Anyone who has worked on their EFI knows that a pressure gauge is an integral part of troubleshooting. But after checking on the price of one (about $250 for a quality unit made by OTC with the fittings to hook up to my 3FE) I came up with a cheaper alternative.
I just bought a cheap generic fuel pressure tester with a 0-100 psi gauge and about $10 worth of hardware. Total cost was under $50
The only tricky part is making the banjo bolt to go into the cold start injector. I drilled the center hole on my lathe and the two holes through the side with a drill press. (see photos) Just remember that one of the side holes goes through the existing injector fitting and the other comes out in the "T" to feed pressure to the gauge.
1 - 1/4 in "T"
2 - 1/4 in plugs
1 - 1/4 x 1/4 (pipe on one end, flare on the other)
1 - 8mm x 60mm bolt (1.00 pitch)
1 - copper washer
The flare fitting hooks up to the gauge (that I didn't take a picture of) and sorry I don't have photos of it hooked up. I will probably hook it up again this weekend as I am still working on an engine gremlin and I will snap a photo to post.
But it worked great and I still have money to spend on my wagon!
Tony
1 - 1/4 in "T"
2 - 1/4 in plugs
1 - copper washer
Tony
