Old 06-26-09, 08:00 AM   #1 (permalink)
ColoradoLC's Avatar
Help - FJ60 Fuel Delivery Issues
I have what I suspect to be a fuel delivery issue. At first I thought I had a carb issue, as it was about time for a rebuild. I had it rebuilt by Mark and put it back in and it does run better, but here's what happens:
I can get it started and it runs for a minute or so, but then it starts to choke and cough as if it's going to die. I can sometimes feather the gas pedal, but usually it will die and I will have to keep trying to get it started. It will run for a few minutes and then die again. This is what was happening and I though the carb was to blame. It probably was partially, but now that this is not an issue, it has to be something else.
I found a thread from a 62 owner with similar issues here. Could the fuel pressure regulator be the issue here too? I just wanted to check with 60 owners to see if they have had similar experiences before I plunk down $90 something for a new one from CDan.
Thanks!
Winston
1986 FJ60 - SOLD
1997 FZJ80 - 295/75-16 Nitto Terra Grapplers - OME suspension
2000 VW Passat - Very much not stock
ColoradoLC is offline   Reply With Quote
Old 06-26-09, 10:08 AM   #2 (permalink)
2mbb's Avatar
Garage
60 series don't have pressure regulators. It's either your fuel pump is going out or one of your fuel lines or fuel pick up is clogged.
mbb
1985 FJ-60
2mbb is offline   Reply With Quote
Old 06-26-09, 11:34 AM   #3 (permalink)
ColoradoLC's Avatar
Thanks mbb. Would you expect intermittent fuel issues if the fuel pump is going out? I would expect it to just stop working, not be sporadic like it is.
1986 FJ60 - SOLD
Old 06-26-09, 01:11 PM   #4 (permalink)
2mbb's Avatar
Yeah, I think so. Read this post, and/or search for more...One of those weeks...
mbb
1985 FJ-60
Old 06-26-09, 01:50 PM   #5 (permalink)
Start with the obvious/easy stuff. Toyota put the fuel filter on the passenger side fender with clamps designed to be removed without tools. Start there, then go to the pump, then the lines and pickup in the tank. Make sure the fuel lines are connected correctly and the pump is drawing through the filtered line, not ther return line.
A daily driver 1985 FJ60, 300HP TBI 350, NV4500, NP241, 14-bolt semi floater rear w/Elocker, 4.56 gears, SOA, four-wheel disk brakes, 35" BFGs, 360,000 happy miles and still going due to a wicked case of wander lust.
lehiguy is offline   Reply With Quote
Old 06-26-09, 02:02 PM   #6 (permalink)
ColoradoLC's Avatar
mbb, It sure sounds to me like the fuel pump could be the problem.
I did replace the fuel filter a couple of months before this started happening, but it ran fine for a while after that before the issues started happening. I'll look into a fuel pump and go from there.
lehiguy, those are good suggestions. I'll doublecheck the filter lines as you suggested.
Thanks guys!
1986 FJ60 - SOLD
Old 06-26-09, 03:41 PM   #7 (permalink)
trace the fuel lines from tank to carb and make sure some other owner didn't add another fuel filter.
1980 FJ40 all stock, factory air and power steering
1988 FJ62 dog hauler
2X 1965 FJ45LPB
1963 FJ45LP, 1964 FJ45LV, 1970 FJ55 all needing some work
and lots and lots of pieces and parts
3_puppies is offline   Reply With Quote
Old 06-26-09, 04:52 PM   #8 (permalink)
meatloaf's Avatar
Thanks guys!
Might want to pull off the filter and check an see if it is dirty. I had the same symptoms and it turned out to be a rusty gas tank...
83 FJ60
92 4X4 x-tra cab 22RE
Meatloaf®
meatloaf is online now   Reply With Quote
Old 06-26-09, 05:01 PM   #9 (permalink)
GIGGIDY!!!
eventhough's Avatar
I have the EXACT same problem with my Pig. I even had my carb rebuilt by JimC. Replace the fuel filter and it seems to run good for a bit - then back to bad.
I'm in the process of replacing my tank (b/c it is alllll beat up) and all fuel lines. Even gonna replace my fuel pump. I'll report back what happens...
Member:
Upstate Cruisers
Toyota Land Cruiser Association
Patriot Guard Riders
76 FJ55 SOA dubbed "The Beast"
07 FJC dubbed "Papa Smurf"
BUILD A CRUISER FOR A FALLEN SOLDIER
I cling to "guns and religion"
eventhough is offline   Reply With Quote
Old 06-26-09, 08:37 PM   #10 (permalink)
Cruiser Curmudgeon
FJ40Jim's Avatar
Check the carb sight glass when the engine is running good, vs. when it sputters and dies.
If sight glass is always showing fuel, then there is no problem w/ fuel delivery to the carb.
If sight glass shows fuel, then fuel drops off window and it dies, then there is a problem somewhere between fuel tank and inlet needle.
Thanks,
Jim C.
TLC Performance
Underhood Janitor, cleaning up other people's since 1988.
FJ40Jim is offline   Reply With Quote
Old 06-26-09, 11:20 PM   #11 (permalink)
ColoradoLC's Avatar
That's a great idea Jim, that's why you are the man on the carb!
