Old 11-01-09, 07:57 AM   #1 (permalink)
Rookie
Inverted shackle yesterday...
Greetings. I have been lurking here for a couple months. I picked up an 88 FJ62 in May and have been working all of the "undisclosed bugs" out of it. Last night while out driving it over some harsh terrain, I heard the all too familiar rubber on fender sound. I hear it alot in my Chevy with 40" tires. This was the first time I heard it in the 62. My question is can I bend the leaf spring back into shape without harming the structural integrity of the spring? If the spring is shot, what is a good inexpensive comparable spring. I know there are a lot of spring options going new, but this is a weekend wheeler not a daily driver. Any help would be appreciated
RTCUL8 is offline   Reply With Quote
Old 11-01-09, 08:06 AM   #2 (permalink)
Butt Ugly Chuck's Avatar
TLCA# use'ta
Welcome to Mud!
Stock springs? A spring bent back into shape is always going to be compromised. Mudders installing a lift frequently hawk their old stockers in the classified section here.
Butt
Arcata, CA
7/85 FJ60 277K
For sale - 2f carb
Butt Ugly Chuck is offline   Reply With Quote
Old 11-01-09, 08:09 AM   #3 (permalink)
Doberdog chauffeur
sirenmoses's Avatar
Garage
what ^ said.
Also, depending on your location, you might be able to score some stuff out of Cash 4 Clunkers junked 60/62's.
My wheels are older than your highschooler:
Sept 84 tan fj60, 202k -- 2.5" BDS, 31's w/ al rims, Daylighters, Yakima w/sliders, hitch w/back-up lights.
to be installed: Rowlands panels, CB, grab handle, quick-stow dog barrier
home-built trailer (not by me) -- Kamp K9 (work in progress)
Oct 84 tan fj60, 265k -- saggin wagon (My lil sis's, once the BIL pays me )
85 Honda Accord, 120k -- DD
91 Kawasaki Concours, 50k -- 2 wheeld fun
sirenmoses is offline   Reply With Quote
Old 11-01-09, 09:29 AM   #4 (permalink)
sounds like something is very wrong, stock configuration should not inverse a shackle. I don't see how an inversed shackle would rub the tire, it would seem to me the rig would sit higher not lower?
bent spring=replace
broken spring=replace
those that fail to prepare are preparing to fail....Benjamin Franklin
1965 FJ45 LWB 2nd owner, 2F, 4speed, sprung over, 35"BFG Mud terrains
1965/67 FJ45 SWB combining 2 into 1 under construction
1970 FJ55 all stock
1980 FJ40 all stock, factory air and power steering, 82,000 miles
3_puppies is offline   Reply With Quote
Old 11-01-09, 09:33 AM   #5 (permalink)
Steelhead Addict
alaska60's Avatar
TLCA# IOU41
Garage
I would like to see the carnage...........................got a photo?
May 85' fj60 - "TONTO" SOA bunch a cool stuff, 400 plus horses!
April 85' fj60 "DUSTY" metalic brown. fully stock 90K
2001 Land Rover Disco 2
Skidoo XP 800 164" (my chairlift)
Wow, look at all the expensive **** in your sig line. Perhaps you should make the damned thing run, reliably, before dragging it thru an offroad catalog with a magnet attached! After all the work it took to install all that, I'd thinhk a couple of water leaks should be minor! ~TEXX (IH8MUD member) 10/09
alaska60 is offline   Reply With Quote
Old 11-01-09, 10:05 AM   #6 (permalink)
Rookie
Will get photos today...Should've mentioned Its SOA with 35" tires and tired stock springs. Bigger shock hoops and shocks though. No sway bars.
What springs will fit this particular situation? If I go with higher arched springs it will be too top heavy, I think.
Old 11-01-09, 10:09 AM   #7 (permalink)
Cut off the shackle mounts and move them in an inch or. Then run a longer shackle. You will have more articulation, a better ride and no more inverting. That is the very reason that I taught myself to weld years ago.
A daily driver 1985 FJ60, 300HP TBI 350, NV4500, NP241, 14-bolt semi floater rear w/Elocker, 4.56 gears, SOA, four-wheel disk brakes, 35" BFGs, 360,000 happy miles and still going due to a wicked case of wander lust.
lehiguy is offline   Reply With Quote
Old 11-01-09, 10:10 AM   #8 (permalink)
Steelhead Addict
alaska60's Avatar
TLCA# IOU41
Garage
I prefer a tired spring for the soa.
The soa rides better with an experienced spring rather than a new spring. My 2 cents.
Old 11-01-09, 12:56 PM   #9 (permalink)
Rando-kurūzā
Spike Strip's Avatar
TLCA# 17876
Spring steel is very resilient. It should bend back fine. In fact, I've seen them "bend back" after trail use and be fine.
But of course, this depends on the if there's a "crease" in the bend or not...
5/85 FJ60 -- A whole lotta crap and $$ that took 2 years of my life and pissed off the
6-86 FJ60 - current project - gonna stay stock.
Support MUD Vendors: www.marksoffroad.net
BEST WWII STORY EVER WRITTEN
Spike Strip is offline   Reply With Quote
Old 11-01-09, 02:40 PM   #10 (permalink)
specialk396's Avatar
For a wheeler only, I'd use Spike Strip's idea and run it for a while to see if it settled down(bent back into original shape).If it's not too rusted, it should be fine. Moving the shackle mounts seems like a good idea, as well.
'88 FJ62-Stock-125K- stock with lots o rust '88 Toyota Mini SR5 3.0 Ext. Cab P/U,7" lift,35s w/4.88's
specialk396 is offline   Reply With Quote
