Clutch Driven Motor Cooling Fan
A few guys in the 80 Series Tech Section have been really looking hard at the fluid driven clutch that runs our motor cooling fans.
I would really like to thank them for all the work they have been doing on it as I think it all applies to our LJ78 overheating problems as well.. Once you have read the thread you will see what I mean. They have left no bolt un turned in their investigations.. http://forum.ih8mud.com/80-series-tech/102633-blue-fan-clutch-mod.html I would like to remove my fan and clutch drive (blue hub) but on looking at the Prado I do not think there is room to get them out without a rad sectomy(removing the rad). If any one out there with a Prado has had the fan and clutch drive off their truck without removing the rad & cowl ... How did you do it..???? __________________ Richard 1998 JEEP TJ Former 1990 LJ78 Support WWW.IVOAC.CA Pioneer AVIC-N2 Navigation System. VHF, UHF Dual band Ham radio equiped www.eclipzrocks.com Newmarket, Ontario Canada |
on my wifes LJ78 i just went with a fixed fan mount...
seems to work well... __________________ pulling this info out of my ass so take it with a pound of salt "People are poor because they don't spend money wisely, tough sh!t !!! " John Galt 09/22/08 "educate yourself. Sorry if that seems too blunt." John Galt 11-01-08 Wayne in Ontario http://www.ivoac.ca join today |
Wayne,
It would probably be better than the fluid driven clutch.. AFTER you unbolted the old stuff how did you get it out from between the rad cowl and motor?? OR did you have the rad off when you did it..?? I hope I can do this without removing the rad.. The spacer you speak of is what part number?? will the same fan work or dose it need replacing as well..if so with what number?? OR do you sell a kit?? The reason I ask all these questions is that every thing else on my truck's cooling system has been done & fixed if bad etc..the fan clutch is the last thing I have to look at.. __________________ Richard 1998 JEEP TJ Former 1990 LJ78 Support WWW.IVOAC.CA Pioneer AVIC-N2 Navigation System. VHF, UHF Dual band Ham radio equiped www.eclipzrocks.com Newmarket, Ontario Canada |
Richard, i do sell a kit but then so does ENS toyota industrial...
you need to enlarge the holes in the plastic fan but it is a direct bolt on. you do not have to remove the rad (although easier if you do) just the fan shroud and the fan/clutch housing... i think Ens sells them for under $200...talk to Brian... cheers __________________ pulling this info out of my ass so take it with a pound of salt "People are poor because they don't spend money wisely, tough sh!t !!! " John Galt 09/22/08 "educate yourself. Sorry if that seems too blunt." John Galt 11-01-08 Wayne in Ontario http://www.ivoac.ca join today |
BTW Richard,
the stock rad in a LJ78 is 3 X 1/2 core. i am having one made up of 3 X 3/4" core for Berni's bush rig. it is an increase of 40% cooling capacity. if you try and go 4 X 1/2" core then there is NO gap between the cores for cooling and defeats some of the purpose of the upgrade. i tried to find your original post to upload this but couldn't find it... __________________ pulling this info out of my ass so take it with a pound of salt "People are poor because they don't spend money wisely, tough sh!t !!! " John Galt 09/22/08 "educate yourself. Sorry if that seems too blunt." John Galt 11-01-08 Wayne in Ontario http://www.ivoac.ca join today |
I have thought about doing the fixed fan conversion, but I really notice the drag on the engine when the clutch is engaged. Plus it makes one hell of a racket - I don't think I'd want to cruise around with it on all the time.
I'm thinking of going with an electric fan, or overhauling the clutch mechanism on my fan. Or buying a new one. My .02$ Edit: You can definitely re/re the fan without taking out the rad. Just remove the four bolts holding the shroud in place, and the 4 nuts holding the fan mechanism in place, and kind of slide them upward together. It's not too hard. Robin |
OH boy!! good news .. about removal ..I was sure I would have to pull the rad..
Great slide all togeather.... I think I'm going to take a day in the very near future and pull the fan and clutch unit and do a re and re adjustment on the clutch unit as per the link I posted above.. If it dose not give satisfactory service I'll go with the straight bolt on fan and spacer.. Again Wayne & Robin thanks for the info.. It seems every time I post a question you guys have the answer or have been there before yourselves. I do hope that people are taking advantage of the link above though.. All the info a person could want on the clutch driven cooling fan.. __________________ Richard 1998 JEEP TJ Former 1990 LJ78 Support WWW.IVOAC.CA Pioneer AVIC-N2 Navigation System. VHF, UHF Dual band Ham radio equiped www.eclipzrocks.com Newmarket, Ontario Canada |
Diesel for blood
I noticed they were also wondering about the colour relationship of the fan hub.
The 1FZ unit was blue and I noticed the other day current model HDJ79 is red (note turbo). Anyone else seen any other colours or colors?
__________________ HZJ75 cab chassis 95 model ,stocker FJ73+1HZ Diesel NEW GEARBOX 1HZ =same power as 3F with 30% better fuel economy 2in Dobinsons lift.Powerdown adj shocks 33 in BFG A/T HJ61 with slidin windas regrettfully SOLD:(Volvo 740 GL |
The hub on my Prado is Blue..
Any one else?? By the way Wayne thanks for the rad info..Mine is full 3 x core. Still working great.. __________________ Richard 1998 JEEP TJ Former 1990 LJ78 Support WWW.IVOAC.CA Pioneer AVIC-N2 Navigation System. VHF, UHF Dual band Ham radio equiped www.eclipzrocks.com Newmarket, Ontario Canada |
#10 |
my 3F 80 series Red.
#11 |
I can't believe the 80 series post 9 pages about the clutch fan?
Like wayne said put a fixed fan on it if your worried. I just clean and add 2 or 3 tubes of Denso silicone and call it good. Never had a problem running the clutch fan. I like em better for wheeling cause if you ford water or get into deep mud you don't get that hideous sound/possible damage when it goes in the water/mud.
#12 |
what BJ44 said is based on self proven fact, if you run the fixed mount and the plastic fan you can and WILL loose all the blades going through deep water. the "F" series steel fans are a direct, no mod necessary, bolt on...
no flexing, tired and tested to be true (and theoreticly should pull you through the water like a propeller(great imagination eh?))... __________________ pulling this info out of my ass so take it with a pound of salt "People are poor because they don't spend money wisely, tough sh!t !!! " John Galt 09/22/08 "educate yourself. Sorry if that seems too blunt." John Galt 11-01-08 Wayne in Ontario http://www.ivoac.ca join today |
#13 | |
#14 |
The silicone here is made by Nippon Denso I think it is around $5 or $6 for a small tube.
#15 | |
#16 |
It just says denso and silicone oil, no instructions, no other writing.
#17 |
#18 |
Loans | Xecuter 3 Mod Chip | Books | Buy Anything On eBay | Mobile Phones |