I'll check it this weekend and report back.
Eventhough, I am 95% sure my tank is good, but there is always the possibility the lines have gone bad. Let me know what you find with yours. This is an aggravating issue. My rig has always run so well. I should never have bragged about that for the last 4 years, because now look what happens...
1986 FJ60 - SOLD
Old 06-27-09, 12:43 PM   #12 (permalink)
Note how full tank is when VAPOR LOCK starts to occur. When it occurs again STOP go around and pop the gas cap take note how aggressive the vaccum on the fuel tank is. After releasing this VAPOR LOCK start motor and note preformance difference. If there is a difference then your AIR SWITCHING VAlVE is dead $600 bucks for the part. Cheap fix is to buy a 2nd gas cap- drill a small hole in it and save the original for inspection time.
How do I know? Same problem, new fuel pump, air rale, exhaust, egr, carb, manifold work, new distributor---BUCKED LIKE a horse on the way out of the dealers shop. I drilled a hole in gas cap and it has never done it again. Hope this helps.
P.S clogged fuel filter usually results in a loss of power but the motor idles well and takes off at low speed OK but when more gas is required to speed up the choked motor just kind of slows down whether you floor the pedal or not. That is my experience with a clogged fj60 fuel filter.
jpnhgpl is offline   Reply With Quote
Old 06-27-09, 02:49 PM   #13 (permalink)
GIGGIDY!!!
eventhough's Avatar
FYI my fuel bowl is near empty to empty the one time I was able to hop out and check the level when it cut off/wouldn't restart.
Member:
Upstate Cruisers
Old 07-02-09, 02:18 PM   #14 (permalink)
ColoradoLC's Avatar
Well I let my rig run for about 30 minutes in the driveway since I didn't want to get stuck somewhere. It almost died at one point, but the fuel level in the sight glass was about 60%, which is about what it was at when it was running normally.
I did check the fuel filter which looked good. When I was checking with my flashlight on my head, I noticed some drips coming from under the fuel pump that I didn't notice before. Even though I didn't run the engine until it died, that's a sure sign I need a fuel pump, so I just called CruiserDan and order a new pump and insulator. I should get them some time next week.
I'll post up again after I get it in and test it with my results.
1986 FJ60 - SOLD
Last edited by ColoradoLC; 07-02-09 at 02:23 PM. Reason: edited found drips under fuel pump, not filter.
Old 07-07-09, 08:37 PM   #15 (permalink)
ColoradoLC's Avatar
Update: I got the new fuel pump from CruiserDan and got it in tonight and it looks like I still have the same issue.
Here's a little recap on what happens. I can get it started, and it runs pretty good, although it does idle a little unsteadily. It's possible that the carb (just recently rebuilt by Mark) needs further adjustment, but what adjustment specifically, I don't know. When I drive it, it hesitates when I give it consistent gas pedal. I was able to get it to die a couple of times, and ths sight glass showed gas level up to the top of the gas (I am on my driveway pointing down at about 5 degrees).
So rebuilt carb, new fuel pump, new fuel filter, new distributor cap, rotor, wires and plugs. I am open to any other suggestions. Keep em coming.
Thanks,
Winston
1986 FJ60 - SOLD
Old 07-07-09, 08:46 PM   #16 (permalink)
ColoradoLC's Avatar
Oh also tested the gas cap. Still does the same thing with it off and depressurized.
1986 FJ60 - SOLD
Old 07-08-09, 05:24 AM   #17 (permalink)
hank14's Avatar
Have you measured your intake vacuum since installing the rebuilt carb? You might have a vacuum hose hooked up wrong- I did that on my 60 after my carb rebuild. I had one of the 4 hoses on the valve cover side of the carb in the wrong place, making it seem like the fuel cut solenoid was not working.
Wouldn't hurt to double check all those vacuum lines.
Scott
Granbury, TX
1987 Beige FJ60.
One clean cruiser.
hank14 is offline   Reply With Quote
Old 07-08-09, 10:20 AM   #18 (permalink)
ColoradoLC's Avatar
I don't have a way to measure the vacuum but it is possible that a hose is connected wrong. Since my marking were cleaned off the carb when it was rebuilt, I had to go with the best guess on the locations for them and fortunately, they were old enough that they wanted to go back to where they were originally. Still, that could be it. The FSM diagram leaves a little to be desired on the location for these from what I have seen. You don't happen to have a picture of those ones you are referring to on yours, do you?
1986 FJ60 - SOLD
Old 07-08-09, 12:25 PM   #19 (permalink)
2mbb's Avatar
I find these two drawings are helpful. The second one (from the emissions manual) shows a detail of how the tubes on the valve cover side of the carb are connected to the four vacuum manifold pipes--top to bottom.
http://www.sweetillusions.org/toyota/6.pdf
http://www.sweetillusions.org/toyota...um_routing.gif
mbb
1985 FJ-60
Old 07-08-09, 04:10 PM   #20 (permalink)
ColoradoLC's Avatar
Wow! Great illustrations 2mbb. Once again, thanks! I'll check this out when I get home.
1986 FJ60 - SOLD
