10-21-09, 06:14 AM
Gobble Gobble Wut?
JT high steer system
Ran across this high steer setup at Just Differentials and it caught my attention. I need to replace the U joints on my steering column and rework my steering to get rid of the bit of slop that's developing, and this looked like a much more solid setup than what comes factory. My questions are 1) is this even useable on 2" of lift and 2) is it even necessary when I won't be turning anything bigger than 33" tires at low speeds?
It sure looks purty for $300. and are those heim joints I see on the ends???
'88 FJ62 W/ 253K miles, desmogged, stock SUA W/ full length Add-A-Leafs, Tuffy console, LED interior lighting, Mallory ignition, Ford Contour electric fan, four wheel discs, Aussie sliding windows
Don't cry like a bitch when you feel the pain...
10-21-09, 08:34 AM
Steelhead Addict
The histeer kits are typically for the SOA conversions....this helps get the steering arms above the leafs.
It sure is purdy though.
The oem steering is pretty beefy too.........it lasted this long!!!!! 1988 - 2010!
I would fix the issues and it will more than likely be good for another quarter million miles!
May 85' fj60 - " TONTO" SOA bunch a cool stuff, 400 plus horses!
April 85' fj60 "DUSTY" metalic brown. fully stock 90K
2001 Land Rover Disco 2
Skidoo XP 800 164" (my chairlift)
Wow, look at all the expensive **** in your sig line. Perhaps you should make the damned thing run, reliably, before dragging it thru an offroad catalog with a magnet attached! After all the work it took to install all that, I'd thinhk a couple of water leaks should be minor! ~ TEXX (IH8MUD member) 10/09
10-21-09, 08:38 AM
Are you sure that isn't another Trail Gear set up being sold by someone else?
Ask them what country it is made in. If it's China, I would pass.
If you want high steer and you are spring under, 4x4 labs has custom arms that they bend just for that application, and then you can run the ultra beefy GM1 ton TRE's made in the USA by MOOG.
Andrew
10-21-09, 09:25 AM
Those look like TREs to me not Heims. The other thing I've found is that most aftermarkect toyota stuff is for mini axles unless specifically noted to fit a landcruiser. If you are interested in the kit I'd call and make sure it will fit your axle.
build-up: Family Haulin' FJ60
10-21-09, 09:55 AM
Even the picture seems to be right off the Trail Gear web site. Why do so many folks not like Trail Gear? I don't get it.
A daily driver 1985 FJ60, 300HP TBI 350, NV4500, NP241, 14-bolt semi floater rear w/Elocker, 4.56 gears, SOA, four-wheel disk brakes, 35" BFGs, 360,000 happy miles and still going due to a wicked case of wander lust.
10-21-09, 10:55 AM
Local Diesel Fanatic
looks identical to my Trail Gear Hy steer.
and with only 2" of lift im not sure if you would have clearance issues or not... i know with 4+ you should be fine.
[O] =TOYOTA=[O] = Mo Betta!
**84 FJ60 "Fiona", OME springs, anti inversion lift shackles, 33's, Front aussie, Rear Detroit, 4.56's, and exhaust..... For Now.... ROTW, 2F-E Swap**
**82 BJ42 SR and some 33x10.50-15's**
91 Honda Civic Hatch "Fry" with a JDM B20B CR-V Engine, with some bolt ons... Oh and it might have some nitrous there somewhere as well...
01 Dodge 2500 "Clifford" 5spd 4 door 4x4 Cummins Turbo Diesel with 4" turbo back exhaust, Quadzilla Adrenaline w/ Pulse, 90hp sticks, Valair Ceramic Clutch, Raptor 150 lift pump, and some 285/75/16 Treadwright MTG's Dyno'd 409.1HP/742.6FT-LBS on 4-11-09 Still NOT Enough POWER!!!
  Need A Cruiser Mechanic? Zismine4life@yahoo.com <----(Me/Trent)
I of course guarantee all of my work to be a professional installation / service.
10-21-09, 12:33 PM
Gobble Gobble Wut?
That's pretty much what I was thinking, only with MAF's 4+ tie rod and relay rod and the appropriate TRE kit (IIRC the 80 series TREs are required. Can anyone clarify?)
10-21-09, 09:52 PM
Dain Bramaged Member
If you put an FJ60 series TRE on the bench next to an 80 series TRE you will know. The 80 TRE is much bigger, about the size of a GMC 3/4 ton TRE.
For applications where HySteer is required you usually want to upgrade ALL of the steering components.
The 4X4 Labs set up is nice, but I'm not a fan of the double ended steering arm. I have the All Pro set-up and have had good luck with it so far.
Search is your friend.
Dan Johnson
What the large print giveth, the fine print taketh away.
Battle Born Cruisers
1975 FJ40, A couple of thingamajigs and a deally bob, fully integrated whatzits, dash board Hula girl (pending spousal approval.)
1998 pair of Pink Panties, now with a doohicky in the front.
1984 FJ60, Detroits F&R and a gawd awful spring lift.
Rust never sleeps.
10-21-09, 10:48 PM
4x4 labs makes both styles. Not all have the Frombe behind the axle tie rod. Check out my FJ60 and you will see.
Andrew
10-23-09, 08:58 PM
#10 (permalink)
If you put an FJ60 series TRE on the bench next to an 80 series TRE you will know. The 80 TRE is much bigger* about the size of a GMC 3/4 ton TRE.
The 4X4 Labs set up is nice* but I'm not a fan of the double ended steering arm. I have the All Pro set-up and have had good luck with it so far.
gm 3/4 ton and 1 ton tre's are pretty much the same , ford dodge , if you look at them all beside each other they are all the same size 7/8" -18 on the threads. some may look differnt due to differnt manufactures. fj80 is quite a bit smaller. i run extreme gear arms with mix and match 3/4-1 ton ends. ive put many marlin arms on rigs and they work fine. 4x4 labs has some nice arms tell them what you have they will set you up. they made a custom set of arms for an uncles 55. no prob. save our country and quit buying imported chinese crap like trail junk sells.
10-23-09, 09:02 PM
#11 (permalink)
[IMG]http://forum.ih8mud.com/attachment.php?attachmentid=280009&stc=1&d=1228440 **5[/IMG]
looks like ruffstuff soa kit. nice setup looks clean too.
