Originally Posted by Mark W
Sounds like something wrong with your ECU to me. I have taken 3 different 3FEs in FJ62s past 5000 a few times each. I have busted pistons in two different 3FEs taking them up around 5500. I do not push the 3F engines past 5000 any more. I have taken more past 4500. I set the upshift point at about 4500 usually when I adjust the kickdown cable on any 3FEI work on.
I have taken my daily driver FJ80 to about 4800.
Never encountered any sort of electronic rev limiter and I seriously doubt that there is one.
Mark...
What sort of failure in the ECM would cause it to cut out at high RPM? Signal from the distributor?
I'll try to take some video on Friday (since I leave for work when it is dark and get home when it is dark :( .....
