10-18-10, 05:54 PM
#1 | | Forum Regular
| Hand crank start? I still am in the honeymoon phase of owning my fj60 and have lots if questions. I noticed in the front it looks like there is a slot in the bumber to slide a handcrank through it and hook it up to the crank. Is that for starting it or for just bringing the engine to tdc? |
10-18-10, 06:41 PM
#2 | | Addict
| IIRC.........On USA spec FJ-60's it can't be used, as the radiator is in the way.
Zack |
10-18-10, 08:24 PM
#3 | | Addict
| It's for a PTO (Power Take Off) Winch. Do a search and see.
__________________ 87 FJ60 Stock...for now |
10-19-10, 07:18 AM
#4 | | Forum Regular
| Quote:
Originally Posted by JLH911 It's for a PTO (Power Take Off) Winch. Do a search and see. | It's certainly not for a winch. The slot in the bumper is only maybe an inch across and when I look down it I see the engine crank, not the tranny or tcase |
10-19-10, 07:48 AM
#5 | | Lifer
| I don't know why Toyota put it there, but having driven old vehicles that had the hand-crank provision that is exactly what that slot in the valence panel looks like. For it to be a PTO opening the shaft size to fit would be too puny to be of much use and I would expect it to be a hole rather than a slot. The reason for the slot is to clear the cross-pin in the end of the hand-crank. I don't recall my 2F having the necessary lugs on the crank bolt, and it certainly didn't have the clearance hole in the radiator, but that doesn't mean that other markets couldn't have received those. If it is for a PTO winch, how did it reverse?
__________________ My opinion is worth what you paid me for it. |
10-19-10, 10:28 AM
#6 | | 250+ Club
| I read somewhere that the crank bolt has the lugs on pigs and 40's through 1980. YouTube - HandCrankMovie.avi
__________________ What's in this drum marked flammable liquid? |
10-19-10, 11:22 AM
#7 | | Lifer
Join Date: Mar 2008 Location: Lehi, Porter Rockwell's home town
| Quote:
Originally Posted by ntsqd I don't know why Toyota put it there, but having driven old vehicles that had the hand-crank provision that is exactly what that slot in the valence panel looks like. For it to be a PTO opening the shaft size to fit would be too puny to be of much use and I would expect it to be a hole rather than a slot. The reason for the slot is to clear the cross-pin in the end of the hand-crank. I don't recall my 2F having the necessary lugs on the crank bolt, and it certainly didn't have the clearance hole in the radiator, but that doesn't mean that other markets couldn't have received those. If it is for a PTO winch, how did it reverse? | Mine had the lugs on the pulley retaining nut and it was made in Aug. 1985. It was absolutely for manual manipulation of the crank. There are also ports on either side of the front crossmember for PTO shafts. I can't imagine wanting to try and hand start it, but for valve adjustment/tune up procedures it would be convenient.
__________________ 1985 FJ60, 350HP TBI 350, NV4500, NP241, 14-bolt semi floater rear w/Elocker, 4.56 gears, SOA, four-wheel disk brakes, 35" BFGs, 405,000 happy miles. |
10-19-10, 02:47 PM
#8 | | Cruiser Curmudgeon
| It's for the hand crank. But all USA FJ60 have AC prep, so have the bigger (deeper) radiator that just drops down in front of the hole in the valance.
I've never started a 2F w/ the crank, but years ago we started our old F-powered FJ40s a few times w/ the crank, just for giggles. This is done by warming up the engine first (no way my skinny butt is gonna crank a cold engine to life), then using the timing adjust knob on the early dissy to fully retard timing, then energize ignition and crank the bar.
edit: I just watched the youtube link above. Yep, that is how it's done.
__________________ Thanks,
Jim C.
TLC Performance < Useful Parts FS>
Underhood Janitor, cleaning up other people's  since 1988.
"It works fine" <> Safe, Elegant or Correct |
10-19-10, 03:39 PM
#9 | | Forum Regular
| just as long as the engine doesn't backfire while cranking or you could seriously hurt yourself
__________________ Currently-83 FJ60, 85 4X4 pickup, 89 4X4 Ext cab pickup, 03 4runner, 06 Corolla
Formerly- 80 Corolla wagon, 84 4X4 pickup, 01 MR-S |
10-19-10, 03:59 PM
#10 | | Forum Regular
| The cog on the crankshaft is usually designed in a way that kicks the hand crank out of the cog if it backfires or starts up and turns faster than youre cranking by hand. Even with that, Ive heard of alot of broken thumbs and sprained wrists when using them.
I have a hand crank just like that on my 74 land rover
__________________ '88 62, H55, OME, ARB, Hydraulic winch, snorkeled, slidered |
10-19-10, 05:12 PM
#11 | | Forum Regular
| So if the rad wasn't in the way one could hand crank it? |
10-19-10, 05:16 PM
#12 | | Lifer
| Quote:
Originally Posted by IH8Wood | Yep, my old 40 had a crank bolt that would take a crank handle.
__________________ '87 FJ-Shemp driver
'92 Mini
TLCA #5448 |
10-19-10, 05:18 PM
#13 | | Lifer
| Quote:
Originally Posted by KonTiki The cog on the crankshaft is usually designed in a way that kicks the hand crank out of the cog if it backfires or starts up and turns faster than youre cranking by hand. Even with that, Ive heard of alot of broken thumbs and sprained wrists when using them.
I have a hand crank just like that on my 74 land rover | Yes, I recall the nut had a weird swirl shape.
'92 Mini
TLCA #5448 |
10-19-10, 06:00 PM
#14 | | Addict
| you learn something new everyday
10-20-10, 09:45 PM
#15 | | Lifer
| I know a guy who did some reporting for NPR in africa, and they hand-cranked 60 series cruisers as the "normal" way of starting. Batteries tended to be in poor condition I guess...
__________________ Doug G
Seattle, WA
TLCA#12671
1994 fzj80, 299,000 miles, 285X75/15, Billy's, dual batteries, daily driver
1987 fj60, 315,00 miles, 3" lift, 1" BL, 35X12.50's BFG KM2's, desmogged, dual battery, rear drawers, CB, tuffy, lockright, 4.10's, H41, 8274 |
10-21-10, 04:11 AM
#16 | | Forum Regular
| Quote:
Originally Posted by JLH911 It's for a PTO (Power Take Off) Winch. Do a search and see. | You do a search and see it's not......... |
10-21-10, 04:13 AM
#17 | | Forum Regular
| Quote:
I have a hand crank just like that on my 74 land rover | You making this up.......... |
10-21-10, 10:49 AM
#18 | | Forum Regular
| What part of that sounds made up?
10-21-10, 11:40 AM
#19 | | Stop calling it an FJ
| I have used the handcrank to start my Pig many times. Sometimes for fun or to win a bet, sometimes because I needed to. 55s have that same front valance hole.
There is a certain technique, and grip (don't wrap your thumbs around the handle) and the handles will bend if you're not careful.
It is handy for adjusting valves too.
__________________ TWRECKS, King of the Dinosaurs.
"Well it's a '68, '69, '70, '71, '72, '73, '74, '75, 76, '77 FJ55" http://forum.ih8mud.com/showpost.php...68&postcount=8 |
10-21-10, 12:25 PM
#20 | | Cruiser Curmudgeon
| Quote:
Originally Posted by Pighead It is handy for adjusting valves too. | That's why mine hangs on the pegboard in the main workbay.
Jim C.
