Old 04-25-09, 08:13 PM   #1 (permalink)
wngrog's Avatar
TLCA# 8121
FJ-60 Old Man Emu Install - My Tips
I am sure there are already 10 threads on how to do a lift on a Fj-60, but I thought I would throw mine out there into the "search" fodder.
I recently purchased a 1984 Fj-60. It spent 20 years in Colorado so the body is decent but the back 1/3 of the underside is fairly rusty.
I have been out of Cruisers for a while playing with buggy's so this is the first leaf spring suspension I have installed in about 6 years. Of the 10+ Cruisers I have owned and modified it is the first Old Man Emu suspension I have installed.
The following is a list of tips that I felt like I should share for those that plan on installing an Old Man Emu OME suspension in their FJ-60 / 62.
3 weeks ago I knew the suspension install was eminent, so tip #1 is:
Before installation, thoroughly soak any and every part that is going to be removed with penetrating oil such as Break Free. I hosed every bolt and nut 3 times in 3 weeks.
top 10 tools you WILL need for this install, don't start without them.
1) 4 quality jackstands
2) Floor Jack
3) Heat source - cutting torch or propane torch
4) 5# and 12# sledge hammers
5) Air chisel (optional, but nice to have)
6) rubber mallet
7) 10, 12, 14, 15, 17, 19, 21mm sockets, (deep)
8) 3' breaker bar
9) Impact wrench
10) Sawzall
Wow, that is a lot of crap to collect just to do a suspension lift....well, if your 60 series is like mine, the stuff you are about to remove has been on the vehicle for anywhere from 19 to 28 years. Stuff gets "baked" on when its been on a car for 20 years.
Here is the start......
Rock Midget Motorsports
2008 Twisted Customs FJ40 Buggy
1984 FJ60
Cottonland Cruisers
www.mailitmadison.com
www.rockmidgetphotography.com
[sigpic][/sigpic]
wngrog is offline   Reply With Quote
Old 04-25-09, 08:32 PM   #2 (permalink)
wngrog's Avatar
TLCA# 8121
OK, so I nosed the 60 into the shop and started on the front.
Jack up the truck pretty high hand use your biggest stands to hold the frame just behind the fixed-end spring hangers, then use your smaller stands to support the axle just shy of full-droop on the springs.
Pull the shocks. The fronts will spin when you try to loosen the top. You can use a strap wrench to keep it from turning, an oil filter wrench or I have even pierced the metal with vice grips or a screwdriver. These are being tossed so just get them off any way you can.
Next, use your impact wrench and pull the ubolts. With your axle and frame supported, you should now have a spring hanging 1-3" under the axle.
Now you are to the fun part. Getting the springs off the 19-29 year old Land Cruiser.
On the front of my Cruiser, the shackles came right off without trouble. I always drop the shackle end first. Not sure why, but I always have. When I got to the fixed-end, the pins were frozen. I beat on them with my 20# sledge and they did not budge.
Enter the heat. A cutting torch works best. Light up the inner pin cherry red and use the air chisel to work the pin out of the spring. Since I used a propane torch, I could not be so precise to hit only the pin so I let the old bushings burn a while and melt.
Keep a fire ext handy when torching, my drivers side front went up in smoke during the "cook off" due to old power steering fluid around the box.
I like to get the front done, and then switch to the rear after the front is 100% complete.
One tip, if you have a 5th jackstand, prop it under the pinion to keep the axle in proper orientation. It will help a lot when you try to put it all back together.
1984 FJ60
Cottonland Cruisers
[sigpic][/sigpic]
Old 04-25-09, 08:44 PM   #3 (permalink)
wngrog's Avatar
TLCA# 8121
Couple of comments at this point:
My rear ubolts were so rusted, I had to use a 3' breaker bar to get them started and then use my Snap On impact.
The outer plated on my front shackes were not drilled out large enough to get the 1/2" shackle bolts through so I had to drill them out to 9/16" to get them to work. For the record, that is the only negative QC thing I found with the OME setup.
When you are setting up the springs with the fixed-end and shackle hangers, keep everything finger tight so you can align the spring pin and the hole on the the axle mounting surface. This can get dicey when it is all tight.
Think about what you are doing when you set up the OME shackles. They go one way. It is easy to mess this up and have to "do-over"
Replacing springs is a good thing to do, even if you don't want to lift your rig. Both of my rear springs had 2-3 broken leafs.
