Go Back   IH8MUD Forums > Toyota Tech Forums > 70-Series Tech
Old 09-13-06, 03:45 PM   #1
Question Amber turbo light
Trying to locate high preasure swich as amber dash light stays on even @ idle , green turbo light no longer comes on . Turbo working fine , i hav boost guage that shows max boost @ 9 psi . Unsure if faulty high/low preasure swich as cant find them or faulty dash meter ????. motor is 13BT .
kiwi4x4 is offline   Reply With Quote
Old 09-13-06, 05:24 PM   #2
Greg_B's Avatar
TLCA# 7091
I want to say the boost sensor is behind the batteries inside the inner fender, but I might well be wrong. We have used sensors, but shipping is a long way. Try sourcing local, and if you run out of options shoot an e-mail to info@gscruiserparts.com
All the vacum lines going to the sensors are ok?
EPC shows 83381-60010 and 83381-60020
When you locate yours check the numbers.
hth's
gb
Old 09-13-06, 06:15 PM   #3
Thumbs up Cheers
Thanks Greg ,will go and have look now.
Old 09-13-06, 07:54 PM   #4
Found it.
Thanks again Greg . Found them where u said . Turned out to be a bad earth .All going now.
Loans | Bad Credit Mortgages | Loans | Cingular Ringtones | Property Search
