Old 07-02-09, 08:37 PM   #1 (permalink)
t case shifting
I feel a positive shift from 2h to 4h, but the lever will easily move left and right while in the low position. I can't even find N let alone 4L. Am I even in 4h?
I don't use 4lo very much - clearly.
what up?
nmarshall-no is offline   Reply With Quote
Old 07-02-09, 08:57 PM   #2 (permalink)
what he said
Mace's Avatar
Soundsa like your linkage is broken in the low/high position.
There should be a significant difference in gearing.
The difference between 2wd and 4wd is not as noticeable (unless you need 4wd )
I am kinda gay.......
I've set the bar, don't trip over it....
Old 07-02-09, 10:52 PM   #3 (permalink)
2mbb's Avatar
Garage
There are two shift arms on the transfer case. Linkage goes from the shift lever to both. One engages the front drive shaft (2wd vs 4wd). The other shifts the transfer gear from high to neutral to low. As mace said, it's probably something wring with the transfer gear linkage. You can see the linkages from under the truck on the passenger side of the transfer case.
mbb
1985 FJ-60
2mbb is offline   Reply With Quote
