Old 02-28-06, 04:40 PM   #1
tpattyII's Avatar
tell me about "anti-inversion" shackles?
im minutes away from buying an OME kit for my 60 and keep seeing anti-inversion shackles everywhere. what are the pro's and con's to getting these aswell. do they have to be welded?
thanks
tpattyII is offline   Reply With Quote
Old 02-28-06, 07:17 PM   #2
Suffering from V8 Madness
djawahir's Avatar
Do you plan on doing some serious wheeling? I mean, like the type that takes the wheels off the ground? If not, you can do the anti-inversion or the normal type of shackle. If there is even the slightest chance you would wheel the rig, just get the anti-inversions. The anti-inversion shackles are better in most cases. And as far as I know, I've never seen any anti-inversion shackles that need to be welded...
I have the uncanny ability to make things harder than they really are.
V8 swap progress: 5.3L Vortec mounted. Plumbing lines!
djawahir is offline   Reply With Quote
Old 02-28-06, 07:26 PM   #3
what he said
Mace's Avatar
If you need antiinversion shackles you need longer shackles from the getgo..
I would say that I do not see any reason to get them.
I am kinda gay.......
My Myspace
Old 02-28-06, 07:31 PM   #4
nuclearlemon's Avatar
TLCA# 1431
i've seen quite a few inverted springs that could've been helped with anti inversion.
as mentioned, if you routinely pick up wheels, get em.
seven cruisers and 3 of em run and four are for sale
nuclearlemon is offline   Reply With Quote
Old 02-28-06, 07:36 PM   #5
what he said
Mace's Avatar
If your springs are able to go inverted your shakles are too short. I cannot imagine why running shackles that are too short on a rig is ever a good thing.
Even with antiinversion shackles you are putting a bandaid on your suspension. Instead of allowing the most flex possible you are straining the spring eyes and bushings by putting a bunch of pressure on them.
My Myspace
Old 02-28-06, 09:40 PM   #6
beaufort-fj60's Avatar
explain this some more... what is too short? factory length or shorter than factoty.
beaufort-fj60 is offline   Reply With Quote
Old 02-28-06, 10:11 PM   #7
TLCA# 1431
how long do you want them to be? at least two that i've seen inverted were running extended shackles...one running 2 1/2 with stock springs, other running 1 1/2 over stock with skyjacker 4".
the stock rig was runnign hard through a mud bog and popped the front end out.
other rig was crawling a rather difficult twisty section and put the right pressure to cause it.
both of these rigs sat very nicely with a slope in the shackle away from the other end of the spring.
i don't think longer shackles would've made a difference.
Old 02-28-06, 10:36 PM   #8
agent orange's Avatar
TLCA# 16545
You dont want them to be so short that you run out of shackle travel before the spring fully compresses, but there is a point of diminishing return after that as far as function goes. Oh, and they can definitly be too long (the ones MAF puts with their 4 inch suspension kits fall into that category IMHO).
1988 FJ 62- SUA, 1" body, 34" trxus mudders, 2.5" exhaust, 27spl Longs/Pig Inners, 4.88s, torsen LSD/lockright, 4runner brakes, other random stuff...
1986 pickup- 2wd, 22r, 4 speed, DD
oh, and custom tree damage
agent orange is offline   Reply With Quote
Old 02-28-06, 10:39 PM   #9
lowenbrau's Avatar
TLCA# 5513
Mace is almost right.
Where the theory breaks down is when a rig is climbing out of a hole and bumps the shackels into the bank while the suspension is unloaded. It happens all the time around here when you are breaking ice on river crossings.
If you have an over length shackel or spring then you have about a 50/50 chance of bending the spring at the fisrt spring clamp when you invert. Some method of inversion proofing will save having to buy new leafs.
Rocky Mountain Land Cruiser Association TLCA # 5513
'87BJ74, '86BJ70, '78FJ45, '53M100, '90M101cdn
I support our Troopies
lowenbrau is offline   Reply With Quote
Old 03-01-06, 05:00 AM   #10
I've been "acquiring" a lift in pieces and the shackle length is something I an not sure about. sofar I have the "habu"/terrain tamer rears leafs the heavy version and stock length rear anti-inversion. I've got the OME light fronts and stock length anti-inversions. How much longer/larger diameter on the arc are aftermarket springs? is it up and out (higher the lift the further apart the shackle eyes are) will stock length shackles create odd ball angles with the aftermarket springs?
Old 03-01-06, 12:33 PM   #11
what he said
Mace's Avatar
most of the time, the rest of the time youbend leaf springs.
