Old 04-21-09, 04:17 PM   #1 (permalink)
lo-temp thermostat and rad. flush
Hey Lenny123 here..getting ready to put in a low-temp thermostat in the 82 FJ60. Just moved to Louisiana where it gets quite hotter than the Northwest ever did. Anyway figured I'd do a radiator flush while I am at it.....actually never done one before!!!!!! Any tips or pointers I need to know before I change out the thermostat and do a radiator flush??????
lenny123 is offline   Reply With Quote
Old 04-21-09, 05:54 PM   #2 (permalink)
forestdan7's Avatar
TLCA# 17532
Drain and refill might be all you need. Sometimes flushing can loosen up stuff that is better sitting still.
Get new thermostat housing bolts and a new gasket. And make sure you've got the O ring that sits on top of the thermostat. I didn't use any sealant on the gasket. And don't tighten the housing bolts too much. The aluminum housing threads strip easy.
That's all I can think of off the top of my head.
1985 FJ60
1987 4Runner -- SOLD
2002 4Runner Limited
2007 Honda XR650L
forestdan7 is offline   Reply With Quote
Old 04-21-09, 10:15 PM   #3 (permalink)
thermostat
Thanks for the input...so you are saying not to flush but just drain and fill?????? I have all the gaskets needed....I always put new gaskets on when doing stuff so I am covered there.
Old 04-29-09, 05:41 PM   #4 (permalink)
forestdan7's Avatar
TLCA# 17532
Yep, I just drain and fill. There are probably different opinions, but with an old radiator, I figure you don't want to scour too much junk off and get it moving around inside. Same reason I don't like the sludge treatments for the oil circuit. There might be stuff in there that's just fine sitting still, but would be a disaster if it got loose and plugged something up.
FYI, it takes me a few hundred miles of driving to get all the air bubbles out. You might try searching for burp methods, but it'll eventually work its way out without burping. Just don't freak when the temp spikes if a bubble gets on the sender.
1985 FJ60
2007 Honda XR650L
Old 04-29-09, 05:52 PM   #5 (permalink)
TLCA# 2432
Flush it at least with water. Mike
Mike Hanson
1982 FJ40
1987 FJ60
3 x 1988 FJ62
1989 FJ62
1991 FJ80
Michael Hanson is offline   Reply With Quote
