We've got another Desert trip this weekend so I better take care of this....
Well besides the fact that my Transfer Case is running dry I can't stand the smell of hot 90 weight when I'm playing in the sand. This is by far the easiest "repair" I've done yet.
I know Man-a-fre sells a kit for this but it's pretty simple to DIY.
Parts involved:
2 new drain/fill plugs from Toyota
2 new plug washers
2 new brass 1/8" pipe male thread to 3/8" hose nipple
Teflon Tape or liquid pipe sealant
1/8" pipe thread tap
3/8" fuel or trans cooler hose(I got 2 feet to be safe)
2 hose clamps
I got the new plugs so I could do everything on my bench before crawling under to do this.
If I was gonna do this again I would use 1/4" pipe thread fittings instead of 1/8" only for the bigger hole on the inside to promote better oil flow.
Drill out the plugs from the backside, they're hollow and make an excellent drill guide. Tap the holes from the front side.
Remove the old plugs, let the trans drain, refill the transfer(mine always seems to take 3-4 pints)
Put the new plugs in without the brass fittings 'cause you'll need to set the drain/fill angle of the fitting.
Screw in the fittings and adjust the angle for good drainage, cut the hose to length and clamp on. DONE!
From underneath:
From the rear:
How cool is that?
Parts involved:
2 new plug washers
2 hose clamps
From underneath:
From the rear:
How cool is that?
