LinkBack (3) Thread Tools Display Modes
Old 11-28-07, 09:01 PM   #31 (permalink)
great functional mod.
How much sound are you dampening with that hood liner? I wonder if such a thing would work on the firewall too (if one could stand the agony of cutting around all that ****.)
Gutterpunk is offline   Reply With Quote
Old 11-29-07, 11:31 PM   #32 (permalink)
joel hj60's Avatar
Originally Posted by joel hj60 View Post
What is the length of the struts fully extended then fully retracted?
bump
1985 HJ60
joel hj60 is offline   Reply With Quote
Old 11-30-07, 12:40 AM   #33 (permalink)
Gobble Gobble Wut?
Spook50's Avatar
Very unlikely it'd work on the firewall. If you've got those holes in your inner fender walls, I'd recommend using those. The struts are 17" fully extended and 11" compressed.
As for the hood liner, it worked alright. After my truck was vandalized (coulda killed the little fucker) last year and I had to get a completely new hood, I redid the foam trick and instead of just slapping the new hoodliner in place, I cut out portions of it to perfectly fit the recessed areas on the underside of the hood, and put Dynamat Xtreme (the foil-lined stuff) along the stiffeners. Looks much better now, and works FAR better. This method shields heat so well that if there's snow & ice on my hood, it's STILL there after a 4.5-hour drive to Seattle to see my folks. Heat does NOT escape from this hood. It quiets it down a great deal too. I'll snap a pic or two this weekend of how it's done now and post 'em up.
Also, concerning heat being reflected back down to the engine, my temp gauge has actually red lower on average since using a reflective hoodliner. I'm not really sure why, but that's what it do...
'88 FJ62 W/ 253K miles, desmogged, stock SUA W/ full length Add-A-Leafs, Tuffy console, LED interior lighting, Mallory ignition, Ford Contour electric fan, four wheel discs, Aussie sliding windows
Don't cry like a bitch when you feel the pain...
Spook50 is offline   Reply With Quote
Old 11-30-07, 10:03 AM   #34 (permalink)
bkfj40's Avatar
TLCA# 7909
spook50 - your PM box is full...can you pm the part numbers for the australian fj60 sliding rear number weatherstripping?
thanks!
bk
bk
KJ4HFL
646 and repeat
bkfj40 is online now   Reply With Quote
Old 01-25-08, 04:33 AM   #35 (permalink)
Great mod idea!!! Thanx for sharing!!!
Vince
1989 FJ62
1976 FJ55
1971 FJ55
1989 Supra
MauiVince is offline   Reply With Quote
Old 05-17-08, 05:29 PM   #36 (permalink)
gaylon's Avatar
This is a great modification. Did it today - quick pretty easy (muscling the end of the shock down not so easy). Thanks for the idea.
'00 LC - OME Lift, 285 REVOs, Group 31 AGM Marine Battery.
'84 LC - OME Dakar Lift, 33 x 10.5 BFGs, ARB roof rack, bull bar & connected slider steps. Tuffy Console, Group 34 Sears Platinum AGM Battery
'92 M101 Trailer
2008 Mazda MX-5 PRHT GT
gaylon is offline   Reply With Quote
Old 05-17-08, 05:36 PM   #37 (permalink)
Gobble Gobble Wut?
Spook50's Avatar
Glad to hear you liked it. They still work like a champ for me. And now that my hood is holding a few extra pounds from the Dynamat stuck to it, the 120lbs (now that they're broken in a bit) are a perfect match for it.
Easily the best "cheap" mod I've ever done.
Old 05-17-08, 05:41 PM   #38 (permalink)
Sixty's Guy's Avatar
I did this mod too, but used the same struts as the rear hatch.
AKA Mark
1983 HJ60, 2H Turbo, 33/35" BFG MT, Twin Lock Rights, other stuff
1975 FJ55 Stock Standard
Sixty's Guy is offline   Reply With Quote
Old 05-17-08, 05:43 PM   #39 (permalink)
gaylon's Avatar
90 lbs. Shocks
I used 90 lbs. shocks, still more than enough lifting force. Thanks again.
'92 M101 Trailer
Old 05-17-08, 06:12 PM   #40 (permalink)
cruiserpants's Avatar
That is friggin’ clever, creative, resourceful and ingenious!
...now do mine.
Are the voices in my head bothering you?
1989 FJ62, OME lift, 33" BFG A/T's & a new air freshener
cruiserpants is offline   Reply With Quote
Old 05-18-08, 11:55 AM   #41 (permalink)
Gobble Gobble Wut?
