Old 12-02-04, 06:24 AM   #1 (permalink)
Blue Chip's Avatar
Dead Battery Update
I posted earlier this week about the battery being dead after a couple of days of sitting. This all seemed to happen around the introduction of the MG alternator - or at least around 2 weeks later. Well, brough the truck in to Sears - turns out it was a faulty battery. No big deal there - I traded up for the Optima red top. Ten put all new terminal conectors on as well. The Diagnostics at Sears are pretty limited - but they confirmed that there was a drain somewhere - what they can't tell is how big the drain is - it can be anything from the stereo memory lead to something major -
Tha being said, the truck is in an auto electronic diagonistic shop thins am getting checked out - I'll post an update on what the problem is as this progresses - maybe someone can be helped by this experience!
By the way, the MG is charging at 29amps at idle and toped the meter at 147 somewhere aroung 2500 rpms....
1983 FJ 60, 3" lift, 33's, 383ci stroker, Edelbrock 750 carb, intake, and cammed. MG Alternator and rattle can paint job. Wilderness Sport Rack with tire mount and a face full of Hellas.
Blue Chip is offline   Reply With Quote
Old 12-03-04, 06:35 AM   #2 (permalink)
Blue Chip's Avatar
Okay - so, brought the rig into an electrical diagnostic place to see where the drain is. They still haven't got it down perfectly yet - however, they have it narrowed down to the Meen Green Alternator. Turns out the the OEM alternator has two plugs on top and the post in the back. The MG has 4 plugs on the top that join into a 2 prong plug - well, it looks like it was wired wrong. Basically, what I understand is that the regulator is pulling from the battery - mind you it charges fine, but it drains as well.
Will give another update when I get the final word.
Old 12-03-04, 04:16 PM   #3 (permalink)
Blue Chip's Avatar
Got the drain figured out!!!
Got the truck back today - turns out that the MG alternator wasn't wired right - not by me, but by the factory. See, the stock alternator has 2 plugs that come out of it - the MG has 4. Those 4 plugs splice into 2 that plug into your existing harness. It seems as though the folks ar MG spliced the wrong 2 wires together and completely bypassed the internal regulator. At Idle, the alternator was putting out nearly 17.9 volts....not good. It also created a drain on the battery when truck was off as well as overcharging the battery when running...not sure how, but the problem is fixed.
I guess some of the threads about MG actually were true...
Still love the alternator - just not the customer service or quality control. Under load it's productin 147+ amps.