1984 FJ60
Cottonland Cruisers
[sigpic][/sigpic]
Old 04-25-09, 09:00 PM   #4 (permalink)
wngrog's Avatar
TLCA# 8121
OME rear springs are L/R oriented.
The modular OME shackles are super easy to install compared to the barbell type shackle that come with Hell for Stout systems and BDS suspensions. That said, they are 4x more expensive. I don't know if it is worth it. OME shackles are damn cool, but the price is crazy.
Swaybars; I took mine off. If I decide to re-install it, Georg Esterer sells extensions. PM orangefj45 here on MUD for the kit.
My install took me alone about 6 hours to complete. I have done this quite a few times, but not for a while so I was a bit rusty. I would suggest a helper, but if you can't get one, there are no 2 man jobs. The rear packs are stupid heavy, I would estimate they are 65# each.
Here is my final picture. My shocks won't be in until Monday and on Tuesday I will get my 33 x 10.50 BFG MT/KMs installed.
1984 FJ60
Cottonland Cruisers
[sigpic][/sigpic]
Old 04-25-09, 09:05 PM   #5 (permalink)
Gobble Gobble Wut?
Spook50's Avatar
Looks great! That'll be sure to help those going OME. Myself, I'm planning SOA to accommodate the (eventual) 4BT.
'88 FJ62 W/ 253K miles, desmogged, stock SUA W/ full length Add-A-Leafs, Tuffy console, LED interior lighting, Mallory ignition, Ford Contour electric fan, four wheel discs, Aussie sliding windows
Don't cry like a bitch when you feel the pain...
Spook50 is online now   Reply With Quote
Old 04-25-09, 09:32 PM   #6 (permalink)
Doberdog chauffeur
sirenmoses's Avatar
Garage
Thumbs up
Excellent write up.
I paid a wrench to install my BDS: it took him twice as long as he thought it would (8hr vs 4), involved borrowing a cut-off wheel and perhaps another tool he didn't think he'd need, and revealed a broken leaf in the rear.
I'd thought perhaps I might re-use the springs on my trailer: only one was intact, the others only removed by cutting through at the wrap side.
VERY happy with the ride, worth every penny (says the one who didn't bust knuckles doing the job )
My wheels are older than your highschooler:
Sept 84 tan fj60, 202k -- 2.5" BDS, 31's w/ al rims, Daylighters, Yakima w/sliders, hitch w/back-up lights.
to be installed: Rowlands panels, CB, grab handle, quick-stow dog barrier
home-built trailer (not by me) -- Kamp K9 (work in progress)
Oct 84 tan fj60, 265k -- saggin wagon (My lil sis's, once the BIL pays me )
85 Honda Accord, 120k -- DD
91 Kawasaki Concours, 50k -- 2 wheeld fun
sirenmoses is offline   Reply With Quote
Old 04-26-09, 12:18 AM   #7 (permalink)
Sixty's Guy's Avatar
Originally Posted by wngrog View Post
OME rear springs are L/R oriented. Since they are made in OZ, the best thing to remeber is the + that is painted on them is driver and the - is the passenger.
Regardless of the country the A spring is for the drivers side. The + means that the spring is slightly taller than spec and the - means the spring is slightly lower than spec.
AKA Mark
1983 HJ60, 2H Turbo, 33/35" BFG MT, Twin Lock Rights, other stuff
1975 FJ55 Stock Standard
Sixty's Guy is offline   Reply With Quote
Old 04-26-09, 03:44 AM   #8 (permalink)
Joe_E's Avatar
TLCA# 5448
Isn't it amazing how the old pin and bushing seem to morph together?
I remember beating on mine for about ten minutes working up a major sweat before it was decided fire would be the only solution.
Joe_E is online now   Reply With Quote
Old 04-26-09, 05:47 AM   #9 (permalink)
Beagles Rule!
D'Animal's Avatar
TLCA# 17104
Garage
WHAT??
OME rear springs are L/R oriented. Since they are made in OZ, the best thing to remeber is the + that is painted on them is driver and the - is the passenger. They are labeled A and B....in the US, B is the driver side.
Land Cruiser Garage Sale Items <- Link
Get Your Marlin ToyBoxes Now!
