Old 07-04-09, 12:58 AM   #1 (permalink)
Mixed Napa Green Coolant and Prestone Green. Any problems?
Long story short, someone else added NAPA brand green coolant to my truck's cooling system. Before this, I was running only the yellow Prestone pre-diluted 50-50 coolant.
A substantial amount of the NAPA stuff was added, should I worry about these 2 coolants mixing? Do I need to flush it out?
Thanks.
-Bryan
Edit: Title of thread is wrong, originally had the yellow Prestone pre-diluted Coolant.
89 FJ62- w/ an H42 and other stuff
Bryan062087 is offline   Reply With Quote
Old 07-04-09, 10:30 AM   #2 (permalink)
Tinker's Avatar
I don't think any of the normally-available coolants are incompatible. You're OK.
"His mudder was a mudder".
Tinker is offline   Reply With Quote
Old 07-04-09, 10:47 AM   #3 (permalink)
2mbb's Avatar
Garage
I did a little reading. Some coolants have low silicates, others don't. If you mix too much of one with the other, you lose some of the "heavy duty" corrosion protection offered by the low silicate formulas. My guess is these coolants have been specially formulated for engines with dissimilar materials such as an iron block and aluminum heads.
I agree with Tinker that you should be OK.
mbb
1985 FJ-60
2mbb is offline   Reply With Quote
Old 07-04-09, 11:01 AM   #4 (permalink)
Somewhere on this board I thought I saw mention to not using the Dex Cool GM type coolant with the green stuff. Maybe I dreamed it. The concern was that they did not mix together and you got pockets of one type that did not circulate as well. May be a myth, but I am good at perpetuating that.
86 FJ60, Champagne Bronze, 33X9.5s, Desmogged, Dynamat, ARB in rear, 4.11 gears. OME lift, bedliner on rocker panels. Tint, H55.
1987 FJ60 Dark Blue Metallic, 31X10.5s, 130K, Desmogged.
"When you subsidize poverty and failure, you get more of both"
Heartworm is offline   Reply With Quote
Old 07-04-09, 11:35 AM   #5 (permalink)
fliphkd778's Avatar
Taken from a respected porsche authority,
"Porsche recommends using a phosphate free anti-freeze in the aluminum engines used on 944s. Standard glycol type anti-freeze which contains phosphates will cause minerals to plate out on the heat transfer surfaces inside the engine. I've read that it isn't really isn't necessary to use phosphate free anti-freeze in the United States because most water systems have a very low mineral content. However, this doesn't take into account those who have private wells. I figure better safe than sorry. Phosphate free anti-freeze used to be a little hard to find. However, it's becoming much easier to find now days. I personally prefer Prestone Extended Life because you can buy it almost anywhere and it's not that expensive relative to other anti-freeze brands. Be suspicious of anti-freeze that says, "Safe for Aluminum Engines" on the label. Unless it specifically says "Phosphate Free" on the label, it probably isn't."
-1986 Fj60-Bored out 2f delta ground cam bumping z28 valve springs, 32x12.5 on stock rim, white roof, desmog,, hellas, surf racks, sunroof, springs so flat a yardstick sits flush
-1989 Porsche 944S2-3.0ltr pita to work on, why I bought cruiser
fliphkd778 is online now   Reply With Quote
Old 07-04-09, 12:57 PM   #6 (permalink)
IH8Wood's Avatar
I doubt it makes any difference in an FJ60.
What's in this drum marked flammable liquid?
IH8Wood is offline   Reply With Quote
Old 07-04-09, 01:19 PM   #7 (permalink)
Pants on da ground !!
Spike Strip's Avatar
You mean the "Yellow" Preston, as Yellow bottle ? If yes, that's the same stuff
5/85 FJ60 -- A whole lotta crap and $$ that took 2 years of my life and pissed off the
6-86 FJ60 - current project - gonna stay stock.
Call Mark! His carb rebuilds are awesome! www.marksoffroad.net "Mark saved my cruiser!"- Calico Kid. "Mark cured my Leprosy and baldness." Polynesian guy on the beach.
BEST WWII STORY EVER WRITTEN
Spike Strip is offline   Reply With Quote
Old 07-04-09, 01:27 PM   #8 (permalink)
not an addict
nuclearlemon's Avatar
you don't want to mix dex cool because it's an extended service antifreeze. never mix extended with old school green antifreeze. all greens can mix, but as mentioned, you may affect some anti corrosion properties. not a problem if you flush your system every so often and replace with fresh coolant.
mixing extended service and green coolants can cause bad gelling. also, many extended service coolants won't mix with other extended service coolants, so be careful there. fleetguard makes an es coolant that does mix with others, so if you need to, look for it. it will be blue in color.
"to learn is to teach someone else"
only four cruisers left
nuclearlemon is online now   Reply With Quote
