I had to tear into my door to replace a window that some jackass decided to smash out and since I know some people are intimidated by the door I figured I'd do a quick write-up.
This is what I woke up to on Christmas Eve (we had one window in three cars of our four cars broken, I had spares for the one that didn't)
http://i87.photobucket.com/albums/k130/lated22/New Window/IMG_8375_zps6dfe1a26.jpg
Tools: Phillips (#2, and #3), flat-blade screwdriver, window crank tool, and a helper
Step One: Strip the door. Speaker, arm rest, window crank, and door latch trim all need to come off. The door latch and arm rest are just held on with screws but the window crank is a little trickier. A tool like this makes for a much easier removal; just slide it between the crank and the trim ring. A flat-blade screwdriver can be used if it's all you've got. Be careful with the trim ring. Mine crumbled apart as soon as I touched it.
http://i87.photobucket.com/albums/k130/lated22/New Window/DSCN8410_zpsf413b831.jpg
Make sure not to loose the clip that holds the crank on. Mine kept walking away with the assistance of my helper.
http://i87.photobucket.com/albums/k130/lated22/New Window/DSCN8411_zpsd6d6ac28.jpg
Don't worry about the map pocket, it's attached to the door panel.
http://i87.photobucket.com/albums/k130/lated22/New Window/DSCN8413_zps6ca7e509.jpg
Step Two: Now all the push-in fasteners along the perimeter of the door panel need to be popped out. The easiest way is to try to gently pry the panel off by hand, working your way around until you find one of the fasteners.
http://i87.photobucket.com/albums/k130/lated22/New Window/DSCN8417_zps436ce684.jpg
Then you can slide the flat-blade in and just pop it apart. Work around the entire perimeter of the door until it will pull away from the door.
http://s87.beta.photobucket.com/user/lated22/media/New Window/DSCN8418_zps9e235054.jpg.html?sort=3&o=13
Step Three: Lift up on the panel to pull the inner window felt off the door. It seems to work best if you start by the door hinges and then move toward the outside of the door. It also helps to have the window rolled down all the way (not really a problem for me though )
http://i87.photobucket.com/albums/k130/lated22/New Window/DSCN8420_zps2a53d24a.jpg
Step Four: Yay! The panel is off. There should be a sheet of plastic under the door panel, try not to tear it as you remove the panel. Mine has been removed by a PO at some point (probably speaker upgrade) and not replaced. I don't know that the plastic is absolutely necessary, but I would imagine it helps keep dust and moisture off the back of the door panel. I'm not going to bother replacing mine at this point because I'll be back in here replacing weatherstripping soon, I hope.
I found an old For Sale sign in the door; haven't seen cruiser spelled quite like that before.
Step Five: If you are only replacing glass like I am (and if you still had the plastic in place), you only need to peel it up from the bottom two corners to allow access to the two bolts that hold the window channel to the regulator.
Step Six: Undo the two bolts pictured above and pull the glass out carefully. On the front doors the straight edge (latch side of the door) has to come out first as you let the mirror side drop into the door. It also needs to be pulled inside the door, following the curve of the glass. I assume the back doors are the same, but I haven't pulled one apart yet. Now you can replace weatherstripping, the window regulator, etc.
Step Seven: Installation is pretty much the opposite of removal, mirror edge of the glass goes in first, followed by the door latch side. Make sure the window is seated in both the front and back channels before you bolt it to the regulator. This is much easier to do with two people.
Step Eight: Reattach the plastic. I plan to use clear RTV since I have some laying around and a sheet of plastic drop cloth that seems about the same weight as the remains that were left on my door.
Step Nine: Drop the door panel back in place, making sure the window felt is seated completely (window cranked all the way down again).
Step Ten: Push all the push-in fasteners back in and reattach arm rest, speaker, etc. I didn't realize at first, but if you slide the clip on the window crank all the way back in (unlike the pic below) it will just push right on. I tried to put it back like this and then slide the clip in place after the crank was on--Pain in the ass. Just push it on.
Step Eleven:
Step Eleven:
