09-29-09, 07:30 AM
#61 (permalink)
Engine Belt Routining
I managed to put on all my accessories this weekend and now need to put the belts back on.....Anyone have a diagram of how the belts are routed?
Thanks!
BritKLR
09-29-09, 08:00 AM
#62 (permalink)
I can take a picture for ya. On your wheel bearings. Did you replace the race too?
74 FJ40 Mustard Yellow 2.5" procomp springs, rancho 5000s, sr5 seats, 32x11.50 BFG A/Ts awaiting 2f, h55f with split case to be installed.
87 FJ60 White 3"ome heavy,4plus flipkit, 33x10.50 BFG A/Ts on Eagle 589s, mwalls54 f+r bumpers with rock sliders/steps and rear 1/4 protection, mean green, H55f, hella h4 and 4000s, LED cargo lights. warn 9500ti, a lot of non usa parts on the dash.
WV Mountaineer Cruisers TLCA Delegate
Tornado Alley Cruisers
09-29-09, 09:11 AM
#63 (permalink)
Resist much, obey little.
I like the ladder on the bumper. That's a neat solution. Do you find it wobbles when you're up on top of it? Is that an available option with that bumper or did you make it?
Nice KLR, too. Love the old Kawasaki Land Rover!
"Freedom, not safety, is the highest good. " — Edward Abbey
"Gojira" - 1984 FJ60, 2F, 3" OME, 33's, Lock Rights, H55F, XD9000, it's dark, and we're wearing sunglasses.
09-29-09, 09:36 AM
#64 (permalink)
Hi Matt-
Hope your feeling better!
I did replace the race aswell.
Thanks!
BritKLR
09-29-09, 10:36 AM
#65 (permalink)
Originally Posted by britklr
Hi Matt-
Thanks!
by the end of the week my back was better. Figures, Just a sign to not go to GATOR.
as for the belts, starting with the closest grove on the crank to the block,
crank to ac
crank to water pump to smog pump
crank to power steering to alternator
11-17-09, 06:18 AM
#66 (permalink)
Update - Problem
Need some help here. I've installed new front/rear bearings/seals, New brakes front/reaf, New drive shaft unjoints and balanced the DS, rebuilt T-case, H55 Tranny, New clutch/TO bearing, ARB lockers front and rear, new 4.56 gears front and rear.
Before the upgrades it drove smooth and solid, now when I hit 65 mph I get a solid rumble/vibrations. I've rotated tires/wheels and taken the DS off and rotated it (Phasing).
Now I have no idea what to do....Any suggestions would be appreciated.
Thanks!
BritKLR
11-17-09, 06:27 AM
#67 (permalink)
Wow, that's a whole heap of different improvements that could be causing the vibes.
Good luck narrowing the problem down. My first thought would be driveshaft but you seemed to have covered that. Any way someone could let you borrow a spare just to make sure? Seems like an easy way do dismiss that part of the equation.
'87 FJ-Shemp driver
11-17-09, 07:32 AM
#68 (permalink)
Update - Problem.......
Thanks!
Just a thought,
Our Volvo started doing that a while back. The steering wheel felt like machine gun Charlie after 60 mph. Turns out that one of the little weights they use to balance the wheels had come off one wheel. Re-balanced and it smoothed out.
Edit: I also hit a nasty pot hole once and started getting a similar issue. Turns out that the impact had snapped one of the steel belts in the tire and was causing a bulge to develop causing a slight "thump, thump" noise and vibration. Where I live the roads are pretty nasty.
William
11-17-09, 08:04 AM
#69 (permalink)
I might add that I put new TRE's on the front and a front end alignment was done.
Update - Problem
Thanks!
BritKLR
11-17-09, 09:03 AM
#70 (permalink)
Knuckle bearing preload issue? Double check the toe-in? I've been told that a loose knuckle build or excessive play will cause wobble. So maybe shim packs weren't gauged properly???? Loose hub nut?
83 FJ60-5" ALCANS-HYSTEER-80 TRE's-RICEBUILT RODS-AUSSIELOCKER-ARB DeerSlayer-LONGFIELDS-35" MTR's-BILSTEIN 5150's-Warn M8000-Ultimate Air-Defender Rack-Rising Sun Roof Clamps-Yukons-Tailgate Storage-Thanks Ige-Groucho-EricS-Corbett-Schmoozer-DurangoDDS-Zen80-Marlin-Bobby-JimC-Proffitts-WagonGear
11-17-09, 09:26 AM
#71 (permalink)
Thanks!
We rebuilt the knuckle bearings aswell. Replaced the shims the same way they came out and did the "scale" test and everything checked out. I redid the front hub bearings and did notice the passenger side bearing seemed a bit light after doing the scale test on the hub. I'll check that one, but I don't get any vibration in the steering wheel.......
BritKLR
11-17-09, 09:36 AM
#72 (permalink)
Oh....maybe I misunderstood....The vibrations don't translate to the steering wheel? You sure the driveshaft is phased properly? I hope its not a diff issue
11-17-09, 12:41 PM
#73 (permalink)
Trapper50cal-
Thanks again for your suggestions and I'll check the front axle just in case.
I really hope it's not the diffs. The ARB's and Gears were set-up by a reputable company so I can't imagine that they're the problem, but I'd be really curious if anyone else has ever had a rumble/vibration problem from new diff gears and ARB Lockers.
BritKLR
11-17-09, 12:53 PM
#74 (permalink)
A better description of the rumble/vibrations maybe in order.
As you approach 60 mph your hear and get a general rumble/vibration in the entire truck. At first I thought since it was a windy day it was turbulence off my roof rack, but as I changed directions on the highway it stayed the same.
The rumble/vibration is felt throughout the entire truck. Nothing isolated to the steering wheel. You feel it in the seat of your pants.
At 65 mph, you can push in on the clutch and the rumble/vibration is still there. If you slow down or speed up it seems to disappear.
BritKLR
11-17-09, 01:16 PM
#75 (permalink)
well, sorry I'm not more knowledgable....tires all balanced? maybe it has nothing to do with the new work persay....maybe a balancing weight got knocked off one of the tires. Can it be localized to originating from front or back? or is it just all over?
11-17-09, 01:23 PM
#76 (permalink)
KOOL AAROW
make sure the shaft is in phase
82 FJ60 5.3, 4l60E, OME Heavy, 33 KM2's 410's, ARB bull & side bars ...SOA in the works
85 FJ60 Trail beater SM 420 crawler box lockers 456, 4D's bobed & choped with a Metal Tech cage
GIT-R-DONE!!!!
TLCA #15374
low riders want SWITCHES... 4 wheelers want SHIFTERS
www.jkcustoms.com
11-17-09, 02:23 PM
#77 (permalink)
Kling-on-
Any suggestions on how to make sure it's phased?
Since everything in the front and rear diff came out and was replaced with new and the DS had new ujoints and was balanced my original alignment marks are no longer any good.
Thanks!
BritKLR
BritKLR
11-17-09, 06:49 PM
#78 (permalink)
if you remember mine had a vibration in it when we were in moab. well after driving it alot more it never went away. I put in this Center Bolt Spacer and i have little to no vibration at all.
11-18-09, 08:12 AM
#79 (permalink)
Matt-
Thanks for the suggestion. How does this bolt help? Since it didn't vibrate prior to the upgrades would it now show-up due to all the new parts?
BTW-I'm really sorry to hear about what happened to your home. I hope everything works out.
P
BritKLR
11-18-09, 08:35 AM
#80 (permalink)
That's sounding more and more like a diff/pinion issue
11-18-09, 09:57 AM
#81 (permalink)
What is a diff/pinion issue?
The gears are all new 4.56's. and bearings in both the front and rear diffs.
They are Serria gears and installed at the sametime as the ARB's by mud vender. Is there anything I can do to check them?
Thanks JMRINS!
BritKLR
BritKLR
11-19-09, 01:55 PM
#82 (permalink)
Weekend
Lets get together this weekend and check it out. You have probably gone over it a 100 times, but maybe we can spot something else.
Ex
FJ60 - Chevy 5.7L V8, H55F. Alcan 4", 4.56's, Aussie locked f/r, Longfield axles, 33X10.50-15, dual Optimas, SROR rear bumper/sliders, TJM front bumper, 8K Warn, Tuffy console.
11-21-09, 12:47 PM
#83 (permalink)
Update-
Hanging out on Saturday waiting to work on the vibration and thought I'd work on locating my ARB compressor in the rear quarter.
See how it goes.
Notice anything under the hood??? My next project is to plumb in a fully "smogged" airbox that will work with my snorkel...
I'll LYK what we findout about the vibration.
Thanks.
BritKLR
11-21-09, 03:15 PM
#84 (permalink)
Ex
Thanks B!!!!!
Well, with exrsa1's expertise, he narrowed it down to the drive shaft. We checked tire pressure, removed the rear DS and ran it on the front DS. He disassembled the rear DS at the yoke and rotated 180 degrees and we put it back in and it stopped the rumble/vibration!
Now, I will be calling the DS company that did my DS and UJ's and express my concern since they are the ones that installed the new U's and balanced it (or so they said)...anyway, thanks to everyone that gave advice! I really appreciate it!
BritKLR
11-21-09, 06:38 PM
#85 (permalink)
Glad you got it tracked down....nothing worse than a bad vibration, especially since you've gone through such an extensive redo. Nice Truck!
11-21-09, 08:06 PM
#86 (permalink)
Glad it was simple, good on yah (or do Aussie expressions irk the English?)
Where did you get the airbox assembly for use with the snorkel? I'm thinking
about doing this myself...
