Old 11-30-04, 06:30 AM   #1 (permalink)
Blue Chip's Avatar
Dead Horse... Dual Battery Set Up
I've read about everything that I can about this -
Can you just take the positive from one battery and jump to the other, same for the negative for a simple set up? I imagine that both batteries would be charging as well. Or, do I need to have an isolator switch like the Rule marine battery switch?
1983 FJ 60, 3" lift, 33's, 383ci stroker, Edelbrock 750 carb, intake, and cammed. MG Alternator and rattle can paint job. Wilderness Sport Rack with tire mount and a face full of Hellas.
Blue Chip is offline   Reply With Quote
Old 11-30-04, 07:54 AM   #2 (permalink)
Merchant of Death
Landpimp's Avatar
TLCA# 5506
that would/will work and make one large battery. Few problems with this. both batts much be identical and of the same age, if not the weaker battery will kill the better battery eventualy. Also, you have no back up, if your batts die you can't just flip a switch and start up the cruiser
Truth is a torch that shines through the fog without dispelling it. Always be true to your work, your word, & your friends, & you will never live a day without peace
Landpimp is offline   Reply With Quote
Old 11-30-04, 08:10 AM   #3 (permalink)
Blue Chip's Avatar
So is there such thing as a 1 way switch? Meaning - both batteries will always charge direct from the alternator - but only one will draw at a time? What I'm thinking is, take 2 wires from the alternator post and hook to each of the + terminals on each battery. Run a negative from one post to the other on the 2 batteries. That would isolate the draw of the accessories to only to battery that I have them hooked up to - but leave the other for starting and such.... right???
Old 11-30-04, 09:49 AM   #4 (permalink)
Two Batteries
You could:
- Hook both negatives together.
- connect accessories to 'new' battery
- leave regular stuff connected to 'existing' battery
- connect 'new' battery positive
to 'exisitng battery' positive
via one whopping ( powerful) diode, 60 amp or greater
if using stock alternator.
This way, accessories drain the 'new' battery, but not the 'existing'.
and the alternator charges both ( well, nearly full ,99%, charges 'new' battery)
The 'isolator' box you buy:
- is basicaaly the above.
- compensates for the '99%' mentioned above.
p.s. : Where in Central Fla do ya live ?
- I grew up there,,,
- Son and sister live there
- I'm there often
I'm in Palm B county
soggy60 is offline   Reply With Quote
Old 11-30-04, 10:00 AM   #5 (permalink)
Blue Chip's Avatar
Live in Oviedo - by Winter Park...15 minutes north east of Orlando.
I'm running a mean green alternator - would I need a diode larger than 60 then?
Old 11-30-04, 11:24 AM   #6 (permalink)
lowtideride's Avatar
TLCA# 14891
nother florida boy?
www.NFCruiserheads.org 2RZ-FE 'D 1983 SR5 Hilux...
has had no peers for 50 years...
lowtideride is offline   Reply With Quote
Old 11-30-04, 11:42 AM   #7 (permalink)
Tank Buster
HZJ60 Guy's Avatar
TLCA# 13102
Look at this picture.
Here you see two batteries. The blue box is a 200 amp isolator (available anywhere) the alternator goes into that isolator as well as the two batteries. The isolator keeps the two batteries charged properly. Now if you look at the yellow top battery you'll see a very large round solinoid. That solinoid (painless wiring) uses a switch on the dash that connects that battery to the other red top battery. The isolator keeps care of both batteries and the solinoid either connects or disconnects the battery from the other. If the red top dies (I left my lights on) the yellow top will NOT be effected unless the switch on the das is ON!
The isolator was around 100 bucks, and the solinoid was 50 some dollars.
TB
2001 VW TDI Bora
1987 Toyota HZTJ-60
I'm a democrat member of the House of Representatives, and I've got what it takes to take what you've got!
HZJ60 Guy is offline   Reply With Quote
Old 12-03-04, 04:07 PM   #8 (permalink)
toy60's Avatar
A simalar thread to this is running over in outfitters
http://forum.ih8mud.com/winching-recovery/21649-battery-isolators.html
FORGIVENESS is far easier to get than PERMISSION.
84 FJ60 Lockright TJM Bars Ramsey winch 2" Lift 32" Muddies 300K of Experience
toy60 is offline   Reply With Quote
