Old 10-12-09, 12:39 PM   #1 (permalink)
WAVEPIMP's Avatar
Clutch slips after running for a while
My pretty new clutch starts slipping after running around for a bit. Never did this before. It seems only to slip after everything is warmed up.
I had a new hydraulic clucth cylinder placed on (I think thats what you call it, mounted on the fire wall, the last one started leaking inside the truck) Ever sense then my clutch starts to slip when I have been running her a bit around town.
You guys have any suggestions?
Also I'm starting to get that death wobble when I go to slow down sometimes. I never use to do that either. It only does it sometimes and not all the time. Even sometimes when I hit a pretty good bump on the road it will do it. I don't think the rotors are warped. I think it something else.
I have a 4" reverse shackle lift on the vehicle. Its the old man emu lift with reverse shackles.
Any ideas on this? I have heard of people having this problem, but never heard the resolution.
James
League City, Texas
85 fj60
WAVEPIMP is offline   Reply With Quote
Old 10-12-09, 12:42 PM   #2 (permalink)
Local Diesel Fanatic
CruisinFJ60's Avatar
TLCA# 16781
as for the clutch could be the adjusting rod isnt quite right, but thats one id have to mess with to know more of how it is acting.
and for the wobble likely something loose in the front end.
Get it to me and i can get it fixed for ya, i can even pick up if needed for cost of fuel.
[O]=TOYOTA=[O] = Mo Betta!
**84 FJ60 "Fiona", OME springs, anti inversion lift shackles, 33's, Front aussie, Rear Detroit, 4.56's, and exhaust..... For Now.... ROTW, 2F-E Swap**
**82 BJ42 SR and some 33x10.50-15's**
91 Honda Civic Hatch "Fry" with a JDM B20B CR-V Engine, with some bolt ons... Oh and it might have some nitrous there somewhere as well...
01 Dodge 2500 "Clifford" 5spd 4 door 4x4 Cummins Turbo Diesel with 4" turbo back exhaust, Quadzilla Adrenaline w/ Pulse, 90hp sticks, Valair Ceramic Clutch, Raptor 150 lift pump, and some 285/75/16 Treadwright MTG's Dyno'd 409.1HP/742.6FT-LBS on 4-11-09 Still NOT Enough POWER!!!
Need A Cruiser Mechanic? Zismine4life@yahoo.com <----(Me/Trent)
I of course guarantee all of my work to be a professional installation / service.
CruisinFJ60 is offline   Reply With Quote
Old 10-12-09, 02:53 PM   #3 (permalink)
4lux's Avatar
Did you replace the rearmain seal? Mine slips when it's warmed up and the oil starts leaking on the clutch disk out of my leaking rearmain seal.
84' FJ60 stock as a rock at this time. But, big plans are in store.
4lux is offline   Reply With Quote
Old 10-12-09, 05:00 PM   #4 (permalink)
springfield user
brian's Avatar
TLCA# 6955
death wobble issue:
sounds like it's time for you to do a front axle overhaul. your trunion/kingpin bearings are getting to be toast.
it's only metal, we can out think it.
77-fj40 20th anniversary edition
87-fj60 216K mile DDer
93-fzj80 mall crawler
toyota material distribution center. your source for Factory Service Manuals.
they're alot cheaper than you think.
1-800-622-2033
brian is offline   Reply With Quote
Old 10-13-09, 06:20 AM   #5 (permalink)
WAVEPIMP's Avatar
How hard is it to replace the rear main seal?
How hard is it to do a front axle overhaul?
I will check the adjustment first, don't you access this from the inspection cover at the gear shift?
Thanks again guys
James
League City, Texas
85 fj60
Old 10-13-09, 08:25 AM   #6 (permalink)
4lux's Avatar
To replace the rear main seal you need to pull the trans. and transfer case out and the clutch and flywheel. From there it is pretty straight forward, just alot of work to get there.
Old 10-13-09, 09:28 AM   #7 (permalink)
Steelhead Addict
alaska60's Avatar
TLCA# IOU41
Garage
Originally Posted by brian View Post
death wobble issue:
There are so many different variables when it comes to the death wobble. It is not accurate to pinpoint an area that is causing it with out going through them all.
May 85' fj60 - "TONTO" SOA bunch a cool stuff, 400 plus horses!
April 85' fj60 "DUSTY" metalic brown. fully stock 90K
2001 Land Rover Disco 2
Skidoo XP 800 164" (my chairlift)
Wow, look at all the expensive **** in your sig line. Perhaps you should make the damned thing run, reliably, before dragging it thru an offroad catalog with a magnet attached! After all the work it took to install all that, I'd thinhk a couple of water leaks should be minor! ~TEXX (IH8MUD member) 10/09
alaska60 is offline   Reply With Quote
Old 10-13-09, 11:33 AM   #8 (permalink)
TLCA# 16781
my offer still stands.
