04-29-07, 10:48 PM
#91 (permalink)
I picked up one of Marlin's knuckle ball kits and decided to put it on since It's so cheap and I'm welding anyway. The top gusset becomes the shock mount.
04-29-07, 11:06 PM
#92 (permalink)
Kuddos Bruce, not sure if its been done before, but like anything it may have been, just never seen it on the net.
Nice fab work.
Rob
Come and visit us in Duncan, Vancouver Island, BC
www.raddcruisers.ca
Monday - Friday 08:00 - 17:00
04-29-07, 11:10 PM
#93 (permalink)
Hey Bruce, not doing a cut & turn on that housing?
...and the Fj45 is still waiting for Lowenbrau's attention....
1989 BJ74 LX - Extreme Valve body, Mark's gears, factory winch, custom 3" OME lift, 24V Warn VTC Compressor
1987 HJ61 VX 5spd - loaded - daily driver
1981 BJ42 - ARBs, Warns, oba, ps, h55f, hws, soa
1990 HZJ73 ZX - PTO winch, lockers, 68k Kms
04-29-07, 11:18 PM
#94 (permalink)
Nice fab work.
Rob
Yeah, Rob I'm not the first guy to put 60 axles under a 70 or 40 but I have no idea how they did it. This is my idea of how to keep it as low as possible.
04-29-07, 11:22 PM
#95 (permalink)
I nearly started turning the housing today but decided to try it as-is first. Peter managed to run his unturned by clearancing the u-joint a bit before he put the Toybox in. I plan to add a Toybox soon too so I'd be willing to run limiting straps until then if I need to.
The poor 45 is now outside for the first time in prolly 15 years. I *have* to build a garage for it.
04-30-07, 10:00 AM
#96 (permalink)
Looking good Bruce,
Do you think cutting the housing like that would work for a 40 series too, or would you have to cut further, making it impossible?
Cheers,
Deny
04-30-07, 10:08 AM
#97 (permalink)
I think you just need to go up more if you want to go in more.
05-01-07, 12:37 AM
#98 (permalink)
You might find it easier to use bolts instead of U-bolts and thread into your perch/plate, or add nuts where possible.
A C&T would give you the added benefit of a better caster angle.
05-13-07, 12:48 AM
#99 (permalink)
Got my new tires.
37 13.5r17 on F Gay Loser rims
05-13-07, 12:53 AM
#100 (permalink)
those wheels are sick!
05-13-07, 07:22 PM
#101 (permalink)
Originally Posted by lowenbrau
Got my new tires.
37 13.5r17 on F Gay Looser rims
If thoses go missing in the middle of the night, it wasn't me!
05-13-07, 09:07 PM
#102 (permalink)
Dog is my co-pilot.
Hi All:
Bruce, isn't the back spacing on those rims "wrong" for a solid front axle, disc brake Land Cruiser? Are you gonna run wheel spacers up front??
Regards,
Alan
www.seattlecruiserheads.com
"Cruiserdrew" wrote:
" The very worst thing you can to to a cruiser is half thought out mods that are underfunded and never quite get finished. Then you end up with hacked junk that doesn't work, and some future owner will curse you and all of your children."
05-14-07, 08:11 AM
#103 (permalink)
The 4.5" backspacing helps narrow the wide 60 series axles and limits some of the for and aft travel when turning. This lets me get away from too much fender trimming. Clearance to the TREs and calipers is helped by the 17 rim diameter. Therefor no wheel spacers are required (I hope)
05-14-07, 08:26 AM
#104 (permalink)
Turbo Diesel Lover
Nice tires dude .. but you are qa winner with those wheels ! are awesome !
HJ-60 2H-T Intercooled Tencha
Originally Posted by crushers
05-28-07, 11:09 AM
#105 (permalink)
How do like the fit on those rims Bruce? I just got an e-mail on the weekend from Toyo Canada that they will be offereing the 38x13.5 in a 17" rim. I am just a little concerned about the 7.5" FJ rim width.
Build is looking great.
Brad T
88 HJ61 " Marmaduke " 12H-T, A440, extreme valve body, PI, cable lockers, PTO winch, SOA, 2" body lift, FF, ARP studs, Longfields, 5.29s, 38x14.5R16 Toyo MTs...
78 BJ 40/42/60
05-28-07, 01:17 PM
#106 (permalink)
Update on the wheels. I got the axle together and tried a wheel on only to find the that front part of the luke arms (where the drag link connects) hits the tire. I need about 1/2" less BS. I pondered cutting and welding the arm but quickly decided that I didn't have access to a welder that I'd put up to that. I've been using a Miller 135 that is fine for the little stuff. In the end I ordered up a SKY mfg wide track kit and picked up some IFS hubs at the wrecker. I'll match it with some wheel spacers on the back for now and might try to widetrack the back using ifs hubs later in conjuction with a disc brake conversion.
