LinkBack (3) Thread Tools Display Modes
Old 11-01-08, 05:39 PM   #61 (permalink)
cody c's Avatar
TLCA# #19921
i did this on my BJ a while back, i used the lighter shocks and found it a little underpowered, i have the insulation removed and am wanting to put damplifier or something on in the future but will probally have to upgrade to the heavier shock. My pin locations on the fender may be different than that of a gasser so that might have something to do with it, SO>>> in hindsight i would have went with the cat launchers even though they seemed like too much push for the hood..
83BJ60,Merkur turbo+intercooled,SOA,aussie locker Custom bumpers,,4.88's, longs and poly rears.RDB's +4runner calipers, parabolics in front, 39.5 IROK's on DC-1's
92FJ80 Cummins 6BT, Airbagged, part time 4wd conversion, rancho air adjustable shocks, custom bumper+8274, 35"Toyo M/T's, Mall Ready!
cody c is offline   Reply With Quote
Old 09-15-09, 10:08 AM   #62 (permalink)
Thanks for cutting the path... I have the parts on hand and will be doing the install shortly. - Adam
My 1st Cruiser: http://forum.ih8mud.com/vehicles-trailers-sale-wanted/238955-diesel-88fj62-w-13b-t-auto-trans-c.html
Captain Caveman is offline   Reply With Quote
Old 09-15-09, 10:49 AM   #63 (permalink)
Interesting that this comes back up. Last weekend I was doing work on various vehicles and happened to open the FJ's hood. The stock springs have been removed since sometime last year and I still don't have the gas springs installed. I'm beginning to think that any spring at all is unnecessary. Maybe when I get some sound insulation on the hood I'll change my mind.
My opinion is worth what you paid me for it.
ntsqd is offline   Reply With Quote
Old 09-15-09, 02:37 PM   #64 (permalink)
Gobble Gobble Wut?
Spook50's Avatar
As long as you have the hood prop no springs are necessary to hold it up. Those stock coil springs just help make lifting a bit easier. The gas shocks mod is designed so that the shocks literally lift the hood themselves once you lift it higher than a few inches and hold it at the max height that the hinges allow.
My 120lb shocks are now getting pretty slow at lifting the hood on their own, I should add. I have extra weight added to the hood in that the stiffeners are filled with Great Stuff, and the underside is lined with Dynamat Xtreme along the stiffeners and Dynamat Hoodliner on the flat areas. This extra weight made a perfect balance for the 120lb shocks when they were new.
'88 FJ62 W/ 253K miles, desmogged, stock SUA W/ full length Add-A-Leafs, Tuffy console, LED interior lighting, Mallory ignition, Ford Contour electric fan, four wheel discs, Aussie sliding windows
Don't cry like a bitch when you feel the pain...
Spook50 is offline   Reply With Quote
Old 09-18-09, 08:04 PM   #65 (permalink)
Just what you'd expect
Tofudebeest's Avatar
Great Stuff?! NO!!!! That attracts and holds water. Ask me how I know!
Tofudebeest is offline   Reply With Quote
Old 11-14-09, 06:31 PM   #66 (permalink)
alpinecowboy's Avatar
I just used the 90lb's from McMaster Carr and they worked like a champ. Thanks for the orignial post and writeup.
alpinecowboy is offline   Reply With Quote
Old 11-14-09, 10:19 PM   #67 (permalink)
Steelhead Addict
alaska60's Avatar
TLCA# IOU41
Garage
I'm next on this one.....I lost the rubber grommet that hold the hood bar in place not to mention that little plastic do dad that holds the bar secure when closing the hood. i keep the hood holder upper thingy bar in the back seat......
I cant wait to do this and throw that damn bar away!!!!
Thanks for this write up!
May 85' fj60 - "TONTO" SOA bunch a cool stuff, 400 plus horses!
April 85' fj60 "DUSTY" metalic brown. fully stock 90K
2001 Land Rover Disco 2
Skidoo XP 800 164" (my chairlift)
Wow, look at all the expensive **** in your sig line. Perhaps you should make the damned thing run, reliably, before dragging it thru an offroad catalog with a magnet attached! After all the work it took to install all that, I'd thinhk a couple of water leaks should be minor! ~TEXX (IH8MUD member) 10/09
alaska60 is online now   Reply With Quote
Old 11-15-09, 06:21 AM   #68 (permalink)
Oh, and I totally skipped the bench grinder part - I just left the upper spring mount on the truck and drilled it straight out with the 5/16" bit - worked like a charm and saved me a bit of work.
Total job time was like 20 minutes...
Old 11-15-09, 04:07 PM   #69 (permalink)
slcfj62's Avatar
You can get both the grommet and the plastic clip for very cheap from Toyota. I wouldn't throw the rod away. You may need it to protect your head in the event the shocks get weak, or the hood gets heavy with dynamat, etc.
Tenth Amendment to the US Constitution: The powers not delegated to the United States by the Constitution, nor prohibited by it to the States, are reserved to the States respectively, or to the people.
slcfj62 is offline   Reply With Quote
Old 11-16-09, 09:10 AM   #70 (permalink)
karlsz's Avatar
TLCA# 16931
Thumbs up
Just installed the 120lbs over the weekend and they are a little much but I think with some use and some dynamat they should be just right. Thanks Spook.
Karl
1990 Fj62
-OME 3" heavy Duty, BFG MT KM2 33x10.5x15, Bed lined interior, Custom 2.5" exhaust
2006 Honda Accord V6 MT
-AEM V2 CAI, Neuspeed Short Shift, Corsprot Shift Bushings, j-pipe, cat delete
karlsz is offline   Reply With Quote
LinkBack to this Thread: http://forum.ih8mud.com/60-series-wagons/95168-hood-shock-conversion-writeup-pics.html
Posted By For Type Date
Outer Limits 4x4 Board :: View topic - ALL Series Cruiser Bible This thread Refback 10-05-08 10:27 PM
Outer Limits 4x4 Board :: View topic - ALL Series Cruiser Bible This thread Refback 08-11-08 01:30 PM
1993-2007 Ford Ranger Hood QuickLIFT - Page 2 - The Ranger Station Forums This thread Refback 02-19-08 05:53 PM
