Old 10-30-09, 09:00 AM   #1 (permalink)
SARCruiser's Avatar
Garage
Transmission crossmember questions/issues - pics!
I've hit a snag in my frame swap and it has to do with the transmission crossmember. My old frame (1987) has two triangular "horns" sandwiching each frame rail that the crossmember bolts to from underneath as seen below.
My new frame has four captured nuts on the inside of each rail where the horns on my old rail are located.
From what I've researched on here, it looks like those four holes are where the early-style crossmember bolted to the frame but I've never seen any pictures to confirm that. Am I correct?
The better question is if I get an early-style crossmember, will my '87 transmission bolt to it without any additional modifications?
Thanks!
1987 FJ60: Weber 38, header, OME Heavies, 31/10.5 BFG AT, 316k
1995 Acura Integra: Daily driver...ish
SARCruiser is offline   Reply With Quote
Old 10-30-09, 09:16 AM   #2 (permalink)
NocalFJ60's Avatar
Yes, mine has the earlier crossmember and has four bolts that bolt a brace to each side. The cross member sits on top of these braces on each side. You can see some of it in this thread.
http://forum.ih8mud.com/60-series-wa...l-82-fj60.html
You should be able make an older cross member work but there might be some minor differences like a different transmission mount that bolts to the bottom of the transmission. Also there might be minor difference on the placement of the transmission with the older mount. The 3F bell housing rotates everything behind it at a small angle so things mount different. I have a 3F bell housing and have the older mount.
1982 FJ60 SUA OME w/AAL's, 34's, H55F, 4.7 toybox
Northern California
TLCA/PMC Member
"He who throws mud only loses ground."
NocalFJ60 is offline   Reply With Quote
Old 10-30-09, 09:20 AM   #3 (permalink)
Cruiserdrew's Avatar
TLCA# 11734
This is a significant issue for you, because even with an older crossmember, your transmission will be rotated into the incorrect position by the later bellhousing. I would do something to either re-use your later crossmember, or scrap the existing crossmember and build a custom crossmember from scratch.
Andrew
Cruiserdrew is online now   Reply With Quote
Old 10-30-09, 09:36 AM   #4 (permalink)
SARCruiser's Avatar
Garage
Now I'm confused because SOR has the same part listed for 10/80-8/87 bellhousings. I thought the rotation didn't occur until the 3F bellhousing?
Old 10-30-09, 09:43 AM   #5 (permalink)
TLCA# 11734
3F bellhousing started in 85. Crossmember changed with the start of the 85 model year.
If SOR really lists it that way, they are wrong (which is unusual for them).
Andrew
Old 10-30-09, 09:49 AM   #6 (permalink)
Rum Runnin'
GLTHFJ60's Avatar
TLCA# 17825
Garage
To fix, you could carefully cut the frame mounts off of the old frame, bolt them to the crossmember, and the crossmember to the drivetrain assembly ( engine, tranny + transfer ). Use the motor mounts to locate where the crossmember mounts on the frame should be located. Push it into position then weld away!
Johnny C
Waiting to be installed:
Previous Rig:
1987 FJ60 - Big Red
ΦΚΤ - Fall 06
GLTHFJ60 is online now   Reply With Quote
Old 10-30-09, 09:53 AM   #7 (permalink)
SARCruiser's Avatar
Garage
This is the direction I'm leaning at this point except it's my trusty shop doing the work so it's more $$ into and already $$$ project.
Old 10-30-09, 10:06 AM   #8 (permalink)
Rum Runnin'
GLTHFJ60's Avatar
TLCA# 17825
Garage
Ah, gotcha. Good luck!
Johnny C
Previous Rig:
1987 FJ60 - Big Red
ΦΚΤ - Fall 06
Old 10-30-09, 10:12 AM   #9 (permalink)
SARCruiser's Avatar
Garage
Nocal, somehow I missed your post when I looked at this thread the first couple of times. So what you're saying is that you are currently running a 3F bellhousing and the early-style mount/crossmember and it bolted together fine? From that other thread it looks like the only modification that was done to the crossmember was to provide clearance for your longer front driveshaft due to having the toybox?
Old 10-30-09, 07:29 PM   #10 (permalink)
NocalFJ60's Avatar
That is correct. My 82 has the older crossmember and when I installed my engine and 5 speed I realized that the guy that bolted them together used a 3F bell housing. I didn't want to use the 3F bell housing but the 2F one has to be cut from what I have read. Instead of just changing out the bell housing I went with what he gave me and it worked. The 3F bell housing rotates the transfer case to a better driveshaft angle but is lower. One minor issue is my transmission was not perfectly centered in the hole in the floor and you can tell looking at the boot around the shifter if you look close but it is not much. The other issue is your transfer case shifter could lineup a little off too which could be an issue.
Northern California
TLCA/PMC Member
Old 11-10-09, 06:54 AM   #11 (permalink)
SARCruiser's Avatar
Garage
I just wanted to post up my resolution to this for anyone who finds this thread in a search. I ended up getting an early version crossmember and trans mount (thanks Mikesta!). The shop that was doing my frame swap for me got the engine and tranny in without changing anything else up. They did have to open up the bolt hols on my power steering gear box to get it to fit the holes on the frame but that was an easy fix. Driving it around since I got it back yesterday, I don't notice any substantial change in shifter position and I can put it in all 4 gears and reverse with no issues and the transfer case lines up just fine with the hole. So for the record: yes, you can use the early-version crossmember with the 3F bellhousing. I'll post up some pics this evening.
