available then nice low mileage Land Cruisers.
04-04-07, 01:04 AM
#34 (permalink)
wheres you sence of humour?????
a white Landcruiser - now with Track Tactical!
04-04-07, 04:02 AM
#35 (permalink)
Problem is, i haven't lifted like this before, and don't know what its going to do.
I know how i want to lift it, and thats what im going to do, how it turns out, is how its gonna be.
Now back to the car
Question
Is it possible to reset parabolic springs?
I have the engine, (pix lata)
New 1HZ out of an 06 100 series.
Now do i need the complete wiring harness or do i only need the harness downstream from the computer?
Will the 75 series harness work?
Do i need the computer from the 100s or from a 79s with the same engine!?
So many questions!
04-04-07, 04:33 AM
#36 (permalink)
Stand and deliver
Now back to the car
Question
So many questions!
The springs will be the make or break issue in the SOA. I would forget the notion of using reset worn out springs.
I would see Dean at Malaga Suspension or maybe West Coast Springs in Ashfield and get some purpose built springs suitable for SOA.
I think the high arched springs look crap and for the reasons Crushers outlined will not flex too well.SEE BELOW(not too bad but could be a little lower,I think its in Darwin)
The SOA with flattish springs will still have a good sized lift .
I would leave the double hinged shackles alone until the SOA is complete and fully test driven
You do know the cops will put a SOA vehicle off the road as soon as they see it?
The computer doesnt do much if anything on the 1HZ as far as I know.
The cruisers with the 1HD FTE do have some(LOTS) electronics.
For your purposes I would study the electrical schematic in the FSM and get the engine set up like a early 90s 1HZ with just one wire to the fuel cut solenoid.
Mr Rentokill
FJ73+1HZ Diesel NEW GEARBOX
33 in BFG A/T
HJ61 with slidin windas  regrettfully SOLD:(
Holden Commodore V6
Honda XR650L
04-04-07, 05:01 AM
#37 (permalink)
Money is a bit tight, as im only an apprentice, so custom springs were more or less out of the question, but i will inquire about them, as work deals with west coast springs fairly often.
i will be running all stock suspension after the SOA to make sure all is well then moding yet again.
Im not rlly worried about cops, as i can get it certified, but if it gets yellowed its ok with me
So all the electric governors are only for fuel shutoff and fuel compensation? and not injection in any kind?
Do i need a computer at all?
Tanx for the speedy reply!
04-04-07, 05:36 AM
#38 (permalink)
mate who gave u the false impression that you can get a soa certified?
 85 fj73 with a lil offroad pimpin
04-04-07, 05:41 AM
#39 (permalink)
point me out where it says "NO SOA ON ANY VEHICLE ALLOWED" in the regulations... and ill listen to you..
Having a mate who is soon to be an mechanical engineer is great!
yes.. kon... im talking about you.... i have a favor to ask when your out of your time...
But you prolly already know this rofl
04-04-07, 06:38 AM
#40 (permalink)
spring over give what between6-7" lift, 2" lift in total is the regs for w.a un engineered and even with engineering lane change tests the max is like 150mm, so with the spring over your right on the max lift then what size tyres are u planning on running?
04-04-07, 07:01 AM
#41 (permalink)
Stand and deliver
Yes Zoltan 50 mm is the max. Now the cops are fairly lenient on this and many get away with 100 mm but I think your lift will be like kicking a rottweiller in the balls when the cops see it
Some say it is still theoretically possible to have a SOA but with strict engineering supervision,eg by increasing the width of the axles to suit the height $$$
The engineering supervision is ongoing during the lift meaning stages of inspections
I would consult someone 1st to see what it entails before you start the mods.
Im sure WC springs could give you some advice as they get updates from the traffic branch
Mr Rentokill
33 in BFG A/T
Holden Commodore V6
Honda XR650L
04-04-07, 07:11 AM
#42 (permalink)
Stand and deliver
I think it may also look at the coolant temp for the glow plug system.
If it has an immobilser it will be connected to the computer.
The tacho may also go through the computer.
Also the aircon fast idle as it replaced the vacuum system.
Not sure about the fuel compensation,do you mean the HAC?