Spook50's Avatar
...now do mine.
'Taint hard to do. Took me about a half hour from start to finish.
Old 09-02-08, 09:24 PM   #42 (permalink)
FWIW the rough eqivalent McMaster-Carr part number looks to be 4138T56; these come with the ball sockets and studs already installed. As of this writing (9/2/08) they are $13.13 each.
Specs:
Extended (Max) Length: 17.13"
Compressed (Min) Length: 10.83"
Available Force rates: 15, 20, 30, 40, 50, 60, 90, & 120 lbs. (Specify at order)
HTH......
My opinion is worth what you paid me for it.
ntsqd is offline   Reply With Quote
Old 09-03-08, 12:06 PM   #43 (permalink)
Turbo Diesel Lover
Tapage's Avatar
Specs:
HTH......
Where you bought and which you choose .. ?
HJ-60 2H-T Intercooled Tencha
Tapage is online now   Reply With Quote
Old 09-03-08, 12:18 PM   #44 (permalink)
From mcmaster.com, based on the comments above I've ordered the 90 lbs force versions.
Old 09-03-08, 12:32 PM   #45 (permalink)
what he said
Mace's Avatar
TLCA# Something
I'd do 120. Then you could launch feral cats off the hood with a vengence..
I am kinda gay.......
My Myspace
Mace is online now   Reply With Quote
Old 09-03-08, 05:14 PM   #46 (permalink)
Turbo Diesel Lover
Tapage's Avatar
Thanks .. you thought the 90 are enought ?
Old 09-03-08, 07:07 PM   #47 (permalink)
Originally Posted by Dynosoar View Post
I got mine all done a few weeks ago. If I were to redo it in the future I think a 70-80lbs sping would be plenty, the current stuts really lift the hood quick (it would lift a small child no problem),
Note: on the passenger side I just retaped the hole that was right where spook fit his and just threded the bottom ball in place.
Dynosoar
I did, but Mace's talk of launching cats made me switch them to 120's. If it's too much I'll just move the lower mount. If it's way too much then it's his fault and I'll have to order some lighter versions.
Old 09-03-08, 07:44 PM   #48 (permalink)
FZJ80ismybaby's Avatar
see, i have the problem as having an fj62, with those cheap little coil things to hold up the hood, i dont know about you other guys, but after about 20 years or so, they dont work as well as they used to...can it be done on the 62, probably have to make some holes...
1990 FJ62 - Sold
1976 FJ40 - 33x9.50's, HFS front bumper
1993 FZJ80 - OME, Wet Okole seat covers, ARB, IPOR rear
O=TOYOTA=O
Mountaineer Cruisers
FZJ80ismybaby is online now   Reply With Quote
Old 09-03-08, 10:37 PM   #49 (permalink)
War Eagle
GulfShoresFJ60's Avatar
TLCA# 15437
The vehicle in the first post is a 62. He must have just removed those if they are only helper springs that are separate from the main hinges.
Caleb - Auburn University
1984 FJ60 - Restomod - 2F - H55F - 4.7:1 Toybox - ARB Front - Full-Floater w/Aussie Rear - Custom Rear Bumper - Warn M8274 - 37 MTRs - Vinyl Floor
1983 FJ60 - Parts Rig
1974 FJ40 - Rustbucket
M416
1966 Mustang Coupe - 289 w/ C4
My Site
GulfShoresFJ60 is offline   Reply With Quote
Old 09-04-08, 01:09 AM   #50 (permalink)
Gobble Gobble Wut?
Spook50's Avatar
Aye. I removed the springs (they're only there to assist with raising the hood, not to hold it up. That's why the prop is there on the front) and ground off the rivet that holds the hinge to the brackets (the ones that bold to the hood itself) so that I could attach the shock struts.
Old 09-04-08, 04:41 AM   #51 (permalink)
cool, i didnt see your signature....blonde moment, thanks, i gotta do this, that stupid thing that hold it up in the front keep falling off :/
1990 FJ62 - Sold
O=TOYOTA=O
Old 09-04-08, 04:19 PM   #52 (permalink)
euclid's Avatar
TLCA# 13014
90 lbs is pleanty imo.
Greg Thompson
89 FJ62, Unstock.
euclid is offline   Reply With Quote
Old 09-04-08, 07:57 PM   #53 (permalink)
Now that I have 120's laying on the living room floor I think that I agree, 90's might have been fine. I have some concerns about getting the 70's Chevy truck hood syndrome. I'll put them in & report back.
