06-28-09, 11:48 AM
| | Forum Regular
| RT Help needed - electrical problem... ...and on vacation - so I don't have my local resources (my mechanic).
All interior lights not working (clock, dome, parking lights, heater, tail/brake lights - the biggest problem).
Strange thing is that headlights do work.
I checked all fuses and are ok.
What should I look at next?
__________________ 89 FJ62 173k OME 33's Hella 500s Thule Rack
03 UZJ100 70k bone stock - for now |
06-28-09, 12:05 PM
| | 250+ Club
| sounds like you have a problem with a ground wire that has come loose and is shorting out your elecronics.
do you have a repair manual, or FSM?
i would find out what circut all of those accessories are on and look for the loose wire.
do you have any trailer lights set up or spliced into the taillight wiring? this is a common spot for shorts to occur.
get a voltmeter and find out where the problem is at...
another thing to try would be to TAKE OUT each of the accessory fuses one by one, and when you find what circut the problem is on, some of the other accessories will probably come back to life.
__________________ *'80 2WD,murdered by gaper.Rust Into Pieces,'00
*'80 4WD,RIP'02 *'84 4WD,RIP'06
*'84 Tercel4WD.Stolen by City of Durango,and scrapped.Rust Into Pieces,'07
*'77 FJ40,"Panama Red," drove 2 of the tires off of the rims during test drive!RIP'09 *'84 FJ60,"Blue Steel." |
06-28-09, 12:07 PM
| | where are my pants?
| Do your door locks work? If so, I would double check the brake light fuse (and trailer wiring as Kayak mentions) If not, I would suspect one of the fusible links at the positve terminal of the battery (those lights, the heater, the charging circuit and the power locks share a common feed at the battery)
__________________ [ ][ ]=TOYOTA=[ ][ ] - 22RE, NOS, A440F, 1.3:1 full time 4wd transfer case, 26x8.5 racing slicks, 4.27s, LSD rear, welded front, shortened range fuel tank, side awning, curb feelers, custom bumper with strobe lights and fog machine  - Wobble Wagon [ ][ ]=TOYOTA=[ ][ ] - 2FE and no rust, in the works Edmonton area Cruiser Corner Peace Canyon Toyota Swamp Donkeys
I'm not really a doctor, I just play one online |
06-28-09, 12:22 PM
| | Forum Regular
| Thanks for the quick responses, guys!
The power door locks do not work.
I will hunt down a voltometer and I'll try the 1 fuse at a time diagnostic as well.
I don't have a FSM, but I do have the Hayes. It has a ton of scematics but they are too complicated for my level of experience with electronics.
I'll report back my progress. I really just want to get the tail/break lights working, so I can legally (safely) drive it.
06-28-09, 06:35 PM
| | Forum Lifer
| check your fusible links. I think the white one provides power to dome light and tail lights. On the FJ60 you can take the links out and plug the harness together without the links. BUT, if you really have a short, you run the risk of burning up your harness.
Good Luck. |
