Old 10-22-09, 08:40 PM   #1 (permalink)
HeadacheManNYC's Avatar
Noisy valves, injectors, or exhaust leak?
My FJ62 has sounded like a diesel as long as i've known it. It's always run fantastic, but I have a clicking/ticking/tapping that is with me constantly. My cruiser mech (jose rivera, who knows his shit) has told me it sounds like a normal 62 engine to him, and if anything might benefit from a valve job, but i've read a lot on mud about exhaust leaks sounding similar to this. When starting cold, the sound is less present than when warmed up, and gets less noticeable again as speed increases. Most noticeable at idle, and got substantially louder after pulling my carpet (obviously). Any thoughts? Could it be the injectors?
Thanks all
Luke
89 FJ62 165K 31"s "HFS" seat covers, otherwise stock
97 Saab 9000 aero
89 Saab 900T
HeadacheManNYC is offline   Reply With Quote
Old 10-22-09, 08:47 PM   #2 (permalink)
Steelhead Addict
alaska60's Avatar
TLCA# IOU41
Garage
Heres my thoughts.... If it is less prevelent when cold, then the exhaust leak is not the issue. usually the exhaust leaks will quiet up when warm as the gasket will swell and fill in a bit. The valves however will get noisy with heat. simple valve adjustment.?......inline 6's do tick.
my 2 cents.
On a different note...do you know Jared from mud? he lives in your neck of the woods..... he did that trip to Alaska in his 60 this past spring.....cool Cat!!!
May 85' fj60 - "TONTO" SOA bunch a cool stuff, 400 plus horses!
April 85' fj60 "DUSTY" metalic brown. fully stock 90K
2001 Land Rover Disco 2
Skidoo XP 800 164" (my chairlift)
Wow, look at all the expensive **** in your sig line. Perhaps you should make the damned thing run, reliably, before dragging it thru an offroad catalog with a magnet attached! After all the work it took to install all that, I'd thinhk a couple of water leaks should be minor! ~TEXX (IH8MUD member) 10/09
alaska60 is offline   Reply With Quote
Old 10-23-09, 05:58 PM   #3 (permalink)
rfj62's Avatar
TLCA# 12498
Sounds like a normal 3FE to me.
THE BANE OF MY LIFE:http://forum.ih8mud.com/60-series-wa...g-me-back.html
3FE Remflex Intake/Exhaust gaskets for sale; http://forum.ih8mud.com/sale-parts/2...e-gaskets.html
Parting out an '88 FJ62; http://forum.ih8mud.com/parting-out/...ml#post4454780 I know someone needs an antenna
1989 FJ62 Stock **Trying to make a DD**
Fear is a mind killer
rfj62 is offline   Reply With Quote
