Old 07-03-09, 05:41 PM   #1 (permalink)
Picture Problems
I have been trying to upload a few pictures today and keep getting error messages. These are pictures that have not uploaded in the past. I loaded a couple from old posts, no problem. File size is good...any idea's?
Doug
Doug
TLCA 19157
1985 Fj60, H55, Full OME 3" Lift, 19 Gal Saddle Tank, De Smoged, Rebuilt 2F, 33X10.50 + 33X9.50 Spare, Tuffy Box, Custom Roof Rack, Safari Snorkle, Non-USA Canister Air Filter, SS Brake Lines, R134 A/C, Sliding Rear Windows, No Rust
doug720 is offline   Reply With Quote
Old 07-03-09, 05:58 PM   #2 (permalink)
Kynot62's Avatar
Send a PM to the moderators
Tony
1990 FJ62, ARB Lockers, 4.88's, Front and rear winches, OME lift, U-bolt flip kit, 33" BFG A/T's, Roof rack, Custom bumpers, Full Float rear, Dual batteries, Rock Sliders and Qtr guards, Lots of small changes
1982 BJ 60 460K kilometers and counting. See www.Raincountrycruisers.com for the rebuild
Kynot62 is offline   Reply With Quote
Old 07-04-09, 06:16 AM   #3 (permalink)
Just what you'd expect
Tofudebeest's Avatar
Use photobucket.
Tofudebeest is offline   Reply With Quote
Old 07-04-09, 08:11 AM   #4 (permalink)
2mbb's Avatar
Garage
Tony
x2 or go to the mud help forum
I mostly just use paint, which is software that is provided with windows. I have other programs that make it a little easier, but paint works just fine.
Open your picture in the application. You will need to resize the picture to a maximum of 800 x 800 pixels. In paint the image/attributes command will tell you how big the picture is. Then use the image/stretch/skew command to resize the image. to reduce a 1600x1200 pixel image to 800x600 enter 50% in both the horizontal and vertical stretch boxes. Select OK and your image will resize. The select File/Save as to save the file. Be sure to select an appropriate file type. I generally use JPEG.
I think more important than the bit-size of the file is actually the pixel size of the image. The image can be no larger than 800 tall by 800 wide. Good Luck.
mbb
1985 FJ-60
2mbb is offline   Reply With Quote