If you have a suitable earlier type inj pump, use that.
If the glow system is different ,use a manual type.
When I did my swap I went into car yards and looked at 1HZ engines and compared the years. There is not much differnce
Mr Rentokill
33 in BFG A/T
Holden Commodore V6
Honda XR650L
04-21-07, 07:34 AM
#44 (permalink)
04-21-07, 07:38 AM
#45 (permalink)
Former Lifer
looking good
04-21-07, 10:16 AM
#46 (permalink)
damn, i got me a set of those turbine rims and have wondered how they would look on a truck...i like it...a lot
04-21-07, 10:15 PM
#47 (permalink)
Turbo Diesel Lover
This HZ come from a auto tranny Cruiser .. ?
HJ-60 2H-T Intercooled Tencha
Originally Posted by crushers
04-21-07, 10:20 PM
#48 (permalink)
nope, manual 105 series
04-22-07, 03:38 AM
#49 (permalink)
Turbo Diesel Lover
The denso module ( black one with the blue letters ) looks like my 1HD-T with A442 have over the Injection pump ..
04-22-07, 03:48 AM
#50 (permalink)
what do you meen by that? they use the same injector pumps dont they?
04-22-07, 04:00 AM
#51 (permalink)
Stand and deliver
I love a HZJ75 and 1HZ build up thread  That body and chassis is looking extremely rust free and is a great start.
Zoltan ,do you have any good 750x16 tyres for sale and any 1HZ parts?
Im after a flywheel and the plate that goes between a gearbox and engine or maybe a complete dead engine if the crank is good
Mr Rentokill
33 in BFG A/T
Holden Commodore V6
Honda XR650L
04-22-07, 04:02 AM
#52 (permalink)
Stand and deliver
NAH and the 1hd ft and 1hd fte are different again.
Mr Rentokill
33 in BFG A/T
Holden Commodore V6
Honda XR650L
04-22-07, 04:11 AM
#53 (permalink)
i have a 1hz block minus head spare, but im giving that to a friend, still dont know if he wants it though... Adam if you read this. Let me know
04-24-07, 05:49 AM
#54 (permalink)
HELL YES!!!
please!!! I beg you!!!
i will pay cash and/or jacks and/or my valuable time!!
my ute will be ready to take over the pits by the end of this weekend, so i'll have a car to drive.. you should hear it without the muffler! hehehe, so loud!
it'll be weird driving a fourby with power!
four cylinders just doesn't cut it!
i swear its losing power by the day!! dont get me wrong, i love my BJ60! for city driving its awesome, relaxing and economical! taking it offroad is almost embarrasing.
glad to see ya got the 95 running...
atleast now you've got a fourby!! taken it out for a drive yet?
Mine:
'83 BJ61
'84 FJ45
Dad's:
'82 FJ40LX
04-24-07, 05:56 AM
#55 (permalink)
btw what other parts is it missing? a mate from uni has a bunch of parts leftover from his projects. starter, alternator etc...
this is a list of his Toyotas alone:
HZJ80 with 6.5chev diesel
HDJ80 with factory lockers
BJ70 with a 1HZ
+ a 3B and a partial 1HZ
so he has too many toys!
Mine:
'83 BJ61
'84 FJ45
Dad's:
'82 FJ40LX
04-24-07, 09:16 AM
#56 (permalink)
Turbo Diesel Lover
naaaahhh just making apointment to the denso module .. I was thinking it only comes with Auto trannys ..
04-24-07, 06:13 PM
#57 (permalink)
No worrries
04-24-07, 06:14 PM
#58 (permalink)
Yeah kontoolas your gonna need a fair bit im afraid, so if you can get some bits cheap from ya mate you should do so. When i take it out, ill do an inventory as to whats missing and whats there
04-27-07, 03:27 AM
#59 (permalink)
Just a little teaser
Whats that in the boot of my car?
Custom parabolics are they?
 Stay tuned
04-27-07, 08:11 AM
#60 (permalink)
Turbo Diesel Lover
Mate .. you have the responsability to make a test ( take a lots of pics ) and let us know your feedback about parabolic setup ..
