Home Forum Gallery Wiki CruiserFAQ Tech Links Store
IH8MUD Forum
Go Back   IH8MUD Forum > Toyota Tech Forums > 70-Series Tech
70-Series Tech Tech assistance for the 70- thru 79-series Land Cruisers -- BJ74.com HZJ75.com
Old 01-15-07, 09:53 AM   #1
Rookie
Lj 78
Hi, As posted ,I am a newbie here but have been reading some past posts for assisitance with LJ78 parts,especially regarding the overheating problems.
I went through all the expense of recon heads( x2) and related problems, after spending wads of money I found a permanent solution at relatively low cost, now the LJ performs much better and is always cool, if I can point anyone in the same direction , please contact me,I am based in Portugal am a non technical person but now have my confidence back with this great little LC,
Regards,
Chris.
Chrisys is offline   Reply With Quote
Old 01-15-07, 10:26 AM   #2
JohnnyC's Avatar
Originally Posted by Chrisys View Post
I found a permanent solution at relatively low cost, now the LJ performs much better and is always cool, Chris.
in quick terms what did you do? and also...
welcome to mud....
and show us some pics of your rig....would love to see it
JohnnyC is offline   Reply With Quote
Sponsor 01-15-07, 12:08 PM
Sponsored Link
advertisement
Old 01-15-07, 12:08 PM   #3
1990 LJ78's Avatar
Chrisys
Welcome to mud..
I also own an LJ78..
Any pic's to post..??
The permanent solution for cooling at relatively low cost is what exactly..?? Pics would help.
There may be others here that could use your info..if you wish to post it..
2007 FJ Cruiser--Former 1990 LJ78
VHF, UHF Dual band Ham radio equiped
Hankook 285/70/R17 Dynapro MT's
Spring Tail Solutions Storage
www.eclipzrocks.com
Newmarket, Ontario, Canada
1990 LJ78 is offline   Reply With Quote
Old 01-15-07, 12:14 PM   #4
Mod in Hibernation
brownbear's Avatar
Regards,
Chris.
please directly post your findings on here. It would benefit the whole light cruiser community.
-84 BJ60, Set up for fun.
-91 FJ80, wife's ride
[ ] [ ] [ ][___]__
|--- l l -Lo
=TOYOTA=o]
()_)---()_) --o-- ()_)
Old 01-15-07, 04:59 PM   #5
Rookie
LJ 78 Overheating
Hi, Guys,
thanks for the warm welcome,I bought the LC in March 2004 off a friend,I was moving from London to a very rural part of Portugal and wanted a vehicle that would be a workhorse and take the strain off my small VW Golf.
I loaded the LC with as much as I could get on her and drove it from northern Spain over the mountains to mid Portugal, no overheating and no problems,then I bought a box trailer and went back to UK to get my furniture, loaded the furniture and at 2am on the way to the ferry at Plymouth it blew the head gasket, ( I thought) anyway into a local garage and £1.500 later after having the head skimmed etc I set off for the ferry, it was still getting very hot but it made the boat.
In Spain it blew the head again!, plus I was told the problem was the thermo fan wasn't working, as it flew around the Spanish mechanic stuck his hand into the blades!, they just stopped!.
Another few thousand £;s and off we went again, made the Portuguese border and , it blew again!, this time I used my assistance Insurance and had it taken to my local garage in Portugal.
This garage is in the middle of nowhere, but was long ago a Toyota dealer, the old man who owns it still makes parts,the average age of a truck around here is about 20yrs.
The old man told me about the problems with 2Lte heads along with why it happens and how to fix it, of course I wanted to check for myself, as luck would have it ,I run a research company down here, I put three of my young researchers the task of finding quantfiable reasons why and what the "cure" might be.
They spent a week researching web sites, owners clubs and Toyota data from around the world, yes,the original Toyota heads were faulty, bad castings,it affected the LJ78,Surf, Hi-Ace and some other varients.
In Australia, the major circumstances of overheating was using 4L in sandy conditions, in other places it was towing even very light trailers, using the LJ where long steep hills were present would cause the problem.
The results of the research was that it is usually a combination of faulty radiator/thermo fan but we found that since the A/T cooler is in the bottom of the radiator and the radiator is not big enough to cope anyway, ( in hot conditions) where the A/T box is worked hard it actually contributes to the overheating problem.
As we know spares for this model can be hard to find and expensive, a new head in UK was £500, ( pattern part) a new radiator was about £300, etc,etc.