Brad I think the FJC wheels are about an inch narrow. You can see a bit of crown in the tread. I'm going to run them anyway and will know after I put 10,000kms on in July whether it was a bad plan or not. I think I remember a vender that takes aluminum rims and machines them for a beadlock. I should look into that.
http://www.sky-manufacturing.com/
05-28-07, 01:48 PM
#107 (permalink)
That's good to know about the arms hitting.
I am running the Sky kit with Luke's arms so I am very interested in what you think of the fit of the rims when you get it done.
Have fun in Alaska, are you going for Vacation or Wheeling trip? We are hoping to get up there for Mark's Alaska Trek 08 with the HJ61.
Brad T
78 BJ 40/42/60
05-31-07, 08:57 AM
#108 (permalink)
export.japan4x4.com
Bruce, the 70 front shock lower mount goes to the rear of the spring plate. This sets the line of the shock quite a bit back from the centre line of the axle. With the knuckle gusset kit you are going to the centre line of the axle on the bottom of the shock. I assume you are also going to shift the axle a bit forward as the limit size for the stock location is about 35 inches in a SUA.
Is the SOA enough to permit you to run the tires and what do you feel about the non-vertical nature of the shock and the distortion of the upper mount that may result from it?
Care to comment?
Importer and distributor
05-31-07, 09:28 AM
#109 (permalink)
Care to comment?
You're right. The stock shock towers have to go. They are crappy anyway, I busted them off my BJ70. I'll make some hoops out of 1.5" tube. The axle is going forward about 2"
06-11-07, 08:53 AM
#110 (permalink)
What are you using for a bulb? I have been to two Trucklight dealers with no luck on a 24V bulb. Some how I left one witha set of $200 OFFROAD only no dot Hella lights. They are going back. Need bulbfor TL 27005.
Zach
1987 BJ74
06-12-07, 02:54 PM
#111 (permalink)
Zach
Gregg distributors ~$5 each.
06-17-07, 10:42 PM
#112 (permalink)
Update. I went to put the front axle assembly together and found out the knuckle kits I ordered don't have the metal wiper pieces so that's on hold till I get the parts from Toyota on Tues.
I decided to build a rear bumper instead.
I started with a piece of plate that I had bent up a few weeks ago for the purpose and went from there. I wanted it to be repeatable and bolt-on so I kept the end of frame intact and fastened the bumper using the pintle holes. I'll add some mounts to the frame with tow points later. I'm pretty happy with how its turning out.
06-17-07, 10:44 PM
#113 (permalink)
Added some tube to the ends. Looks a little funny with the tiny tires but that'll change soon.
06-18-07, 10:36 AM
#114 (permalink)
Interesting... I like how you recessed it to use the pintle. I might have to incorporate that in the one that is being made for me right now. I need to have a receiver on mine so I can use my bike rack and then attach the pintle for the trailer.
Thanks!
1964 FJ40 | 1966 M416 | 1976 FJ40 | 1985 BJ70 Volvo Power| 1997 FZJ80 | TDI commuter car
Rising Sun; Former CLCC
You should be able to delete your own thread. Communists abound
Real Change is here --> Cato Institute
06-18-07, 12:12 PM
#115 (permalink)
I like your rear window sticker.
Truck looks good too.
1988 BJ74 / Lots of goodies - Sold
1990 HDJ81 / Fully outfitted loaded beautiful truck - Rolled
1985 BJ60 / Beautiful Stock truck - Stolen
06-18-07, 01:21 PM
#116 (permalink)
bj74_guy?
Good news for your 70 series owning, bumper-needing can't weld nothing loser friends...
norm
Coastal Cruisers
'85 BJ70, '89 BJ74, '92 M101cdn
06-19-07, 09:19 AM
#117 (permalink)
After I saw that, the same thought was running through my mind but was being too polite to comment.
-kevin
If at first you don't succeed, then skydiving is probably not for you...
06-19-07, 09:32 AM
#118 (permalink)
Supporting Vendor
Gonna cut slots in the front and rear bumpers for the T of the highlift to fit in and make safe lifting on the trail?
06-20-07, 11:48 AM
#119 (permalink)
Norm , Kev
I thought I'd be able to design a kit of parts that folks could weld together themselves much like 4x4labs does with their 80 series bumpers. It seems to be getting a bit convoluted now so I'm not sure the kit will happen but who knows? As much as I wanted to completely rip off Luke's design, I just couldn't see 70 series guys wanting to hack out the end of their frames. That would be the way to do it and allow the use of a reciever.
Greg, I'll need some way to make the bumper work with the high lift, for sure. I'll probably holesaw a couple of circles in it. Cutting a "t" only works well on level ground and won't be too useful if you want to jack up the truck and push it over.
06-20-07, 11:49 AM
#120 (permalink)
The sticker came with the truck but I don't disagree with it so it stays.
