Old 10-30-09, 02:50 PM   #1 (permalink)
Toadhopper's Avatar
TBI 350 Swap Clutch Slave Cyl. Question
This one goes out to those of you who've done the AA (Marks) SBC to Toyota MT installation using their bell housing. I've got an 86 60 and I'm going to replace the clutch slave cylinder and soft hose when I do the swap. In the AA manual, the instructions show adjusting the slave cylinder push rod. The post 4/85 60s are self adjusting and the pre 4/85 60s have the adjustable push rod.
Any advice on which one I should get? Do they both work?
Ant advice would be appreciated!
Bryan
86 60 2f/H55f, OME Med/Heavy lift, 33s on16X8s, SROR Sliders, ARB Lockers w/411s, Longs and Polys, TBI 350 built and going in soon.
"Never get out of the boat....absolutely goddam right, unless you were willing to go all the way"
Toadhopper is offline   Reply With Quote
Old 10-30-09, 05:17 PM   #2 (permalink)
inkpot's Avatar
TLCA# 10338
Howdy! I just made my own from a section of all-thread. Grind one end down to a ball like the stocker, to fit in the slave cylinder, and then I used a wheel nut against the clutch fork. Add an extra regular nut for a jamb nut once you get it adjusted right. $5 and 30 minutes, then your done. John
85 Toyota mini truck for chase/support!
CSC #41
inkpot is offline   Reply With Quote
Old 10-30-09, 05:37 PM   #3 (permalink)
TLCA# Associate Member/Sponsor
What Inkpot did will certainly work for awhile, but threaded rod is very soft/low grade, and a Toyota adjustable push rod just doesn't cost that much.
Downey's gone,
Jim isn't!!!
Downey is offline   Reply With Quote
Old 10-30-09, 06:56 PM   #4 (permalink)
Toadhopper's Avatar
OK so adjustable is the way to go?
Bryan
Old 10-30-09, 07:08 PM   #5 (permalink)
inkpot's Avatar
TLCA# 10338
Oddly enough, I did this because my stock rod bent. I forgot to mention that I used Grade 8 stock, and I think it is 1/2 or 5/8". Just small enough to fit thru the hole in the chevy clutch fork. It has lasted over 12 years so far. It's a lot bigger diameter than the push rod that came on my Piggy. John
CSC #41
Old 10-30-09, 07:46 PM   #6 (permalink)
Elbert's Avatar
TLCA# 17526
I have the AA setup with yota 5speed. Initially I used the stock slave cylinder for my 86 LC, but I had a problem with the slave cylinder rod over-extending and coming out of the slave cylinder. I then went to the adjustable slave rod and have not had the problem since then. Did have to cut down the length on the adjustable rod some though, to get it to work right.
My engine is a 5.7 vortec...not a TBI, but I don't think there would be any difference between the two in this regard.
1986 FJ60
5.7 Vortec
Elbert is offline   Reply With Quote
Old 10-31-09, 07:21 AM   #7 (permalink)
ginericLC's Avatar
TLCA# 7328
You can use an adjustable factory one after shortening it or you can make one as suggested. I did both on mine. I think I used a grade 5 bolt and never had an issue but there isn't a reason not to get a grade 8 so that is what I'd do.
Eric V. TLCA 7328 ADIDALC LICENSED OVERLANDER
99 UZJ100 "Barnicle Edition" Vorfab front bumper and sliders, MHHS diff drop, ARB front locker, 4x4 labs rear bumper with custom designed swingouts, OME springs/shocks/torsion bars
FJ68 PROJECT LEGO 60body/80chassis
PM me about Wagon Parts FS
"real environmentalists don't pave roads" "dents are like tattoos with better stories"
www.WildWildWestArt.com
ginericLC is offline   Reply With Quote
Old 11-06-09, 06:37 PM   #8 (permalink)
Toadhopper's Avatar
Saweet!
Thanks,
I'll call CDan and get the adjustable one and trim it down.
Bryan
