08-12-05, 12:24 PM
| | Forum Regular
| Max. weight for synthetic t-case gear oil? Anyone know how thick you can go with synthetic in your t-case? I'd like to try queiting my gears a bit but don't want to do any damage...
Thanks,
Tim
88 fj62 TLCA |
08-14-05, 02:54 PM
| | Forum Lifer
| I've heard that Redline Gear Oil is great for transfer cases...esp ones that are worn. Is your's leaking? Why are you thinking of going thicker?
__________________ Doug G
Seattle, WA
TLCA#12671
1987 fj60, 310,00 miles, 3" lift, 33X10.50's BFG MT, dual battery, rear drawers, CB, tuffy, , lockright, 4.10's and H41 soon |
08-15-05, 08:10 AM
| | 250+ Club
| 75-140 is about as heavy as it gets, AFAIK, Tim. Those Mark's gears a little noisey, are they?
__________________ Steve Crase TLCA 10222
1988 FJ62 - Bart
1997 FZJ80 40th Anniversary #3727 - Sandy |
08-15-05, 08:27 AM
| | 250+ Club
Join Date: Mar 2004 Location: Silver Spring, Maryland & Daytona Beach, Florida
| What have you been using ? Is it conditioned for limited slip applications ?
IMO, going heavier will yield marginal results. You need better quality oil. I did some experimenting using convertional mineral base and then switching to a conventional mineral base with limited slip conditioner.
Note: The limited slip conditioner was already in the oil.
Took the noise down a definite notch. Not quiet ... to hear a pin drop, but definitely an improvement.
Somebody else wil have to comment on the synthetics. I'm not a fan of running synthetics in our trucks in *general* unless there is a *specific* reason.
Cahil
__________________ .....
67 Red FJ40 - SBC, Holly, NV4500, SOA
87 Blue FJ60 - Cummins 6BT, NV4500, OME, SUA
..... coupla' parts rigs too ... |
08-15-05, 05:46 PM
| | Forum Lifer
| Ahhh, so it's because of the Marks gears...
Instead of changing the oil, why not use some noise abatement materials on the floor?
Seattle, WA
TLCA#12671
08-18-05, 11:57 AM
| | Forum Regular
| Out of town or would have replied earlier: yes, it's the Mark's Gears. Not horribly loud but wouldn't mind quiting them a bit. Sounds now EXACTLY like a worn t-case gear whine (at least exactly like my brother's fj62 t-case sounds. Someday when I move to the Great Interior Makeover (pull out cargo drawers, decent stereo, etc.) I will add more sound proofing to the truck as well. But I heard that thicker synthetic gear oil will make the t-case a bit quieter than plain ol' 90wt...
Tim
88 fj62 TLCA |