If you really have trouble with this happening you need a shackle reversal..
My Myspace
Old 03-01-06, 04:30 PM   #12
High Desert's Avatar
Don't you weld "reverse" shackles on the front? And does not OME offer them too?
Just to throw more fuel on this fire.
1984 FJ60, 102k miles, OME med/heavy,
BFG/AT 33X10.5 on Stock Wheels, ARB Bullbar W/Warn 8274, Tuffy Console.
High Desert is offline   Reply With Quote
Old 03-01-06, 05:27 PM   #13
i think the "shackle reversal kit" is a system that basically moves the "working" shackle to the rear and the stationary pin to the front. factory setup is pin in back and "working" shackle up front.
and yes you weld the stationary pin holder on the front.
Old 03-01-06, 05:39 PM   #14
what he said
Mace's Avatar
Exactly, a SR flips the spring around so that the frame end of the spring is at the front and the shackle end of the spring is behind the front axle.
The only reason I acutally like SR is if you are smacking the shackles hard enough to bend a spring. Then you make a nice smooth rap for the item you are hitting by doing a SR.
A shackle only need to be as long as it does. there is no magic number for the length. It is whatever length is required to fully utilize the working arc of the leaf spring as it extends and compresses.
Another fix to springs that tend to invert is to move the shackle hanger.
My Myspace
Old 03-02-06, 12:09 AM   #15
Thanks for the reversal explanation. didn't mean to Highjack, I use to think that I would do a reversal when I go OME, However I'm not really going to get even near crawling type trails in my rig..So the SR would be overkill, right?
Old 03-03-06, 12:45 AM   #16
loomis's Avatar
I recently inverted one of my 2" extended shackles...no major dramas, but hell it made a noise when it happened.
loomis is offline   Reply With Quote
Old 03-03-06, 08:18 AM   #17
TLCA# 1431
you got it on upside down
Old 03-03-06, 08:20 AM   #18
what he said
Mace's Avatar
Aint those anti inversion shackles???
My Myspace
Old 03-03-06, 09:08 AM   #19
Benji's Avatar
TLCA# 14119
Ditto those are upside down. Invert your anti-inversion shackles.
Hoosier Cruisers http://www.hoosiercruiser.org/
84 FJ60 - TLCA # 14119
Benji is offline   Reply With Quote
Old 03-03-06, 04:29 PM   #20
loomis's Avatar
silly question (I ask these all the time, get used to it) but what difference does it make which they they go?
Are you guys saying that the shackle is upside down (top to bottom) or upside down meaning the triangulated side should be facing the front instead of the back....or both?
Old 03-03-06, 05:37 PM   #21
3puttcop's Avatar
TLCA# 15317
When thier installed correctly they don't do that!
87' FJ60, perfect body, BDS lift, mud tires, hula wiggler.
07' FJ Cruiser AllPro suspension & bumper 33/MTZ's
“Beer is proof that God loves us and wants us to be happy”
Benjamin Franklin
3puttcop is offline   Reply With Quote
Old 03-03-06, 05:55 PM   #22
djawahir's Avatar
The instruction on installation leave a lot to the imagination.
At least you bolted the spring on tight!
Old 03-03-06, 07:46 PM   #23
TLCA# 1431
shackle is upside down. short side should go to the top
Old 03-03-06, 07:55 PM   #24
what he said
Mace's Avatar
I love the fact that the first pic someone posted is of an antiinversion shackle that has gone inverted
My Myspace
Old 03-03-06, 08:33 PM   #25
TLCA# 16545
You did better than the fourwheeler guys did, they had theirs on upside-down AND backwards.
They truly are experts in their field.
Old 03-04-06, 09:40 AM   #26
TLCA# 1431
i saw that too...sent em an email, but that was the first thing i noticed.
Old 03-04-06, 02:59 PM   #27
loomis's Avatar
How would having the shackle the other way around stop it from doing this...No matter which way you have it, it could still end up like that....couldnt it....explain this for me please.
Old 03-04-06, 03:02 PM   #28
what he said
Mace's Avatar
Correct me if I am wrong, but I think there is a bolt missing.
My Myspace
Old 03-04-06, 05:27 PM   #29
tclndcrz's Avatar
TLCA# 14430
here is a pic showing an anti-inversion shackle properly installed. there are 3 bolts. one of the bolts will hit the frame and stop the shackle from inverting. in the pic you can see the lower two bolts. the top bolt is behind the exhaust. i circled the shackle in the picture.
btw this pic is from today
