Is it synthetic oil some put in their cruisers? Ive got a 2f with 187k and thought it may be a good idea. What do some of you recommend? What brand and do you fill it up with synthetic or use just one quart?
Man, these oil threads always open up a can whoop-ass...
High-mileage additives and the like are secondary to what you really should worry about for your flat-tapped motor: an oil with the proper amount of high-pressure additives. IMHO, the new formulations of Rotell T do not have it. ANY oil SM or newer rated does not have it. Synthetic or Dino - Plenty of threads on it.
Are you still running Castrol GTX Diesel?
rotella 15-40 is hard to beat especially the price..
Correct. The racing oils that have adequate EP additives are very expensive, compared to 9qts of cheap 15W40 and a bottle of cam lube.FWIW. You can buy Zinc additives for the old flat tappet engines. It might be cheaper to use an additive along with Rotella vs. running a more expensive oil all together.
Not exactly:
Two gallons of Rotella are gonna be about $30, here in ol' CA. One bottle of the ZDDP (re-badged zddp plus) is designed for 5qts oil, so two will be necessary to bring the 800-900 ppm Rotella up to a min level of 1400 ppm or so of what the pre-2007 CI-4 oils used to be. So around $50-ish regular retail total.
Amsoil blend pre-'07 diesel is $25/gal.
Castrol GTX Diesel 15w-40 at 1400ppm zinc is about $4.50/qt and avail at Vatozone.