Beagle Chariot
1962 FJ40
1964 FJ 40
1968 FJ 40 <- For Sale
FJ 40.5 Build 4BT Cummins Conversion
1976 FJ 40
SPEN Trailer
D'Animal is online now   Reply With Quote
Old 04-26-09, 07:37 AM   #10 (permalink)
cruiseronly.com's Avatar
TLCA# 7820
fj60
I remember your first 60. That was a sweet ride. I think you will love your new tires. They ride and drive great. Maybe i will see you at gsmtr.
cruiseronly.com is offline   Reply With Quote
Old 04-26-09, 07:40 AM   #11 (permalink)
wngrog's Avatar
TLCA# 8121
RA is US Passenger Side, RB is driver side. They are heavy load front, medium rear. If the front is too much, you can pull the 4th leaf on the front pack.
Christo Slee
__________________________________________________ ________
Sorry for the confusion....this is how it is supposed to be.
1984 FJ60
Cottonland Cruisers
[sigpic][/sigpic]
Old 04-26-09, 07:44 AM   #12 (permalink)
wngrog's Avatar
TLCA# 8121
Thanks for posting that picture...I have been wondering what they were going to look like. That Cruiser is awesome looking. I really did not remember much about that Tan FJ-60, but this one is bringing back the memories. I really, really like it. I am sorry it took me so long to get back into a 60.
1984 FJ60
Cottonland Cruisers
[sigpic][/sigpic]
Old 04-26-09, 08:02 AM
wngrog
This message has been deleted by wngrog.
Old 04-26-09, 08:26 AM   #13 (permalink)
Great write-up which will help many future installations. Only thing that I did different is to only do one spring at a time. That way, the axle was held in place and there was not worry about the pinion angle shifting.
86 FJ60, Champagne Bronze, 33X9.5s, Desmogged, Dynamat, ARB in rear, 4.11 gears. OME lift, bedliner on rocker panels. Tint.
1987 FJ60 Dark Blue Metallic, 31X10.5s, 130K, Desmogged.
"Assumption is the Mother of all Foul-up"
Heartworm is online now   Reply With Quote
Old 04-26-09, 08:33 AM   #14 (permalink)
What did you use the 15mm for?
KYLE
'97FJ80: Big, White and Dented.
'88 FJ62: Hardcore trail rig in the making, getting back to it very very soon.
'85 AE86 Corolla: Drift/track/DD project
83 FJ60 Parting: http://forum.ih8mud.com/parting-out/...only-108k.html
72rockcruiser is offline   Reply With Quote
Old 04-26-09, 08:57 AM   #15 (permalink)
KOOL AAROW
kling-on's Avatar
TLCA# 15374
rusty 14's lookin good Grog
82 FJ60 5.3, 4l60E, OME Heavy, 33 KM2's 410's, ARB bull & side bars ...SOA in the works
85 FJ60 Trail beater SM 420 crawler box lockers 456, 4D's bobed & choped with a Metal Tech cage
GIT-R-DONE!!!!
TLCA #15374
low riders want SWITCHES... 4 wheelers want SHIFTERS
www.jkcustoms.com
kling-on is offline   Reply With Quote
Old 04-26-09, 09:07 AM
wngrog
Old 04-26-09, 09:11 AM
wngrog
Old 04-26-09, 09:37 AM   #16 (permalink)
wngrog's Avatar
TLCA# 8121
funny...
The anti-inversion pin nuts.
One spring at a time is a great plan...I dont see how you did it in the rear with such a huge difference in spring size.
I actually used a 5th jackstand under the pinion for that.
Another tip.....when you go to move the rear axle back in place, pull the grease zerk out of the driveshaft slip yoke so it can move easier.
I just cut all of the Ubolts flush and greased the shackles......waiting on shocks
1984 FJ60
Cottonland Cruisers
[sigpic][/sigpic]
Old 04-26-09, 04:22 PM   #17 (permalink)
TLCA# 7820
Was that your 60 or 80 we put the arb side steps on? I think i was thinking of the 80. That was a long time ago. shannon
Old 04-26-09, 07:26 PM   #18 (permalink)
wngrog's Avatar
TLCA# 8121
Hey Shannon! Long time no see. You still outside of Nashville?
Yeah that was my 80 we did the sliders on before we took it to Tellico.
Another tidbit of information on the OME install.
I took it out and took it 45 degrees to a ditch and really stuffed the suspension to check the brake lines. This is without shocks so I got full use of the springs.
Stock brake lines barely got straight. They did not get tight at all. I did, however, take off the bolts that mount the hardlines to the frame, unnecessary but I did it anyway.
