Old 10-26-09, 11:47 AM   #1 (permalink)
Yspen's Avatar
"Cracks" in Cam gear
Should I replace the gear .
Yspen is offline   Reply With Quote
Old 10-26-09, 12:18 PM   #2 (permalink)
fliphkd778's Avatar
Yes. It is a lot of work to get to it. A new one is around $36 for an ITM solid replacement, or $72 for the last of the Mellings American made batch. I recieved the ITM one from norther auto parts. Also might want to check the clearance of the thrust plate.
-1986 Fj60-32x12.5 on stock rim, white roof, desmog, headers, hellas, surf racks, sunroof, springs so flat a yardstick sits flush
-1989 Porsche 944S2-3.0ltr pita to work on, why I bought cruiser
fliphkd778 is offline   Reply With Quote
Old 10-26-09, 12:37 PM   #3 (permalink)
Rando-kurūzā
Spike Strip's Avatar
TLCA# 17876
Yes. Solid one is better, too.
5/85 FJ60 -- A whole lotta crap and $$ that took 2 years of my life and pissed off the
6-86 FJ60 - current project - gonna stay stock.
Support MUD Vendors: www.marksoffroad.net
BEST WWII STORY EVER WRITTEN
Spike Strip is offline   Reply With Quote
Old 10-26-09, 08:48 PM   #4 (permalink)
fliphkd778's Avatar
Also, be careful when pressing out the old one, I put a 23 mm socket on the top like the fsm said, but it must have not been exactly centered or something because it crumbled the c clip lip.
Old 10-26-09, 09:18 PM   #5 (permalink)
what he said
Mace's Avatar
TLCA# Something
If you don't, you will be soon anyway..
After a very frustrating period of time wondering why the camshaft timing keeps slipping..
I am kinda gay.......
My Myspace
Old 10-27-09, 02:29 AM   #6 (permalink)
Yspen's Avatar
Great - so not too expensive - worth while to replace
Old 10-27-09, 08:37 AM   #7 (permalink)
fliphkd778's Avatar
What is the right way to press off the gear while we're on the subject?
Old 10-27-09, 08:54 AM   #8 (permalink)
When pressing gears off, I give a little heat from a torch to the gear. Just enough to get a little expansion, it makes them easy to remove.
To press on, I heat the gear in the oven to about 300 F, and if possible, freeze the the shaft (Cam in this case) for an hour of so. Many times the gear will just slide on.
Been doing it this way for more years then I like to remember.
Good luck,
Doug
Doug
TLCA 19157
1985 Fj60, H55, Full OME 3" Lift, 19 Gal Saddle Tank, De Smoged, Rebuilt 2F, 33X10.50 + 33X9.50 Spare, Tuffy Box, Custom Roof Rack, Safari Snorkle, Non-USA Canister Air Filter, SS Brake Lines, R134 A/C, Sliding Rear Windows, No Rust
doug720 is offline   Reply With Quote
Old 10-27-09, 05:08 PM   #9 (permalink)
fliphkd778's Avatar
Good luck,
Doug
Cool, will definitely try this with my new solid gear. I was speaking more about where to put the press on cam end or what to put between cam and press when removing it?
Old 11-05-09, 03:57 AM   #10 (permalink)
Yspen's Avatar
So the options are :
ITM part no 50060 about $30
Melling part no 2202 about $70
OEM part no 13523-60030 about ? ( SA Rand 800 about $100 )
What is the difference ? ( apart from price )
I need to order - I hope they ship to Africa
Old 11-05-09, 11:14 PM   #11 (permalink)
OlympiaFJ60's Avatar
TLCA# 12028/18228
You can also use the cam gear from a 3F, at-least the NA 3FE is solid, assuming the 3F is the same.
And the crank and cam gear are usually replaced as a set since they wear together.
OlympiaFJ60 is offline   Reply With Quote
