Old 11-24-04, 08:43 PM   #1 (permalink)
LT1-62's Avatar
FJ62 PTO winch rating?
Hi guys
I've posted this over in international cruiser tech as well since non-US people prob see alot more of the PTOs but.... I have a FJ62 with factory PTO winch and was wondering what the rating of these are? Ive heard that the pound ratings given to winches may not be comparable since some describe line pull and others absolute hoisting weight? Any idea how my factory 60-series PTO would translate into 'Warn-style' pound units? Thanks.
'86 FJ62 lowroof, LT1, H55F, 35x12.5s BFG MTs, 4.56s, Lockright, 2" lift springs, 2" overstock shackles, 2" body lift, Rancho 9000s with in cab controller, custom bumpers, comfy seats, booms, and then....
LT1-62 is offline   Reply With Quote
Old 11-24-04, 09:17 PM   #2 (permalink)
Tank Buster
HZJ60 Guy's Avatar
TLCA# 13102
I believe Wayne"O" answered you question on the International (not harvester) site.
TB
2001 VW TDI Bora
1987 Toyota HZTJ-60
I'm a democrat member of the House of Representatives, and I've got what it takes to take what you've got!
HZJ60 Guy is offline   Reply With Quote
Old 11-25-04, 02:35 AM   #3 (permalink)
HJ61TurboDiesel's Avatar
Hello there!
Just got hold of a PTO and a mech winch. Looked up the Toyota manual and the rating is about 1800 kgs or 4000lbs.
This al depends on the rating of the split pin installed in the front universal joint comming into the vinch. This could be replaced with a stronger. The winch itself is wery powerful with a worm gear principle.
Dan
HJ61TurboDiesel is offline   Reply With Quote
Old 11-25-04, 06:32 AM   #4 (permalink)
cahilc's Avatar
Location: Silver Spring, Maryland & Daytona Beach, Florida
Doesn't the PTO have a shear pin ? Probably want to have spares ...
Cahil
67 Red FJ40 - SBC, Holly, NV4500, SOA
87 Blue FJ60 - Cummins 6BT, NV4500, OME, SUA
..... coupla' parts rigs too ...
cahilc is offline   Reply With Quote
Old 11-25-04, 08:01 AM   #5 (permalink)
Merchant of Death
Landpimp's Avatar
TLCA# 5506
I beleive its about 8000 lbs rolling, which is how Warn measures theirs.
Truth is a torch that shines through the fog without dispelling it. Always be true to your work, your word, & your friends, & you will never live a day without peace
Landpimp is offline   Reply With Quote
Old 11-25-04, 09:20 AM   #6 (permalink)
Tank Buster
HZJ60 Guy's Avatar
TLCA# 13102
What is this shear pin you guys are talking about?
How is that different from a "failure" pricipal of an electric winch?
TB
2001 VW TDI Bora
1987 Toyota HZTJ-60
Old 11-25-04, 07:26 PM   #7 (permalink)
cahilc's Avatar
IIRC, the factory PTO has a shear pin in one of the drive shafts. It's designed to shear off at a certain load because of the direct connect to the motor. My guess to prevent PTO driveline windup. Sort of a build in safety feature. Electric motors, IIRC, will simply bog down if overloaded and probably have similar but differently designed safety features.
Cahil
Old 11-25-04, 08:58 PM   #8 (permalink)
LT1-62's Avatar
Thanks guys, hmmmm I guess my shear pin must have been upgraded in its life then. I lent a mate of mine my truck and he took it up into the snow and got it stuck. Thinking that the lever inside was a diff lock, he engaged it (actually engaged the winch), revved the hell out of it, coincidentally got out of the foot of fresh snow he was stuck in only too hear a very loud and ugly pop/twang sound. He grudgingly told me about it thinking he had busted some driveline component and I replied "what diff lock?". To his embarassment we checked out the winch and the hook was gone leaving only a frayed piece of heavy duty steel cable. The hook had been attached to the front winch cage/bullbar and had wound onto itself until it broke the line. this cable is pretty scary strong so if the factory winch shear pin is only lightly rated then I guess this means that it must have been changed out in its life.
Old 11-29-04, 11:20 AM   #9 (permalink)
I'm really very humble
photogod's Avatar
Drive shaft #1 has a "Safety Lock Pin" At the forward yoke.
photogod is offline   Reply With Quote
