Old 07-07-05, 10:07 PM   #1 (permalink)
shaking
does any one know what would cause a cruiser to start shaking like you have a blowout, when you hit a pothole in the road? When I pulled over and got out to look at it I couldn'r see any thing wrong so I drove a way's and everything seened fine, then a month later my wife was going down the same stretch of road and the same thing happened. anybody have a idea?????????????
mtbluetick is offline   Reply With Quote
Old 07-07-05, 10:12 PM   #2 (permalink)
what he said
Mace's Avatar
Death wobble..
Start looking at all of your steering links, spring bushings, wheel bearings, etc..
It is s omething in the front end that ia loose
I am kinda gay.......
I've set the bar, don't trip over it....
Old 07-07-05, 10:14 PM   #3 (permalink)
dd113's Avatar
knuckle stud torque/preload also
David Dearborn
www.urbanlandcruisers.com
Foreign Minister for life of the White Trash of the Elwood Chapter.
Visit our E bay store:
http://stores.ebay.com/Land-Cruiser-Stuff
I collect Hello Kitty
dd113 is offline   Reply With Quote
Old 07-08-05, 05:21 AM   #4 (permalink)
Tinker's Avatar
Shocks.
Mace, death wobble is on 2 wheels, no? Kinda worse than a tank-slapper?
Tinker is offline   Reply With Quote
Old 07-08-05, 07:29 AM   #5 (permalink)
Fearnofish!'s Avatar
Do you have play in the steering wheel? If no then I would go with the shocks. End links go pretty often too. I replaced mine but I had about 1.5" of wheel play. Maybe spring bushings are worn aswell? Good luck. I think there is cruizer tech guy in Missoula if you don't want to do it yourself. Not sure of his name though.
1984 FJ60
Forced rebuild in progress due to over abundance of deer.
Fearnofish! is offline   Reply With Quote
Old 07-08-05, 08:10 AM   #6 (permalink)
what he said
Mace's Avatar
Death wobble is when the steering wheel shakes uncontrollably.
It is very scary in a truck. And generally means something is loose in the front end. Generally bad shocks will mask the issues but it is not caused by bad shocks.
Nor is a good solution to it a new steering stabilizer.
Old 07-08-05, 06:57 PM   #7 (permalink)
I know what it is!!!!
I am a technician at a Mercedes dealership, mercedes have a similar steering setup to a landcruiser ie not rack and pinion. Anyway on the steering setup there is a shock which commonly goes bad on the benzs causing exactly what you just described. You hit a bump and the wheel starts to shake, the shaking will not stop until the truck stops. when you start off again, the wheel will be fine until you hit another bump in the road.
The good news it is a very cheap easy fix. If this doesn't solve your problem, you are out less than $50, $100 installed.
Dave
djanis99 is offline   Reply With Quote
Old 07-08-05, 07:05 PM   #8 (permalink)
Where are my keys?!
treerootCO's Avatar
Tighten eveything...u-bolts, shackels, wheel bearings, etc.
Worn tie rod ends will allow the tierod/draglink/relay rod to twist. It sounds weird, but jack up the front end and twist the tierod. You will see the wheel and tires turn left/right.
death wobble usually happens at 35mph for some strange reason.
Could be a bent rim or unbalanced tire as well
'95 FZJ80 - Sleed
'78 FJ40 and a few others...
Workin' on pimpin' the 80...
www.root45.com
www.risingsun4x4club.org
TLCA #14133
treerootCO is offline   Reply With Quote
