Old 04-25-09, 02:23 PM   #1 (permalink)
Spanky Pete's Avatar
Power Steering Pump Priming
I just installed a new Power Steering pump. Yup, I sprung for a new Toyota pump from cruiser Dan. I had to do the whole "take the bracket off with pump" method. Also had to pull the smog pump to get at the bracket.
Now I have a horrible grinding noise from either the PS pump or the gearbox when turning the wheel. The factory pump came with PS fluid in it already. I just bolted it in, connected the high pressure line, connected the return line, topped off with a little more ATF fluid, and started to try and prime the pump.
Is this noise while priming normal?
I have turned the wheel back and forth at least 20 times and still the noise is there. I am trying to get a little better idea of priming should be done. I don't want to do anything stupid and brake a brand new PS pump.
_--------_____----------_______--------_______---
85 FJ60 211,000 mi bone stock
05 KLR 650 the go anywhere bike...SOLD
95 FZJ80 198,000 mi super clean stock with lockers
Spanky Pete is offline   Reply With Quote
Old 04-25-09, 03:24 PM   #2 (permalink)
Boulder Cruiser's Avatar
I just installed ps on my 40 this morning. All i did was pour fluid in, turn the truck on, turn the wheel, turn the truck off, add more fluid, and so on. It would make noise when the pump ran out of fluid thats when i knew to go add more. It took about a 1 quart to fill the pump and gear box and about 3 min to get it full.
1979 FJ40, ARB Bumper, ARB Lockers F/R, 4.88's, 4.5" safari lift, 35" MTZ, Warn 8274, Disk brakes, etc.
Boulder Cruiser is offline   Reply With Quote
Old 04-25-09, 05:53 PM   #3 (permalink)
TLCA# 11643
ps pump
Sounds like you have air in the lines and box. Jack up the front enough to clear the tires, start the engine and turn the steering wheel back and forth. That should bleed the air out.
kbill45 is offline   Reply With Quote
Old 04-25-09, 07:46 PM   #4 (permalink)
Gobble Gobble Wut?
Spook50's Avatar
X2. Do a full "running bleed" of the PS system while keeping an eye on the fluid level and just keep turning the wheel back and forth while holding at full travel each side for a few seconds. Keep this up until the "stiff spot" in the middle and any grinding noise goes away.
'88 FJ62 W/ 253K miles, desmogged, stock SUA W/ full length Add-A-Leafs, Tuffy console, LED interior lighting, Mallory ignition, Ford Contour electric fan, four wheel discs, Aussie sliding windows
Don't cry like a bitch when you feel the pain...
Spook50 is offline   Reply With Quote
Old 04-25-09, 08:16 PM   #5 (permalink)
Elbert's Avatar
TLCA# 17526
like others have said:
Jack frontend up where tires off ground., top off ps fluid.... start engine. Turn sterring slowly full left and then full right....multiple times.... over and over. Stop engine and check fluid (repeat two or three times) or until noise goes away.
1986 FJ60
5.7 Vortec
Elbert is offline   Reply With Quote
Old 04-28-09, 09:27 AM   #6 (permalink)
cruisedeisel's Avatar
2x's on the jacking of the front end, my power steering was noisy and not that strong till i did that. what a deference turning 35's
cruisedeisel is offline   Reply With Quote
Old 04-28-09, 10:12 AM   #7 (permalink)
klittlefield's Avatar
TLCA# 14951
Noisy pump
I just recently replaced my pump with a factory one and it took about a month to get all the air out of the system. I just had to top off the fluid every day just a bit and eventually the noise just went away. I tried the lift the front end method and either I didn't do it right which is possible or it just didn't work for me. Although having a friend turn the wheels back and forth while I was up front topping the fluid off helped a lot in the beginning. In the end it just took a bit of time to get all the air out.
Kent Littlefield
KE7RKR
84 fj60 2"OME lift w/ Dakar springs, BFG 33x10.5, No more Kamar rear bumper Now 4+plus with dual swing arms, headers, and
klittlefield is offline   Reply With Quote
Old 04-28-09, 10:49 AM   #8 (permalink)
Marc311's Avatar
I have been trying bleed my PS system for a couple weeks now. Spent all day Saturday and it still is not fully bled. Others have had similar issues. I haven't found an end all be all solution either. It just seems some systems are harder to get the air out. Some of us just seem to be unlucky.
It is frustrating the S*** out of me.
1995 Locked FZJ80
2007 BMW XChallenge
Marc311 is offline   Reply With Quote
Old 04-28-09, 11:34 AM   #9 (permalink)
HopLite's Avatar
http://forum.ih8mud.com/60-series-wa...s-learned.html
See first post for my method of bleeding the p/s pump. I first used a reman pump (which was defective) and could not get it to bleed using any number of methods. With a new OEM pump from CDan, I used the method as I posted it. No groans or wookie noises at all.
Best of luck!
1987 FJ60 stock 2F, H55, OME heavy/heavy, ARB Front bumper, 4+ rear bumper, Wilderness system roof rack.
I'm confident enough to try it...
Dumb enough to not talk myself out of it...
And optimistic enough to hope...
...hope that I'm smart enough to get myself out of whatever I started.
HopLite is offline   Reply With Quote
Old 04-28-09, 10:19 PM   #10 (permalink)
Well I got it primed and on the road without any more noises. jacking it up definitely sped up the process. I had heard that about ten turns should be enough, well I would estimate that I turned that wheel from lock to lock at least 35 times with wheels on the ground and another 30 times with the wheels off the ground before mine was fully primed.
During the install I had knocked some fluid out of the return hose, maybe 10cc. Not sure if that is why mine seemed to take so long to bleed. Good luck to all with the same problem. Keep on turning.
Old 04-28-09, 10:27 PM   #11 (permalink)
Wile E Coyote's Avatar
I'm surprised to hear there was fluid already in the new Toy pump. My surprise stems from EPA regs that usually get spouted when I've asked about shipping parts with fluids still in em.
The 2nd amendment...for when all the other amendments fail.
The desert dwellin, roadrunner chasin, soooper-genius!
'90 FJ 62, '08 Scion head unit, chopped quarters and rockers, 1" DIY body lift, bedlined exterior, and mostly stock. My soft wheeler and DD.
'85 Dodge Ramcharger a little built, and a little beat. She's looking long in the tooth lately.
Wile E Coyote is offline   Reply With Quote
Old 04-30-09, 10:33 AM   #12 (permalink)
Something that hasn't been mentioned here and should be is Do Not turn all the way up against teh steering stops! That cavitates the pump, which put air back IN the fluid. Stop turning and reverse direction just short of hitting the steering stops.
My opinion is worth what you paid me for it.
ntsqd is offline   Reply With Quote
