| That is the vacuum diagram for an FJ60. If you have a 2FE (FJ62 head on 2F block), then what you need is the vacuum diagram for the FJ62.
Do a search and either purchase or download a copy of the emissions manual. It will show each circuit on a separate diagram, which will make it easier to confirm that hoses are connected properly.
The four hoses identified connect in at the right side of the carburetor (the side next to the valve cover). The detail in the upper right side of your diagram is looking at the right side of the carb from over the valve cover. There are four corresponding vacuum pipes stacked one on top of the other coming in from the front of the carb. As shown in the detail, the top pipe is connected to the fuel cut port, the 2nd one down connects to the advancer port, the 3rd down to the HAC slow port and the bottom to the EGR port. Once you find the four ports on the carb, it should be pretty easy to figure out how to connect them.