Old 10-13-09, 03:45 PM   #9 (permalink)
If yours is an '85, you may not have and adjustable rod between the slave cylinder and the release arm. Seems odd that it started right after replacing the MC. I did a new clutch years ago that did the same thing. It had very little holding power. I ended up having the shoulder of the flywheel cut just a bit deeper that what is nomally called for. That results in the springs of the pressure plate being compressed more when the clutch is engaged. Bottom line, it worked and never slipped again. But you might start with trying the bleeder on the slave cylinder once everything is hot since that is when the issue seems to happen. I would be curious to know if there is pressure there. If so, fluid will shoot out. It should just trickle out.
A daily driver 1985 FJ60, 300HP TBI 350, NV4500, NP241, 14-bolt semi floater rear w/Elocker, 4.56 gears, SOA, four-wheel disk brakes, 35" BFGs, 360,000 happy miles and still going due to a wicked case of wander lust.
lehiguy is offline   Reply With Quote
Old 10-13-09, 07:25 PM   #10 (permalink)
jfnall's Avatar
could you have put the clutch disk in backwards?
_________________________________________________
85 FJ60 239K, white of course, built 2F, desmog, Wilderness rack, ARB, Warn, OME, snorkel, ladder, awning........
07 FJ Cruiser - wife's ride
02 Harley - Ultra Glide custom
97 Harley - Heritage Springer
jfnall is offline   Reply With Quote
Old 10-13-09, 10:10 PM   #11 (permalink)
cando john's Avatar
bleed the line again sounds like it still has some air in it ... as it heats up it expands and you get the spongey feeling just like brake systems do ..... my $.02
83' fj60 .... 4"MAF lift.. cooper stt 33"x12.5 x15 on 8" rims and locked
cando john is offline   Reply With Quote
Old 10-17-09, 07:20 AM   #12 (permalink)
jeepgod's Avatar
Clutch slipping
Ok I have the same problem I just took the cruiser out for its first long drive in over a year. when I got it the clutch resivor was empty so I put new fluid in and bleed it. I can't find where the fluid leaked out form either. I looked at all the usall places. we went for a drive through the city and we went up a hill and the clutch stated to slip not enough to smell it burning but the motor was reving faster then we were driving. What should I do to fix this I dont have the means or time to put a new clutch in.
For Sale TRD Boost Gauge
2004 Saturn Vue 5spd (Wifes Car)
2003 Volkswagen Jetta 1.8T
1984 Toyota Land Cruiser FJ60
1969 Ford F100 69,000 miles
jeepgod is offline   Reply With Quote
Old 10-22-09, 07:25 AM   #13 (permalink)
Jeepgod- just had a similar experience as yours- all I did was unbolt the slave cylinder, bleed it and rebolt it- the problem went away. Actually going back, I would have just tried bleeding it first without removing it.
jzmq is offline   Reply With Quote
Old 10-23-09, 10:54 AM   #14 (permalink)
WAVEPIMP's Avatar
Ok just so I'm on the same page with you guys, where exactly is the slave cylinder? Is that under the vehicle against the transmission? Or up under the hood on the fire wall.
Never really had to mess with one before and I want to make sure I have the Terminology correct.
James
League City, Texas
85 fj60
Old 10-23-09, 12:53 PM   #15 (permalink)
jeepgod's Avatar
The slave cylinder is the bottom half of the hydraulic system for the clutch. It is located in front of the transmission on the passenger side. It connects to a rod the connects to the clutch fork. If you look at the starter it is off to the side of it. You can also follow the fluid line form the clutch master cylinder to find it.
I am not sure of a air pocket could let the clutch spin can someone explain that to me. Also should I bleed it again warm or cold.
Old 10-23-09, 01:15 PM   #16 (permalink)
84CRUISER's Avatar
I have seen this many times with installation of brake of clutch hydraulics. most likely the linkage rod is too tight and when the fluid warms up it expands ever so slightly and pushes the clutch. What is the pedal freeplay feel like?
Also if there was any oil accidently put in the master cylinder it will do this. Ive seen people unknowingly put motor oil in their master cyl. Oil expands alot when warm, especially when put under pressure. Ive seen brakes actually apply and lock while driving. An expensive mistake. the oil will ruin the rubber seals in the master, abs valves and calipers.
Jeep this!
Castle Rock Crippled Cruisers
1984 fj60, aal rearch, 3"+shackles. TBI, 33's
1986 fj60, SOA.
84CRUISER is offline   Reply With Quote
Old 10-23-09, 01:46 PM   #17 (permalink)
jeepgod's Avatar
Thanks that explains it. expansion of the fluid I will bleed it when it is worm and see what happens.
Old 10-23-09, 02:15 PM   #18 (permalink)
WAVEPIMP's Avatar
I figured that was it, just wanted to clarify. i really appreciate all the good advice guys.
I don't think the pressure plate is in backwards due to the clutch being in over a year, but the new cluth master cylinder is only several months old. I will check all these things out and see what turns up.
Again, Thanks
James
League City, Texas
85 fj60
