07-21-05, 12:43 PM
| | Site Addict
| Tips on arc welding patch panels on the quarters...??? Working with what I have (basic stick welder), I am thinking about tackling my rusty rear quarter panels. One side has rust 1/2 to 1 1/2 inches along the wheel arch and into the dog leg. The other side is less bad.
I know how to cut and prep for rust, but am less certain about my stick welding skills on 18-20 gauge sheet metal. I am inclined to work with something like 1/16 rods.
What is your experience here? What kind of sticks and amps? Have people had luck with butt welds? Should I flange the existing sheet metal, drill holes in the donor pieces and tack? Stitch? |
07-21-05, 03:39 PM
| | Forum Regular
| The only rod I could think of that might work would be a 3/32 6011 rod, I can't tell you what to put your amps to I would guess 35 to 65 but you should expierement on some scrap sheet metal first until you get it down.
__________________ Never do today what you can put off until tomorrow. |
07-21-05, 07:09 PM
| | Forum Regular
| I'm not an eperience welder by any measure, but one thing that I'm fairly sure about is that you shouldn't attempt to use a stick welder (arc welder) for sheetmetal.
You would be far better off hiring a MIG or even an Oxy welder for that type of work.
Honestly, don't waste your time with the stick welder on sheetmetal!
(or at least practice on some scrap first so that you will see the mess that it will make!) |
07-22-05, 06:19 AM
| | 250+ Club
| Kind of a recipie for panal warpage from too much heat.
Even with a mig using .045 or larger wire (which is small) requires turning up the welder power to a degree enough to melt the wire, is too much heat for thin sheet metal.
.023 or .030 wire is preffered.
__________________ 82 FJ60 Trail Rig. topless, Caged, 4BD2T diesel turbo & intercooler, H55, Toybox, SUA, 37" MTR's,
83 JJ60. Daily driver, OME, 33's, 6.2 diesel, NV4500, WVO http://mysite.verizon.net/sbutman1/LC.html |
07-22-05, 06:55 AM
| | 250+ Club
| 6013 Go buy some new 6013 rods. As small as they have.
You can always plug weld places.
The most important thing about stick welding is having good dry rods. If they have been sitting out. Wrap them in aluminum foil and put them in oven on about 250 for an hour. You'll be amazed how much better they do.
J.R. |
07-22-05, 08:32 AM
| | 250+ Club
| I had to use an arc welder for about the same thing. I just butt welded them at around 30 amps but I put a 3/4" strip behind it to make the metal a little thicker. Didnt look too bad after finishing. Just use smatt stitches at a time, like 1/2". dont get it too hot. p.s. the strip i used also helped keep everything level and flush. 6013 rods are recomended.
__________________ FJ-4.3 1973 FJ40 was frame off, got a 4.3 CFi/4L60E/NP-205 and FJ-62 power steering. SOA, 35x12.50 MT/Rs, FJ62 FDB. Brought back from the grave(traded a shotgun for it, if that tells you anything). Turning out to be a sick 40!!
Buildup Thread: ALMOST DONE!!!!! http://forum.ih8mud.com/40-55-series...up-thread.html Sanity is over-rated!! |
07-22-05, 10:02 AM
| | what he said
| Quote: |
Originally Posted by FL cruiser Kind of a recipie for panal warpage from too much heat.
.023 or .030 wire is preffered. | .045 is small???
.030 is standard with solid core.
Flux core typically is .035
You can do sheet steel with stick. Tig is just a glorified stick welding. You jusat have to know what you are doing. Get the smallest rod you can possibly find. and practice.. Do some test patches on some junk metal before you decide to go hog wild on your truck.
__________________ I am kinda gay.......
I've set the bar, don't trip over it....
"Mary Poppins: In every job that must be done, there is an element of fun. You find the fun and - SNAP - the job's a game." |
07-22-05, 11:52 AM
| | Site Addict
| Keep those recs coming.
I have been working with 6011 sticks for awhile now, but getting a fair amount of burn through, particularly on the edges of my lap joints. I have tried stitching mainly.
Someone mentioned burning at 30 amps. That might do the trick, I know I have been playing around with 45-55amps....the higher amps for playing with 1/4 inch steel.
If I try plug welding with lap joints, how much space can I allow between the two pieces of metal before welding in the plug? Because of my clamps, I am usually pretty tight on the edges, but the gaps open up towards the middle of the pieces....that is when I get burn through on the edges and through the metal. |
