Old 10-30-09, 11:59 AM   #1 (permalink)
Real time help needed: Replaced plugs, wires, rotor, cap & now running rough
I just replaced my spark plugs, wires, rotor and cap. I did this all in one sitting and put everything back in the original orientation. Starts up just fine, but runs rougher than before and there's some hesitation upon acceleration. I was under the impression that if i replaced this components in their original orientation that no timing adjustment was needed... am I wrong? What else could be causing the roughness? Here's a video of it idling, hopefully you can hear a little bit of the rough idling.
FYI I used OEM Toyota parts for everything. I did not mess with the spark plug gap, installed them as they were sent to me.
http://www.youtube.com/watch?v=lxXjlI6WA-Q
nitro3421 is offline   Reply With Quote
Old 10-30-09, 12:44 PM   #2 (permalink)
Drunken Ira Hayes's Avatar
TLCA# 19280
You may want to check the gap on all of the plugs, it's definitely not a given that they'll be correct out of the box.
86 FJ60 SOA w/ 35x12.50 Pro Comp XMTs, 4.11s, Hysteer, H4 Conversion, etc.....
00 Tacoma w/ All Pro 2" and 33x12.50 BFGs
Drunken Ira Hayes is offline   Reply With Quote
Old 10-30-09, 01:14 PM   #3 (permalink)
krookedpandas's Avatar
TLCA# 18509
Make sure everything is nice and snug, could just be a lose wire.
-Matt
1987 60 series- OME, 33"s, 4.56, Aussie rear, SROR tube front & JK custom tube rear bumpers, Weber, Header, 1" BL.
1986 22RT-E truck- Know nothing about turbos.
LSLC Austin.
krookedpandas is offline   Reply With Quote
Old 10-30-09, 01:14 PM   #4 (permalink)
Sounds like the next step.
I did go through and find a couple of loose vacuum hoses & I fixed those. It idles better now, but still is pretty rough when in gear and below 1000 rpms or so.
Anything else I should check besides the spark plug gap?
Old 10-30-09, 03:37 PM   #5 (permalink)
So get this, I take out all the spark plugs and one of them had literally no gap. Not sure whether it was damaged during shipping or it got dropped or something, but this was the cause of the problem. It would have paid to check the gaps before installing them...
Old 10-30-09, 03:58 PM   #6 (permalink)
jeepgod's Avatar
Always check the gap of a plug before install. A gauge is less then 2 buucks
For Sale TRD Boost Gauge
2004 Saturn Vue 5spd (Wifes Car)
2003 Volkswagen Jetta 1.8T
1984 Toyota Land Cruiser FJ60
1969 Ford F100 69,000 miles
jeepgod is offline   Reply With Quote
Old 10-30-09, 07:05 PM   #7 (permalink)
Lesson learned, the hard way...
