Old 06-16-09, 06:35 PM   #1 (permalink)
Esther's Avatar
Transmission and transfer case oil...
OK, my 86fj60 turned 120000 miles this week and I want to change the transmission and transfer case oils. My Toyota Maintenance book (the skinny, 30 page one with the red cover) says to use API GL-5 or -4 with SAE 90 viscosity. I am having trouble finding this exact type of oil. Every place I call (Checkers and Pepboys) says they have multi-grade oils that will work, but I don't know if I trust their advise on this.
What do you all use, and where do you get it?
John
Esther is offline   Reply With Quote
Old 06-16-09, 07:28 PM   #2 (permalink)
forestdan7's Avatar
You should be able to get straight 90W somewhere. Try NAPA or Carquest. 80w-90 should also work fine, but I hear you about trying to match what the manual calls for.
Some people like running synthetic in the trans and transfer. Like 75w-140. I do right now, but only because the transmission is new (H55F), and the transfer case is rebuilt. Once they get some wear on them, I'll probably go back to 90W.
1985 FJ60
1987 4Runner -- SOLD
2002 4Runner Limited
2007 Honda XR650L
forestdan7 is offline   Reply With Quote
Old 06-16-09, 07:34 PM   #3 (permalink)
klinetime574's Avatar
Garage
I got my oil at the local place. Those big black jugs, same ones that coolant comes in. I think its 80W-90. Shifts fine just like before. Have fun filling it I laid on the floor with a little hand pump on the jug that broke halfway through and fell in the bottle haha. Fun times.
1984 FJ60, 176 Thousand Miles, Rebuilt 2F, OME, Desmog, Weber 38, SOR Header, BFG A/T's on Eagle 058's
klinetime574 is offline   Reply With Quote
Old 06-16-09, 08:58 PM   #4 (permalink)
Take the shifter boot loose, pull the shifter out and fill through the top of the tranny. MUCH easier.... I learned the hard way also.
SouthCoastMudder is online now   Reply With Quote
Old 06-17-09, 02:16 AM   #5 (permalink)
... Alive
Mark W's Avatar
Multigrade is better. use it and be happy.
Mark...
Mark W is online now   Reply With Quote
Old 06-17-09, 02:45 AM   #6 (permalink)
Yspen's Avatar
Stick to 80w-90 .
I tried adding stuff to make shift easier but that only changes the viscosity and makes the shift worse .
So after a lot of experiments , additives and different viscosity oils I have found 80w-90 to work best .
( I have not tried Xado additive - apparently it does not change viscosity but makes shift smoother via some fancy ceramic coating . Still sceptical and I have had to many dead ends in the quest to find a better shift .)
Yspen is offline   Reply With Quote
Old 06-17-09, 08:08 AM   #7 (permalink)
Garage
I did do that for the transmission. But it took forever to fill that transfercase. haha
Old 06-17-09, 11:34 AM   #8 (permalink)
cruiser88's Avatar
Get the 8 dollar pump that fits on the gallon jug
http://shop.advanceautoparts.com/web...0oil%20pump___
NEW! Club sticker for sale. pm me for details!
MountaineerCruisers.net
Old 06-17-09, 01:27 PM   #9 (permalink)
Esther's Avatar
OK, Found the oil and 8 dollar pump at Nappa.
Another question... The fluid that is currently in the tranny has a reddish tint to it. It dosen't look dirty, just reddish or brownish. Is this the color of old, bad oil? Or is it possible that the PO put automatic transmission oil in the thing and if so, would the truck be able to drive with that type of oil in it? (yes, it is possible considering the PO was not the brightest).
I've put about 8000 miles on the truck since I got it with no tranny issues.
John
Old 06-17-09, 01:40 PM   #10 (permalink)
T-bones 60's Avatar
I use Royal Purple 75-90 in my H55 and T-case. I noticed smother shifts right away. I ran 90wt dino for the 1st 15k, then switched. I also use it in my diffs. It's stupid expensive, but worth it to me after feeling how much easier it is to shift.
"LC THE BROWN COW" 84' FJ60. Featured in 4WDTO mag. See her here; http://www.cardomain.com/ride/622071
Trucks fixed, I'm broke.
T-bones 60 is offline   Reply With Quote
Old 06-17-09, 02:08 PM   #11 (permalink)
cruiser88's Avatar
Its possible......just dump the ATF and refill
John
