Old 11-29-04, 07:47 PM   #1 (permalink)
MR.FJ60's Avatar
It's winter and my FJ is Not warming up!
It's been getting a cold here and even got a little bit of snow last night and everytime I look at my temp guague it doesnt bearly move. Anyone here do anything special for the winter months to help warm up a little better? Thanks in advance guy's.
MR.FJ60 is offline   Reply With Quote
Old 11-29-04, 07:49 PM   #2 (permalink)
lowtideride's Avatar
TLCA# 14891
I moved south.
My rig did the same thing when I lived way up North. 10 min warm up times til ya hear it roaring from the living room.
www.NFCruiserheads.org 2RZ-FE 'D 1983 SR5 Hilux...
has had no peers for 50 years...
lowtideride is offline   Reply With Quote
Old 11-29-04, 07:55 PM   #3 (permalink)
MR.FJ60's Avatar
ha hah! Thanks,But I'm not planning on moving anywhere anytime soon.
Old 11-29-04, 09:26 PM   #4 (permalink)
gulp3000's Avatar
T-stat stuck open will cause that. Just had to change mine this weekend. NAPA didn't have the right gasket but other than that it's a piece of cake. Good time to throw some new hoses on as well.
If it's just taking too long to warm up. The old cardboard in front of the radiator might work.
Don '87 Turbo Runner
'97 FZJ80 waiting for the wife to finish using it!
<----- I miss my 60!
gulp3000 is offline   Reply With Quote
Old 11-29-04, 10:12 PM   #5 (permalink)
TLCA# 14625
I got rid of the stock engine fan and hooked up an electric. never turn it on in the winter up here, heats up ALOT faster. Of course, i replaced the radiator at the same time, so that might have helped.
ILikePie is offline   Reply With Quote
Old 11-29-04, 10:57 PM   #6 (permalink)
getto's Avatar
I had the same problem until I replaced the thermostat. Very cheap from the dealer and a quick project. Make sure you install it right side up, with the correct gaskets (I learned the hard way).
Todd
getto is offline   Reply With Quote
Old 11-30-04, 12:33 AM   #7 (permalink)
MR.FJ60's Avatar
Well guy's I just replaced the thermostat last year during winter. You guy's think that I could be having this problme maybe because the thermostat could be upside down? Thanks for the reply's.
Old 11-30-04, 12:36 AM   #8 (permalink)
WALoeIII's Avatar
Its a cold running engine, what oil are you running? (Don't know how much this relates but I'm more curious)
-- Andrew
Journal - FJ60 - Wheeling
84' FJ60
WALoeIII is offline   Reply With Quote
Old 11-30-04, 12:44 AM   #9 (permalink)
MR.FJ60's Avatar
I switched it to 10w40 about a month ago.
Old 11-30-04, 06:37 AM   #10 (permalink)
60wag's Avatar
If the top gasket for the thermostat is missing, it will run cold.
'96 FZJ80
Member Rising Sun Chapter TLCA
KC0ZAC
60wag is offline   Reply With Quote
Old 11-30-04, 10:11 AM   #11 (permalink)
MR.FJ60's Avatar
OK, I think this might be the problem here. As I recall I got the wrong gasket when I installed teh new thermostat a year ago. Thanks 60wag!
Old 11-30-04, 10:43 AM   #12 (permalink)
getto's Avatar
That was my problem, too. Once I installed the correct gasket, it got hot really quick.
Todd
Old 12-01-04, 09:48 AM   #13 (permalink)
84Bruiser's Avatar
I'm having the same problem...
I'm going to start with the thermostat, since the fan turns on when I start the car, almost immediately... but I have another radiator question: SOMEtimes I have a pinhole leak at the top of the radiator, it never leaks more than a drop, but could my problem be at all related to poor pressure regulation in the radiator?
Thanks in advance,
Bruiser
'84 FJ60 183K
84Bruiser is offline   Reply With Quote
Old 12-01-04, 05:01 PM   #14 (permalink)
60wag's Avatar
A tiny leak wouldn't make it run cold. It might make it run hot if the leak was big enought to truly drop the pressure enough to let the coolant boil. I'd take the rad to a shop and have it fixed before the small leak becomes a big one.
'96 FZJ80
KC0ZAC
Old 12-01-04, 06:32 PM   #15 (permalink)
sanjuancruiser's Avatar
Mine could be warmer as well. Is there a difference btw factory and aftermarket t-stats?
TLCA#14565
62 FJ45 SWB H55,
88 FJ62 H55,
If it can't be grown Its gotta be mined
http://www.safari-ltd.com
sanjuancruiser is offline   Reply With Quote
Old 12-02-04, 08:29 AM   #16 (permalink)
peepers's Avatar
just go oem t-stat with new gaskets. you will need 2. the gasket for the tstat houseing and the rubber round one for the tstat itself. if you go that route, you can rule out that part of the cooling system and move onto something else.
peepers is offline   Reply With Quote
Old 12-02-04, 06:42 PM   #17 (permalink)
Peepers
Thanks-I kind of figured that but never hurts to ask. Aftermarket ones look very close to OE (read not junky)so I never thoughtnthat they could be suspect.
TLCA#14565
62 FJ45 SWB H55,
88 FJ62 H55,
