| Here's my experience with similar symptoms and 1970 bronco with efi conversion. Routinely stalled as clutch was in and coasting to light. There was also a surging sessation when I coasted at low speed (at idle) in gear. I do not have VSS hooked up. I easily rule out volts and fuel pressure immediately as I have after gauges in cowl of hood with fuel gauge being mechanical. Both showed no problem when it puked. The fix was to add a PCV from upper intake to lower which I had read was optional for this type of conversion. I do not know the technical reason why this would fix it, but it did. It has not stalled since. Good luck, if you find the root cause please post. Thanks, AZLC
__________________ 1988 FJ62 stock TLCA#15225, 32 BFG muds, rear aussie locker, ever so closer to h55f
1970 Bronco, 351w, Cobra EFI, NP435, LS & DL
1981 Toyota 4x4 Truck not running |
