I had to dig into the transfer case this weekend and in prep purchased the needed seals and gaskets, one of which was the input seal. T-case to transmission fluid movement seems to be not uncommon with 60s but not common with 62s. So I ordered an input seal for an '85 FJ60 and an input seal for a FJ62. The t-case I had apart was from an '85 FJ60 but I used the FJ62 seal because I think it will prevent oil gear movement.
FJ60 oil seal part # 90311-48012
outer diameter - 72.3 mm; inner diameter - 46.8 mm; depth - 9.1 mm
FJ62 seal part # 90316-48003
outer diameter - 72.2 mm; inner diameter - 46.8 mm; depth - 10.8 mm
The major difference between the seals is that the FJ62 seal has dual spring-compressed lips, i.e. one on each side unlike the FJ60 seal which only has one spring-compressed lip.