I found a new head at just £300, my garage then built me a custom radiator (£200) which has exactly a third more water capacity, they took an oil cooler off and old Mercedes and mounted it just in front of the radiator,this is now the A/T cooler, with all the work it cost just a total of £ £900.
The above included all the bottom end work,( bearins etc) and a lot of other new stuff, I found some very good sources of LJ 78 parts,new and used in the UK, it is also worth finding old Toyota dealers with old parts,many are interchangeable with the LJ78.
I had wanted to use a 3L head but was told not to do this, but I have learned that recon heads are a problem in most cases, buy new it saves a lot of grief and cost in the long run.
My old LC now pulls anything, never ever gets hot no matter what I do and is very good on fuel, also found that a larger bore exhaust makes a big difference, as I am not a technical person this is a laymans guide but if anyone wants more specific detail and names of parts suppliers ,please contact me via e-mail.
Regards,
Chris.
Old 01-15-07, 05:27 PM   #6
JohnnyC's Avatar
larger radiator and larger AT cooler...more cooling and less heat...makes sence to me.
Old 01-19-07, 10:00 AM   #7
1990 LJ78's Avatar
Thanks for explaning Chris..
It will give us LJ78 users something else to consider.
I have already enlarged my radiator..
I will try and get a look at the a/t cooler the next time the truck is up on the hoist.
That way I can look from under the truck..
www.eclipzrocks.com
Old 01-19-07, 10:21 AM   #8
bruzer's Avatar
did i read this right you found a head for 300.00 pounds?
bruzer is offline   Reply With Quote
Old 01-19-07, 10:37 AM   #9
crushers's Avatar
you need to make sure the t/c is still run through the rad. in the winter this actually heats up the t/fluid.
we are all given sh*t in life, but some of us learn to turn it into fertilizer and grow from it, and some us try to fling it on others like monkeys.
the start to the above truck here: http://forum.ih8mud.com/70-series-te...uck-build.html
Wayne in Ontario
www.luxuryimports.ca
Old 01-19-07, 02:04 PM   #10
Rookie
Yes!,
actually, the price was so good I bought two!, brand new and running well so far.
Old 01-19-07, 02:07 PM   #11
Rookie
Yes,
probably true in very cold climates but here in Portugal it only gets down just about icy, but in 40c summer heat it doesn't need the radiator.
Old 01-21-07, 04:28 PM   #12
bruzer's Avatar
were did you buy the head if you don't mind me asking
Old 01-22-07, 08:30 AM   #13
light_duty's Avatar
300 GBP at today's exchange rate is roughly 700 $CDN. You can get a new head at your local toy dealer for just over $800 CDN.
Robin
1990 LJ78
2L-TE and LJ78 site, dig?
light_duty is offline   Reply With Quote
Old 01-22-07, 05:17 PM   #14
I had heard the at cooler theory before, which is why I bought mine in a five speed (that, and I prefer shifting my own gears, thank you very much). Apparently, the 5 speeds have still been known to crack, however, but I presume it to be with less frequency.
LJ78 sold before the head went.
Suzuki Samurai for cheap fun.
Mattse.cx is offline   Reply With Quote
Old 01-22-07, 06:00 PM   #15
crushers's Avatar
unless the cooling system is upgraded and the EGTs dropped the head will crack 5 spd or auto...
Wayne in Ontario
Old 01-23-07, 01:16 PM   #16
Yes, it's still prone.
But I'm hoping that careful driving, the lack of a transmission cooler, and the added coolant volume and heat transfer added by my veggie oil system will save me from a cracked head, or at least prolong it.
Old 02-03-07, 04:22 PM   #17
Rookie
Hi!,
bought the head from an importer of LJ78 parts in UK, these are new in the box heads, in Portugal Toyota want £500+ tax( 22%), all is still well after the re-build,
Regards,
Chris.
Old 02-03-07, 07:57 PM
Sponsored Link
advertisement
Old 02-03-07, 07:57 PM   #18
Stand and deliver
roscoFJ73's Avatar
I saw this on oz ebay if anyone was interested in a new 2.8 head
http://cgi.ebay.com.au/Toyota-3L-Die...QQcmdZViewItem
Its a bare head,is there any parts like valves and cam that can be swapped over from a 2.4 head?
Shoot straight ya bastards and dont make a bloody mess of it.
Breaker Morant at his execution
FJ73+1HZ Diesel NEW GEARBOX. SOLD : (
Holden Commodore V6
Honda XR650L
Triumph Rocket3 08 (with some extra punch)
