12-09-04, 07:39 PM
Seafoam or Berryman's B-12?
Seafoam or Berryman's? I'm thinking I might need to clean out the combustion chamber/valve train on the '60.....do these products actually work? Any damage to seals/gaskets/etc...? Negatives? Positives?
Always have been hesitant to put any aftermarket additives into the system so those with firsthand experience please pipe up before I go and do something I might later regret....
Thanks,
-dogboy- '87 FJ60
12-09-04, 07:49 PM
Have had good results with Berrymans, great stuff.
12-09-04, 08:17 PM
Utarded
Does Seafoam work? Hell yeah!
The first time I treated my 87 FJ60 with Seafoam was in a parking lot of an auto parts store, guys were stopping to ask if I needed a ride home, because the black smoke coming out of the tail pipe was making them think my motor blew! It really does the trick when it comes to cleaning out carbon deposits- two thumbs up!
Eric, Utah operations commander- Tall Corn Cruisers.
1993 Landcruiser, 197K miles. Lifted, Locked, Slidered, Slee'd, Snork'd, Winched, bobbed. Daily driver. ROTW
12-09-04, 09:44 PM
Be careful, I would use Berryman's for the fuel tank and Seafoam for the carb system. Yeah, they can do a number on your gaskets. Also be careful as they can loosen up deposits that will haunt you in the long run. Unless you really think you need it, then use it; otherwise don't.
Hell, I use them all, but I am prolly wasting my money.
12-09-04, 09:52 PM
Seafoam.
12-09-04, 09:56 PM
Could someone elavorate a little more on these two products? Are they available at my local autozone? How are they used? Thanks in advance guy's.
12-09-04, 10:09 PM
No body is mentioning 44K? (K44?)
devo
12-09-04, 10:17 PM
Yes - and the uses are all on the side of the can...
which leads to:
As far as which is better, I'd say it depends. They are a little different. Seafoam into the manifold is great for clearing carbon, and in the crankcase it's helped mine idle smoother and more quietly. I've put both in the tank and never noticed a difference.
I like B12 for cleaning though. I keep spray cans and the open top cans in the garage at all times. I've run B12 through the oil just before an oil change, too. Seems to do an okay job cleaning things out, but I haven't seen any huge benefits from using it...(but again, it's great for parts cleaning. I don't use anything else if I can help it.)
Originally Posted by OZCAL
…I think we need Swank 60 on this case. He knows irony…
12-09-04, 10:44 PM
Thanks a bunch swank.
10-21-09, 01:40 PM
#10 (permalink)
How do you seafoam the the motor without putting in the gas tank
10-21-09, 01:50 PM
#11 (permalink)
Utarded
Pull one of the vacuum lines off of your brake booster.
10-21-09, 02:14 PM
#12 (permalink)
Veni, Vidi, Dormivi
i like Seafoam, and think it works great - but haven't tried B12 before.
I usually pour down the carb while keeping the RPM's up, then let it bogg and die so seafoam can soak some parts for 10-15 min, then fire back up and go!
I've heard about fouling issues and such, so typically do it just before i change plugs and oil. Also usually put the other half of the can into the gas and/or oil.
Not "magic in a bottle" but works very well IMO.
GL!
Rob
1984 FJ60 *still TBD* 33x9.5's, 3" BDS, H55f
Dual Batt's, LED's, SROR Bumper, Rear Sliding Windows, Audio Dampener, More to come!
1987 FJ60 "TeeK"
Bozone (n.): The substance surrounding stupid people that stops bright ideas from penetrating. The bozone layer, unfortunately, shows little sign of breaking down in the near future.
10-21-09, 10:00 PM
#13 (permalink)
Had great results in the cruiser with seafoam, would for sure recommend it.
1984 Beige FJ60 "Helen"
10-21-09, 11:15 PM
#14 (permalink)
i run b12 through my fuel every so often. not sure how much it helps since i still have to use starter fluid almost every time i get in the truck. i've also done the seafoam treatment which worked wonders on helping to identify all of my exhaust leaks. i had smoke spilling out of cracks and crevices from the manifold to the tail pipe.
1984 FJ60
1965 Mustang
2004 HD Dyna Wide Glide
10-22-09, 08:06 AM
#15 (permalink)
as i understand it you put some seafoam in the gas tank in with the oil and in your carb or throttle body, and it is smart to do it during a tune up cause i believe you are supposed to change plugs at the same time. It loosens alot of gunk up in there which is why you change oil and plugs and such at the time you do it. I have heard wonders though. Look on youtube , theres some videos.
10-22-09, 03:50 PM
#16 (permalink)
I used some Seafoam on my 160k miles TBI Sub. Put the whole can in the fuel tank and then filled it to it's full 40 gal. capacity. Mileage from that tank sucked, but the smoothness & drivability did slightly improve afterwards.
My opinion is worth what you paid me for it.
10-22-09, 06:06 PM
#17 (permalink)
SEAFOAM
83' fj60 .... 4"MAF lift.. cooper stt 33"x12.5 x15 on 8" rims and locked
10-22-09, 07:13 PM
#18 (permalink)
Pouring Seafoam straight into the carb is worth it just for the smoke!
Cruzerman
'85 FJ60
'78 FJ40
10-22-09, 07:26 PM
#19 (permalink)
... Alive
Guys... WATER in the intake will clean the combustion chambers. That trick is older than anyone on this board. Not a damn thing special about Seafoam there.
Please elaborate on how Seafoam... or anything... added to the oil in the crankcase will improve how the engine runs. With supportable arguments, based on some sort of science or at least demonstrable repeatable facts.
Mark...
http://www.AlaskaCruiserTrek.com
MIBS Rules!
The first primordial slug that sprouted gripping pods to pull itself out of the ocean onto the slick rocks of the world beyond was the original proponent and carrier of MIBS. It has been onward and upward since. Embrace MIBS! Leave the other slugs behind!
10-22-09, 07:54 PM
#20 (permalink)
hasn't mythbusters done something on this?
'88 FJ62-Stock-125K- stock with lots o rust  '88 Toyota Mini SR5 3.0 Ext. Cab P/U,7" lift,35s w/4.88's
10-22-09, 09:25 PM
#21 (permalink)
just drink gas and be done  .
Snake oil is freak'n snake oil.
ben
10-22-09, 09:49 PM
#22 (permalink)
When I finally brought my cruiser back to life this past spring, it had a sticky lifter, identifiable by a periodic downward tick in the vacuum gauge while idling. After a half can of seafoam in the oil, the sticky lifter unsticked itself.
It may have been the additive, or it may have been the increased use that did the trick, but I'm inclined to believe that the seafoam helped.
[O]=TOYOTA=[O]
1985 FJ60 “The Bantha”
10-23-09, 12:13 AM
#23 (permalink)
... Alive
ATF would do the same. As would simply running the rig more or using a detergent oil... Nothing special there.
Mark...
MIBS Rules!
10-23-09, 09:47 AM
#24 (permalink)
Agreed, I would use ATF in the engine oil. A little can do hard seals some good. More is not better though.
I used Seafoam in the fuel to try to remedy problems that I thought were caused by varnish in the fuel injection system. It did appear to work for that, but no data to support that if you exclude the SOP dyno.