1984 FJ60
Cottonland Cruisers
[sigpic][/sigpic]
Old 04-26-09, 08:05 PM   #19 (permalink)
TLCA# 7820
you will be fine with the stock. i usually bend the brackets where it will give them a little more. i am still south of nashville you will have to come by some time. i have not made it back home to natchez in several years but if i do i would love to ck your buggy out.
Old 04-29-09, 08:39 AM   #20 (permalink)
wngrog's Avatar
TLCA# 8121
Tires are on...I love the way it rides.
I am 1/2" taller on the driver's rear corner. Front sits level.
Springs are Heavy front and Medium rear. Still has the stinkbug rake, but I plan on loading down the rear over time.
1984 FJ60
Cottonland Cruisers
[sigpic][/sigpic]
Old 04-29-09, 09:08 AM   #21 (permalink)
FJ60_cruiser's Avatar
Cool!!! what a nice change! love the look of your cruiser... by the way what headlights are u running?
Land Cruiser... because everythnig else just sucks
FJ60_cruiser is offline   Reply With Quote
Old 04-29-09, 09:15 AM   #22 (permalink)
wngrog's Avatar
TLCA# 8121
I got them from Bruce Wade at roundeyes dot com. Home
Bruce is a TLCA guy and a big supporter of the sport. Great lights. I have the street legal bulbs, but they sell 130w off road bulbs.
1984 FJ60
Cottonland Cruisers
[sigpic][/sigpic]
Old 04-29-09, 11:04 AM   #23 (permalink)
Rum Runnin'
GLTHFJ60's Avatar
TLCA# 17825
Garage
Beautiful! Do you have the stock wiring harness?
I just ordered a pair
Johnny C
Waiting to be installed:
Previous Rig:
1987 FJ60 - Big Red
ΦΚΤ - Fall 06
GLTHFJ60 is offline   Reply With Quote
Old 04-29-09, 11:06 AM   #24 (permalink)
wngrog's Avatar
TLCA# 8121
Yes, as long as you keep the 55w bulbs, you don't need to upgrade the wiring IMO.
1984 FJ60
Cottonland Cruisers
[sigpic][/sigpic]
Old 04-29-09, 02:02 PM   #25 (permalink)
euclid's Avatar
TLCA# 13014
Good tech. Thanks Nolen. FAQ'd.
Greg Thompson
89 FJ62, Unstock.
euclid is offline   Reply With Quote
Old 04-29-09, 02:04 PM   #26 (permalink)
FJ60Cam's Avatar
TLCA# 16341
Did you add the grab handles on the front handles or was that the PO?
I ran without the sway bar for about a year, then put it back on... it really seemed to make passengers freak out! I honestly can't say I really notice a difference one way or the other on the trail. Now I just leave it hooked up.
Cameron Mosley
'85 FJ60 - Daily Driver
FJ60Cam is online now   Reply With Quote
Old 04-29-09, 02:23 PM   #27 (permalink)
klinetime574's Avatar
Our cruisers are twins! I even have my IH8MUD sticker in the same spot haha
Thats looks like a lot of weights on your driver side rear wheel. I think you should get the tire rotated on the rim to get it positioned better. (Unless my eyes are deceiving me, everything is so shiny.)
1984 FJ60, 174 Thousand Miles, OME, Desmog, Weber 38, SOR Header, BFG A/T'S on Eagle 058's
klinetime574 is offline   Reply With Quote
Old 04-29-09, 02:39 PM   #28 (permalink)
wngrog's Avatar
TLCA# 8121
I added them. I even added one above my head like on the passenger side. Self tappers
I will hook mine up. It does not seem the least bit spooky like it is now, but I will see what it feels like with the Sway Bar on.
As for the wheel weights, I don't feel any vibs...I am going to run it. I don't plan on doing any long hauls in this thing.
1984 FJ60
Cottonland Cruisers
[sigpic][/sigpic]
Old 04-29-09, 06:10 PM   #29 (permalink)
TLCA# 7820
very nice!! i did not know you could still get the old style mt tires.
Old 04-29-09, 06:40 PM   #30 (permalink)
Ridin Dirty
Bomar's Avatar
TLCA# 17198
looks good.
it doesn't take you long to get the lift, tires, and now 4.88's
sixty deuce
94 KZ Runner
Bomar is offline   Reply With Quote