Old 09-04-08, 08:05 PM   #54 (permalink)
what he said
Mace's Avatar
TLCA# Something
lol
Did you really get the 120's???
My Myspace
Old 09-04-08, 08:53 PM   #55 (permalink)
You promised me cat mortars. I'm not too interesting flinging cats, but gray tree squirrels..........
Think I can build an assisted spud trebuchet with them?
Old 09-05-08, 07:00 AM   #56 (permalink)
Dynosoar's Avatar
TLCA# 17857
120's will push the hood into the wiper arms when the hood is raised. 90 are plenty I would even consider 60's. 90's are redundant as one side will hold the hood up with 60's you do need both in good working order.
Dynosoar
'82 V8J60 - TPI 350 with a 700R4 attached to a splitcase, Cable Locker FF rear end, 4" SUA (National Spring), Copper Metalic Has been south to Cabo San Lucas, BCS and North to Port Angels,WA.
Call Sign: KI6SMP
Dynosoar is offline   Reply With Quote
Old 09-05-08, 09:04 AM   #57 (permalink)
what he said
Mace's Avatar
TLCA# Something
With your skills..
I pretty much guaronteeeeee it
My Myspace
Old 09-06-08, 02:57 PM   #58 (permalink)
Gobble Gobble Wut?
Spook50's Avatar
Dynosoar
It will with the plastic covers on the wiper pivots. Remove the covers and the struts will hold the hood at the limits for the hinges, without touching the wipers. My 120 lb. struts have a lot less force now that they're broken in than they did when new. Now it's a perfect balance for the weight of the hood (keeping in mind I have Dynamat Xtreme and Hoodliner on it, so that adds to the weight a good amount).
Old 09-06-08, 10:49 PM   #59 (permalink)
3pits's Avatar
I am planning on doing this conversion tomorrow or monday I and thinking of putting a piece of hose or trim like from the door surround (ushaped) on the top of the hinge, that should hold the hood down a 1/4" so it wont touch my already brokend plastic covers,,,ill post if it goes well
You can have it done QUICKLY, done INEXPENSIVELY, done CORRECTLY Pick any 2
Liberals are like Slinkies, Not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs
3pits is offline   Reply With Quote
Old 11-01-08, 12:34 PM   #60 (permalink)
3pits's Avatar
ok I did my hood shock conversion and had some pointers,
on the passenger side, I removed the washer resevoir to get to the nut
on the drivers side I used a manget to hold the washer and the nut to get it started
I would consider going with the 15.23" total extended shocks 4138t55 in McMastercarr.com as just when I compressed my shocks during the install I broke another plastic wiper cover, I forgot to put the spacer on the hinge,,, anyone got an extra they want to mail me?
I went back and re-did mine, I did not like it resting on the windshield wiper. I used the hole on the passenger side as a guide for where I drilled the drivers side. There is a raised panel about 1.75 inches ahead of the hole noted in the first post. I believe I measured from the front bib something like 19.75 inches back and 1.75 inches down and drilled a hole, again the same distance as the passenger side hole with nut. On the passenger side there was a hole with a nut welded to the back of it, I probably should have drilled and tapped it for the 5/16th stud end I had on my shock, instead I drilled it then had to painfully and blindly dremel the rest of the nut off with my hand/arm backwards inside the fender/skirt area,,, trying not to cut any of the many wires I have routed inside there. Definatly a painful and not very fun way of spening a half an hour,, anyway it worked, it is about 1.5 inches more open than stock, but about 2 inches lower than the first mounting point. It does seem to not sling open as hard, and you have to open the hood more before the shocks take over the opening effect, but that has to do with the new geometry of moving the lower pivot point forward.
As another note, the 80 shock is mounted differently then the way this mod is done, not saying either is better, just different. I am very happy with this mod, thanks for the notes and info for me to get it done. I looked like a fool out there opening and closing and opening and closing my hood sunday,,,it is just neat!!
Also, I did not have to wrestle with compressing the shock to mount it on the ball joint.
LinkBack to this Thread: http://forum.ih8mud.com/60-series-wagons/95168-hood-shock-conversion-writeup-pics.html
Posted By For Type Date
Outer Limits 4x4 Board :: View topic - ALL Series Cruiser Bible This thread Refback 10-05-08 10:27 PM
Outer Limits 4x4 Board :: View topic - ALL Series Cruiser Bible This thread Refback 08-11-08 01:30 PM
1993-2007 Ford Ranger Hood QuickLIFT - Page 2 - The Ranger Station Forums This thread Refback 02-19-08 05:53 PM
