Old 11-02-09, 09:20 PM   #1 (permalink)
Power Steering is acting up!!! twitchy and jerky
Hello all
I just purchased another Bj60. While i was driving it home to Seattle last night i noticed that the power steering is very twitchy and every now and again it would jerk to one side on its own. It was a little hairy at times driving 65mph at night on the I5 in a cruiser that wanted to find it own way. This only happens when i'm driving relatively straight at higher speeds (around town parking ect it is fine, It does seem to need a little more input then other 60's that i've had before, its stiffer and more resistant )
Would any of you know what this might be? is it just a worn out front end (IE slack in the steering?) or is it related to the pump? I know very little about how PS pumps work.
any info would be greatly appreciated.
cheers
1985 Bj60 was daily driver (parked)
1986 Bj74lx
1980 Fj40 long term 3b and h55f swap project
1969 Fj40 Original stock rust free, being sold
1983 Bj60 Daily drive, garrett turbo project
Rustybones is offline   Reply With Quote
Old 11-02-09, 09:27 PM   #2 (permalink)
Steelhead Addict
alaska60's Avatar
TLCA# IOU41
Garage
could be pump? Have lookes at the drag link? or the TRE's? Look the whole front end over as there are many variables when it comes to drifting or your symptoms.
May 85' fj60 - "TONTO" SOA bunch a cool stuff, 400 plus horses!
April 85' fj60 "DUSTY" metalic brown. fully stock 90K
2001 Land Rover Disco 2
Skidoo XP 800 164" (my chairlift)
Wow, look at all the expensive **** in your sig line. Perhaps you should make the damned thing run, reliably, before dragging it thru an offroad catalog with a magnet attached! After all the work it took to install all that, I'd thinhk a couple of water leaks should be minor! ~TEXX (IH8MUD member) 10/09
alaska60 is offline   Reply With Quote
Old 11-02-09, 09:32 PM   #3 (permalink)
Alaska60
Thanks for the help, what is a drag link?
Should I just look for play in all steering components? Should I have someone move the steering wheel while i look at the front end move to see where there's some slop/slack???
1986 Bj74lx
Old 11-02-09, 09:42 PM   #4 (permalink)
Steelhead Addict
alaska60's Avatar
TLCA# IOU41
Garage
drag link is the first joint coming down off the pitman arm. it connects the steering rods to the gearbox off the pitman arm. has a little rubber boot around it with two smalll springs wrapped around it too.
Thats a perfect plan....have someone turn the wheel while you watch.
